11-16-2018, 05:12 PM | #1 |
Rep 101
When to change spark plugs
Hi all,
So I thought in a previous thread I wrote about (4K average rpm) that the smell I had was with the engine not being properly heated up or something. However it is due to a bad coil (found out this morning) when my car went into engine service soon limp mode with the engine rattling (this is a symptom of a bad coil this happened to me a year ago) I am changing all of my coils (car is at 30k miles) at a local trusted guy . I had one coil go bad about a year ago and bmw replaced the one spark plug as well coil for that cylinder. When is the recommended interval to replace spark plugs? The local guy adviced against it because only the coils were recalled. Thanks. |
11-16-2018, 05:40 PM | #2 |
Rep 22,992
BMW says for a 128i that the spark plugs should last 100K miles.
For a 135i they say 45K miles. For a 1M they say 30K miles. I think that most people should change their spark plugs at ~30K or so. Basically if your car is tuned... change the plugs. The problem with long life spark plugs is, sure they might last 100K miles(in a NA motor) but who wants to risk removing those seized out plugs at that mileage. IF your into performance driving, you like a snappy throttle response... and power... change your spark plugs more frequently. Just like engine oil. BMW wants you to buy a new car every few years just like a cell phone. I prefer to hold onto my cars longer than two years. Dackel
Captain Blood13866.00 |
11-16-2018, 06:19 PM | #3 |
Rep 101
Thanks for the detailed response. Do people here think that are throttle lag has to do anything with spark plugs? My basic research online is showing that lack of acceleration when hitting the gas pedal maybe a sign of a faulty spark plug.
What do you all think? I never got a code for a spark plug, am I over worried about this? Like the previous posted menionted they are recommended for 100k miles. I only have 30k miles on my 09 128i vert |
11-16-2018, 07:23 PM | #4 |
Malcontent
188
Rep 305
For the most part, my rule of thumb is to cut in half any current BMW recommended service interval. I do the plugs on my 128i every 50k. FWIW, driving harder will keep them cleaner.
Life's tough. It's tougher when you're stupid. -John Wayne
Dackelone10512.00 MightyMouseTech4334.50 |
12-10-2018, 08:54 AM | #5 |
Rep 12
60K miles. Changed spark plugs. No real challenge, just took time to remove the cabin air filter assembly below the windshield. Need to do this to expose the rear 2 cylinders. Videos on line showed how to use a screwdriver to pry up on the coil and they popped out. Did not have to remove the strut brace/bar. Also shows how to remove the wire looms and cabin air filter assembly. Had no codes, but had a misfire/hesitation when trying to accelerate at about 2k RPM in 6th gear at about 70mph. Old plugs had noticeable wear on the center electrode. Gap was .050-.055 while new plugs were .040. Hesitation seems to be gone now. Plugs are recommended at 60k miles, but seeing the wear, and if it is linear at about .002 every 10k miles, I think they should be replaced every 40k miles. I'll try that interval next time or when/if the hesitation comes back. NGK plugs, with bright plating on the threads that is supposed to have lubricity so they recommend no anti-seize. Finger tight, then 90 degrees, easy. From FCP Euro, NGK 95712 at $65 for 6.
Had a teaspoon of oil in the last cylinder next to the firewall. Valve cover gasket? Mopped it up before putting in the new plug. Front valve cover bolts did not move with reasonable effort, back ones did move a few degrees tighter. Bolt heads needed a torx socket. Glad I bought a torx socket set, a cheapie set at Autozone for $20. Looks like many other bolts in the engine bay have positive torx heads that require a socket. (N52 in a 2013 128i) Last edited by 1 Bimmer; 12-12-2018 at 10:18 AM.. |
12-10-2018, 08:08 PM | #6 | |
Rep 3,071
12-11-2018, 12:09 PM | #7 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
Change them more frequently than what BMW recommends, for sure. I don't have enough experience to call a specific mileage, but 02Pilot is probably on the mark for the 128i at 50k miles between changes.
I just changed mine (no idea what mileage was on them, but the gap was roughly 1.5x the size of the new plugs, my dad was thinking that they were never changed at 182k miles) and the car drives SO much better. I'm blown away by how it is performing now. It pulls harder than ever, all the way to redline like an N/A motor should, it does so in the smoothest way I've ever felt, and the throttle response is way better. Change your plugs.
