      01-19-2020, 04:04 PM   #1
cjb762
Drives: 2013 135is, MG 6MT
Oil temp gauge not working
Hey all,
I have done some searching, but haven't been able to find anything. For some reason my oil temperature gauge stopped working yesterday. I can't be positive, but I think it may have happened after I hit a pretty big pot hole with my right front tire.
I did the instrument cluster self test, and the temp gauge (and everything else) is in working order.
When I hooked up a scan tool and the "live data" shows that the oil temp is -61, which is obviously incorrect. There were also some codes about "implausible oil pressure," and Carly gave a "003427: engine oil pressure sensor, electrical: short circuit to ground"
I have poked around a little bit, but don't really know what I am looking for. I am leaning towards replacing the pressure sensor, but wanted to see if anyone had any other ideas first.
Thanks for any help you can give!
      01-20-2020, 05:08 AM   #2
Sam_M
Tea wot?
Drives: 2011 N55 135i 6MT
Most likely the wiring has been damaged or the plug has come loose.
Based on the two codes you've got, the pressure sensor isn't providing a valid signal.
Find the location of the sensor, check the plug and wiring to it. Could be that the big pothole you hit dislodged the pressure sensor plug.
cjb7621221.50
      01-20-2020, 10:34 AM   #3
cjb762
Edit: You were right on the money Sam - It turns out a rodent chewed through the wires after making a huge nest behind my throttle body.
