      07-17-2018, 07:16 PM   #1
MJS130
Drives: 2007 BMW 130i M Sport
Another 130i caliper question
Hi all,
I'm up for new rotors and pads soon, so contemplating just doing a full upgrade. Can anyone suggest calipers and rotors that will fit the standard 17" 207m wheels?
Cheers
Mark
      07-25-2018, 01:11 AM   #2
Giveway74
Giveway74's Avatar
Drives: 130i and MK7 Golf GTI PP
135i 6pot front calipers fit a 130i under those 17"wheels.
The fit pre LCI and LCI and are a direct bolt on.
LCI cars had them as an option.
2006 E87 130i
M3 front and rear arms, M3 Front and rear ARB , Quaife LSD, BMW performance wheel (non electronic), 135i Brakes, DS2500 pads, Apex wheel studs, Adjustable Bilsteins, API Half cage, Hankook Z221's (track) and Bridgestone RE002's (street) 225's all around
      07-25-2018, 07:10 PM   #3
MJS130
Thanks for that, would it make sense to keep the stock rear calipers and upgrade just the front?
      08-06-2018, 09:01 PM   #4
Giveway74
Giveway74's Avatar
Rears are a pain to do it properly by changing the hub flange. You can use a spacer behind the rotor as a easier alternative but you lose most of the lip to mount the wheel onto.
If i was to do it again i'd leave them stock unless you want the looks.
2006 E87 130i
      08-08-2018, 08:43 PM   #5
Cheungs
Not that left, your other left!
Cheungs's Avatar
Drives: SG BMW 130i
I have done rears on my 130i PreLCI.
Took me awhile to find, but this is the correct BMWP rear rotor to fit the caliper without any modification: 34216795755KT
(you will need to trim the dust shield to fit the caliper though)
Goodluck!
SG 06 BMW 130i E87
- Build Thread -
      08-23-2018, 12:15 AM   #6
MJS130
Thanks for that info, still tossing up whether or not to upgrade, stock brakes are more than good enough for the street!
