      08-19-2018, 01:49 PM   #1
Hops128i
Hops128i's Avatar
71
Drives: 2010 128i, manual, sport pkg
Need diagnosis dunlop Ziii wear at the track
Over 4 years with dunlop ZII's, i did maybe 10 autocross event and 6 or 7 track nights, and they still had half their tread. Had to get rid of them because they got too hard.
So this spring I got new dunlop ZIII's because I really liked the ZII's. I've only done 3 track nights, and i have a weird wear pattern on the front right. This wear seems mostly from a track night i did a Dominion Raceway in Virginia. It was ~93 degrees, and my tires were 40-45psi. I have a similar wear patter on the front left, just much less pronounced, and the rears don't look that bad. Definitely, rotating front to rear for my last event of the season.
Anyway, just wondering why i'm having this wear pattern.
(2010 bmw 128i 92k miles, -2.0 camber with plates on a stock suspension)
2010 128i manual, sport package, performance exhaust, Vorshlag camber plates, Bilstein B6 struts/shocks, 245/40/17 ZIII square on et 40 with rolled rear fenders.
      08-19-2018, 04:15 PM   #2
drunkenup
Drives: 2009 135i, 2021 F150
The center rib of my Z2 ss tend to look like that- the edge wears down and narrows the rib. Your pressures are 40 psi? I would not run anything more than 35 hot. I find mine happiest around 32-33.
Good luck with the z3 - my z2 ss are calling it quits after some 8 days with at least 3 more worth of tread. Z3 will probably be my next set.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
      08-19-2018, 09:34 PM   #3
Hops128i
Hops128i's Avatar
71
oh, maybe i have too much pressure? .... i was thinking the higher pressure would reduce outer shoulder wear, i only have 2.0 camber
      08-19-2018, 10:15 PM   #4
drunkenup
Yeah 40 is very high- less of the tire is going to be touching the ground vs if you were setting it lower so you're also leaving room on the table in terms of grip. Uneven wear that is center biased is a sign of that. On the street I run the tires at around 36 cold.
As far as reducing shoulder wear, at -3 and greater neg camber, and zero toe it wears pretty even.
That said the center rib on my z2ss gets pretty chewed up compared to the rest of the tire, maybe just a product of pressure getting too high before i have a chance to bleed it
      08-20-2018, 07:22 AM   #5
bionicbelly
Drives: Z3 coupe, 128i
Yeah, probably a little less air, and you need more camber. Without that, your tires will never wear evenly. It is weird how the center rib is almost pefectly split, and looking like layers are flaking off though. I do not recall seeing that before. The center rib usually has a pretty pronounced bevel on camber challenged cars, but this is different. Probably a combination of the tire pressure and heat.
      08-20-2018, 10:19 AM   #6
RyanDavies
Drives: 2012 128i MSport
Needs more camber.
      08-20-2018, 06:09 PM   #7
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
More camber, less tire pressure.
Beyond that, it's partially normal. RE71R do the same thing, it's part of their charm.
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      01-29-2019, 05:11 PM   #8
coolmac
Drives: 335i , M Coupe
I like the Dunlop ZIII at 36-38psi hot. Must check them first off track.
      02-05-2019, 10:28 AM   #9
beattiecj
beattiecj's Avatar
Drives: 2012 135i 2017 x5 35i 1988 e30
Agree same with the Hankook RS4s, I get the same wear at -2.2 degree.
Def lower your tire pressure I was maybe 28-29 pressure cold... it makes a big difference from running 40psi.
