      11-13-2013, 06:43 AM   #1
Iron Man
Iron Man's Avatar
Drives: N/A
Evans Coolant?
Does anyone have experience using Evans NPG+ Waterless Coolant? It is available on Bavauto.com and they say it is good for 500,000 miles. I am somewhat skeptical about it being "lifetime", but I like the idea that it doesn't use water. Also not sure if it might help extend the life of my water pump as well.
      11-14-2013, 06:34 AM   #2
Iron Man
Iron Man's Avatar
Drives: N/A
Bueller? Bueller? Bueller?
Well I guess no one on here has used it (or has any input). Anyway, after researching further, sounds like it is not a good option to use.
      11-14-2013, 08:53 AM   #3
bmw1racer
bimmerphile, technogeek
bmw1racer's Avatar
Drives: 2012 E82 6MT Sport
Sorry, I must've overlooked this thread.
I've read about this coolant and I'm intrigued by it, but there doesn't seem to be a whole lot of data about its positives and negatives...
      11-14-2013, 09:56 AM   #4
Iron Man
Iron Man's Avatar
Drives: N/A
Yeah, the only place I could find any real info was on BITOG, but most of the experiences were somewhat outdated (sounded like Evans changed their formulation as well).
      11-14-2013, 02:46 PM   #5
02rsxpilot
02rsxpilot's Avatar
Drives: 2012 BMW 135i
2012 BMW 135i  [10.00]
2013 Mini Cooper S  [0.00]
2002 Acura RSX  [0.00]
I saw a Wheeler Dealers episode where they used waterless coolant. Pretty cool stuff considering he was able to run the car and open the radiator while it was hot, since there was no water to create steam. But...I don't know what its cooling performance is. After all, the water in a normal coolant mixture is the part that does the cooling.
      11-26-2019, 11:14 PM   #6
Ursan
Ursan's Avatar
53
Drives: '12 128i, Volvo 945t & 780t
Dead thread revive.
I'm using this in my 1994 Volvo 940 turbo. No change from water/glycol, but what's nice is my coolant system is now zero pressure.
Heat is the same, takes the same amount of time to get to temperature.
Keeps hoses cleaner longer. No rust. My water pump seems to be quieter.
I'm planning on doing this to my 128. But I'll replace all the hoses first.
Requires a complete flush and a pre-clean with Evan's flush. I used a small vacuum cleaner to extract as much water as possible. Evan's allows up to 2% water.
