      10-04-2019, 01:44 AM   #1
arch2r84
Drives: bmw 335i
BMW 1M 295 squared track car
ive been looking around for the best setup for my car, and with some help from my shop JMP autowerkz in Southern california and slicer i was able to fit 295's on my 1M now for the test at buttonwillow in the following months.
      10-04-2019, 05:44 AM   #2
10"
10"'s Avatar
Drives: orange BMW 1M.
why on earth would you want 295s in the front?!
if you are going square why wouldn't you go 245 or 265 even?
are you rubbing?
don't read this. too late...
      10-04-2019, 07:09 AM   #3
1mGator
1mGator
1mGator's Avatar
Drives: Valencia 1M
Wow ... I have 265 front and 295 on rear .... can’t imagine 295 on front
      10-04-2019, 09:59 PM   #4
arch2r84
Drives: bmw 335i
are you rubbing?
I had done 265 squared and wanted to test a better setup for track and it doesn't rub.
      10-04-2019, 10:00 PM   #5
arch2r84
Drives: bmw 335i
im pretty excited to test it.
      10-05-2019, 05:11 AM   #6
gmx
Drives: VO 1M
Does it poke? Can't tell from the pics.
      10-05-2019, 02:56 PM   #7
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I run 275/35/18 square. The diameter is about 1/4" less than stock diameter on the front, and I still rub at full lock, albeit slightly.
Interestingly, I rub on the rear of the fender liner not the front (revised liners). I am lowered 20mm and run -2.5 degrees camber, stock caster.
Honestly, I can't imagine how a 295 width can fit.....awaiting details
Tornado1M1211.00
ayao641.50
      10-06-2019, 10:52 AM   #8
Mogge94
Drives: 1M Coupe, Z4M Roadster
in for more details about rubbing ...
      10-06-2019, 01:19 PM   #9
SingerBuilt135i
Drives: BMW 135i and Plymouth Duster
are you rubbing?
Lol
      10-06-2019, 11:17 PM   #10
arch2r84
Drives: bmw 335i
Will post more info and pictures when I mount the Nankang ar-1 tires on my bbs wheels
      11-11-2019, 12:46 AM   #11
touringteg
Drives: 2011 BMW 1M
I am impressed this works without rubbing.
I have 255/35/19 RE71R on stock wheels on the front and it rubs the passenger side front liner closest to the door. Does not run on forward revised linings.
Did you move the washer resevoir and re mold the fender liner?
