      08-17-2012, 10:55 AM   #1
M135
Professional Rookie
M135's Avatar
Drives: 2016 M4
2008 BMW 335xi  [0.00]
2016 BMW M4  [0.00]
My car forgot its comfort access
So I have comfort access, and recently when the car was in the body shop the guys did not shut it off properly and drained the battery. When I got the car back it is like it totally forgot comfort access, I cannot touch the handles to open and key must be in the ignition to start it. I replaced the battery in the fob and same result afterwards.
Is there a trick to getting this to reset or must I go to BMW? Trying to avoid a whole demod right now.
2016 MGM/Sakhir M4
DCT | M-Adaptive | Not Stock for Long
      08-28-2012, 08:30 AM   #2
M135
Professional Rookie
M135's Avatar
Drives: 2016 M4
2016 BMW M4  [0.00]
Anyone?
2016 MGM/Sakhir M4
      09-13-2012, 09:42 PM   #3
corrado
Drives: 2008 135i
I'd like to know the answer to the above question as well. My comfort access is also not working.
      09-15-2012, 06:17 PM   #4
b1aze
Just one more taste...
b1aze's Avatar
Drives: 2013 128i 6MT MSport
My CA is working intermitently from my drivers side only. I can still CA into the trunk and passenger side, but my drivers side works sometimes and not others.
      10-02-2012, 09:56 PM   #5
Low Gravity
Low Gravity's Avatar
Drives: 435i, 135i, s52 325is
I have also noticed this occasionally happening to my driver's door and trunk, the passenger side works all the time though. Very strange
      10-03-2012, 10:49 AM   #6
JimD
JimD's Avatar
368
Drives: 128i convertible
I don't know exactly how comfort access is implemented but I believe it is through the same instructions you change while coding. I know I got my top to go down with the key fob through coding and this is normally a comfort access feature. Anyway, if my assumption is correct, and you have a pre-body shop version of your file, you can restore to that. If you do not have the file, then I don't see an alternative to a trip to the dealer.
Jim
      10-05-2012, 09:25 AM   #7
M135
Professional Rookie
M135's Avatar
Drives: 2016 M4
2016 BMW M4  [0.00]
I have coding capability, I may check it out
2016 MGM/Sakhir M4
      11-10-2012, 09:31 PM   #8
Shaggykjb_135I
Shaggykjb_135I's Avatar
Drives: Sedonna Red 135 6spd. loaded.
2008 135i  [0.00]
I stopped by my local BMW dealership and told them about the same issue. I mentioned that I used to be able to start me car with my fob in my pocket. Now I must have it in the ignition.
They "Analyzed" the issue and said their was a sensor behind the ignition Fob insert that reads the proximity of the Fob. They said I would have to replace it for it to work. Its about 700USD. With my extended warranty I would pay about 300USD.
Can anybody get their hands on a schematic of the dash to verify this part and possibly the part number?
      11-28-2012, 05:24 PM   #9
spellbmw
Feuertrunken
spellbmw's Avatar
Drives: MY10 135i 6MT
Mine stopped working and a new fob had to be ordered n programmed....while yet on warranty. No more warranty, so I hope it doesn't happen again.
Crimson-Coral Red |Walnut | iDrive | Premium & M Sport | Heated seats | PDC |CA | Premium hi-fi | BMW SSK & PE | BSH OCC -
Deposit 7/15/2009 - Ordered 9/18 - Production 9/23-30 - Euro Delivery 10/17 - Shipped 11/13 - Oxnard 12/8, Oregon 12/24 & home on 12/30
      12-07-2012, 12:29 PM   #10
b1aze
b1aze's Avatar
I brought mine in for an oil change and had them take a look at it. They ordered a new door handle and hope that it will remedy the issue. Outside of that, they would have to do more digging. I can still easily access the trunk and passenger side but cant get CA to work on the drivers side at all anymore.
Ill update if i find out anything.
      12-07-2012, 12:37 PM   #11
euro2fast4u
Drives: signle turbo e30
Number 3??
http://realoem.com/bmw/showparts.do?...18&hg=61&fg=25
My boosted e30 vs boss 302 new video
http://www.youtube.com/watch?v=CdgxMMIOgk4
      06-07-2017, 09:27 AM   #12
mistawall
mistawall's Avatar
Drives: 08 135i 6MT
2008 BMW 135i  [9.50]
im having same issue...
08 135i|1M conversion|Montego Blue|TFT Inlets|Riss Racing DPs|Riss Racing Exhaust|Tial BOV|VRSF 7"FMIC|WEDGE TUNED|BMS Short Throw Shift|BlackLines|PURE stg2| follow me on instagram!
      06-07-2017, 03:06 PM   #13
Duesentrieb
Drives: E81 116i, F31 LCI 320d
If only one handle will not work, normally this handle is defective.
      06-13-2017, 08:25 PM   #14
thetaobear
thetaobear's Avatar
47
Drives: 2009 135i Crimson Red
First thing I would check is the fuse... I changed mine from 15A to 20A and this intermittent issue went away.
Apparently the 15A fuse (which comes stock) sometimes can't handle the pressure.
Change it to a 20A fuse and see if it works. As per,
http://www.e90post.com/forums/showthread.php?t=439456
      06-14-2017, 11:20 PM   #15
Nasserdamus
Drives: 09 135i / 01 Z3 M Coupe
Bmw recognizes 10 keys for the vehicle with only 2 for CAS.
alot of time the battery located in the back of the key dies out, easy fix.
if the vehicle did "forget" the programming for the vehicle you can access it in ISTA and change the key numbers and profile number to "key 1" or "key 2" and it should all work again, also keep in mind your not suppose to "jump start" bmw's alot of things can go wrong.
FBO obviously
      06-15-2017, 01:42 AM   #16
Make a new claim with your insurance company. Tell them what you said... that it worked before going into the body shop. Sometimes when body shops weld on a car... they don't disconnect the car's battery... and the voltage spikes can kill some ECMs in the car.
IF it is the sensor behind the ignition Fob insert - why are the door handles not working when you touch them? Sounds like your dealer just gave you a "guesstimate" on what's wrong. ?
Your insurance company should take car of this for you.
Dackel
PS: Have you tried replacing the key fob battery ?
      08-29-2017, 04:53 PM   #17
Matt@EuroJerks
Drives: 2021 Jeep Cherokee
I am having a problem where everything works except the driver side CA (both lock and unlock by touch) the key fob battery was replaced less than 6 months ago and passenger side works by touch. What number fuse should I pull and check? Any other ideas?
      05-21-2019, 11:10 AM   #18
Matt@EuroJerks
Where is the CA module located so I can check that as well as checking the fuse?
      06-30-2019, 03:24 PM   #19
Ladydragonz
Ladydragonz's Avatar
Drives: '08 135i M Sport
Recently everything but my trunk is working for me....started off sporadically now it won't work at all I have another fob and tried it as well with no success. Anything I can try? Im so used to accessing my trunk without the button or going in my car it's been a huge hassle for me.
      07-03-2019, 07:20 AM   #20
JimD
JimD's Avatar
368
It is possible to set your car up to unlock everything, including the trunk, when you unlock it. That is how mine is set. I do not have comfort access. So I don't know if it would unlock the trunk when you touch a door handle but it seems worth a try. You can set it through the buttons on the turn signal.