Dackelone10512.00 |
12-11-2018, 12:34 PM | #8 | |
Rep 22,992
BMW NA(in the USA) recommends a 45K miles spark plug change for all 135i's(n54 and n55). Or at the third oil change(back when BMW was doing oil changes every 15K miles, now they say every 10K - but I would say change your oil every 5K!). For 1M's(n54T) BMW NA says to change spark plugs at 35K miles. For the 128i(N52 & N51) BMW NA says every 100K. But I feel that is WAY too long. One reason why you don't want to wait too long to change your plugs... is bc they will freeze or seize in place. And IF that happens... you will probably need to pull the cylinder head to repair that! Here is what BMW AG says for 135i's with the PPK installed... My old plugs(N54) at 30K miles...
chris_flies3027.00 |
12-11-2018, 08:42 PM | #9 |
Rep 3,071
Interesting. The US sticker that is put on with the n55 PPK says 45,000 miles. (Photo compliments of @zx10guy from a spark plug thread.
Seems strange it would be no change with a tune?
12-12-2018, 11:35 PM | #10 |
Rep 2,805
At 48,000 miles my plugs were very difficult to remove. It felt like something that had been torqued to 40 or 50 ft-lbs. Also, the gap had grown to nearly 0.060" !!
Dackelone10512.00 |
01-02-2019, 10:16 AM | #11 |
Rep 3,547
My gap was noticably bigger at about 70K miles when I changed them but the car ran fine. My originals and replacements were NGKs which are supposed to have an anti-seeze material in the threads. The old ones came out fine. I had no oil in the cavity surrounding them.
Dackelone10512.00 |
01-04-2019, 10:35 AM | #12 |
Rep 992
My N52 had 68k miles when I changed them and the electrodes had noticeable degradation. No way should they go 60k miles! Even on the N52, I would change them probably every 30k miles. Why not? It's relatively cheap and easy.
Dackelone10512.00 |
01-28-2019, 11:48 AM | #14 |
Rep 99
Good information on this post.
The dealer replace one coil (#4) due that I had a insurance claim and due to the accident the light came on and the cylinder was misfiring. I have few questions: The dealer says that soon I had to replace the coils are they were getting weak. The spark plugs and fuel injectors were replace two years ago. I paid for the spark plugs and the injector were done in warranty. Now that I have no light, if I replace the coils and spark plugs, I should not get any SES light, correct? Where did you buy the special socket for the spark plugs? Which one is cylinder #4? Thanks a bunch!
Used to own the eclipse (avatar pix).
Sold it and post it in memory |
01-29-2019, 11:39 AM | #17 |
Rep 2,805
Just plugs for me. From what I've read fresher plugs prolongs coil life.
12-19-2019, 08:08 AM | #19 |
Rep 277
Hello guys
I got some engine sputter this morning followed by some difficulty accelerating and a bit of a rough idle. I'm almost at 38k miles and I think I need to change my plugs soon. I see some of you are using ngk plugs, are those the ngk laser double platinum? Pleased to hear, Makis |
12-19-2019, 04:42 PM | #20 | |
Rep 2,287
On my old N52 I changed the plugs at 100k and then at 190k both times the old plugs looked good and the engine response stayed the same. I'm was tuned and did the tuning myself, pretty sure I'd notice a performance difference with the new plugs. Never had a coil fail. My commute was 75% freeway at good speeds. Kombi would say my average was 50 MPH. I've moved and my new average is 25 MPH😢. But now I'm 4.5 miles from the office instead of 43. Makes me wonder what I'm doing with a tuned Z4 35IS, : |
Rmtt8206.00 |
12-20-2019, 10:48 AM | #21 | |
Rep 1,233
I really do wonder how much the commute cycle, fuel and regular maintenance/oil changes makes. I am the 2nd owner of my 128i, bought it with 67K Kms on it, and after applying a tune (just stage 1 software) at roughly 95K Kms, the plugs went shortly thereafter. I did both coils and plugs in one shot and she was good as new. Feel like the advanced timing and extra spark a tune requires was what put the original stuff over the edge.... EDIT: Oh - also forgot to mention, wife drives a bone stock 328i (also 2nd owner, purchased at 55K kms CPO from BMW) and the plugs/coils were gone by 80K kms.... : |
12-21-2019, 02:30 AM | #22 | |
Rep 2,250
