05-26-2009, 10:25 PM | #1 |
Rep 361
HPFP Broken...... AGAIN!?!?!
So my HPFP already died on me once and BMW took care of it free of charge for me a few months ago so I was ok with it. I understand that sometimes automakers mess up but atleast BMW fixed it under warranty. BUT NOW....... something is wrong with my 135 again! I dont know if its the fuel pump but it seems like it is. My car started sputtering and shaking sometimes.... almost like a hicupp on friday night. Now its getting progressively worse and today the engine malfunction light came on. How do you mess up the fuel pump TWICE (if it is the fuel pump)??? Anyone else's fuel pump go out twice?
05-26-2009, 11:44 PM | #2 |
Rep 3,350
Unless they replaced it with a rebuilt old version instead of the new '885' series. In any case it is covered under warranty. How often do you fill your tank? Only when the light comes on or do you not let it get below 1/2 very often?
05-27-2009, 01:15 AM | #5 |
Rep 361
me too........ i have an appointment to get it looked at tomorrow. my service adviser called me after i made an appointment with the receptionist at the service dept and sounded like he was skeptical about my claim since they replaced my HPFP earlier.
05-27-2009, 06:12 AM | #6 | |
Rep 2,199
I still believe there's some external variables involved in these failures, maybe ethanol ? pump cavitation is very bad, any air in the line will cause partial cavitation until the air is pushed out, maybe these pumps are susceptible to that type of damage I don't know it's just a theory
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
05-27-2009, 09:21 AM | #7 |
Rep 1,917
There has to be some external factors involved as I've read quite a few times where people have had to change the pump multiple times where others never have a problem.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport |
05-27-2009, 10:32 AM | #8 |
Rep 361
well i just got back from my service dept. my service advisor said he would have to contact BMW because we already changed the fuel pump out and put a new one in a few months ago and he said it has the "classic symptoms" of another fuel pump failure
05-27-2009, 11:43 AM | #10 | |
Rep 2,199
and for sediment, it comes from the gas station tanks there's a reason our fuel tanks have a pickup filter before the fuel pump, I've changed fuel pumps and those things are straight up nasty with dirt from fuel
05-27-2009, 11:44 AM | #11 |
Rep 56
I posted similar questions in another thread but got no answers.
It would be great to see a poll of those with and w/o fuel pump problems. Miles at time of failure (if you've had one), Octane rating of fuel used (be honest), Fuel company (Mobil, BP, Sunoco, Shell, etc.), Typical amount of fuel remaining before fill-up (1/4, 1/8, light?) |
05-27-2009, 11:47 AM | #12 |
Rep 2,199
can you do multi choice polls in here? It would only be good if you look at only people with failures first
05-27-2009, 01:42 PM | #13 | |
Rep 5,970
The fuel pump ALWAYS picks up from the bottom of the tank. Anything that settles to the bottom is going to enter the pickup. |
05-27-2009, 01:45 PM | #14 | |
Rep 2,199
I know for sure my tank has crap in it, when we had our fuel shortage last year the gas I had to put in did not look like gas, every gas station ran out so all the tanks had everything in the bottom stirred up it could also be air in the line causing cavitation in the HPFP, if you have ever been around a high pressure pump that gets air in it, it's a scary thing. If your going down to the light turning on, you could easily get air in the line going around a corner or as some have done, running it completely out of fuel and we all know by now, when the hpfp detects a pressure problem, it does not stop you, you get to keep on driving
05-27-2009, 11:33 PM | #15 |
Rep 361
Well I got the call today...... apparently its a bad fuel injector this time not the fuel pump. Anyone else heard of any 135's with bad fuel injectors?
05-28-2009, 05:40 AM | #16 |
Rep 2,199
yep, it's fairly common, if you google it there's quite a few that have had bad injectors replaced
05-28-2009, 03:16 PM | #17 |
Rep 361
This is really bad. This is my first BMW i've ever bought and I've already had the HPFP replaced and now the injector and i've owned the car less than a year.
05-28-2009, 03:19 PM | #18 |
Rep 1,609
I wonder whether the fuel injector was damaged while the HPFP was going out.
05-28-2009, 04:43 PM | #20 |
Rep 1,917
True, but you have to wonder if the HPFP failure caused the injector to die quicker than it would normally and it took until now to fail.
05-29-2009, 01:41 AM | #21 |
Rep 361
I dont know but im pretty disappointed in the whole situation. I mean..... car is less than a year old and already had 2 major problems arise. My confidence in BMW is starting to go downhill
05-29-2009, 07:04 AM | #22 |
Rep 2,199
injectors can get burnt if the car runs too lean, this happens on a few different engine designs and is not that uncommon
it could have been what happened to yours, I would ask the tech if they know what would cause it, and why only that 1 injector and not the other 5
