07-17-2018, 07:17 PM | #1 |
Rep 142
Stock M sport suspension and Arc 8
hey guys I need help figuring out some answers from arc8 owners. The arc 8 thread has not yielded much.
Do 18x8.5 +45 front and 9.5 +62 rear, sit flush with the fender? Am I currect in suspecting the need for a 3mm spacer in the front and 15mm spacer in the back to make this setup flush? Once I have the wheels flush what tires can I run without rubbing 235 40 front and 265 35 rear? Any ARC 8 owners running Continental DWS, if so what size, I ask because they run wider than their specs? I want to buy tires and spacers to complete my new setup while also keep the flush look I have now. With stock wheels I'm running 15mm spacers front and back. |
07-19-2018, 11:25 AM | #3 |
E82 Mudflap Ambassador
2212
Rep 2,219
Drives: '08 128i
I have +38/+43 F/R and my wheels sit flush, so aim for similar offsets.
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
07-19-2018, 12:12 PM | #4 |
BXR
575
Rep 636
Those values don't mean much without the width. What width are you running?
07-19-2018, 02:38 PM | #5 | |
2212
Rep 2,219
Drives: '08 128i
18x8.5 +38 18x9.5 +43
Soterios575.00 |
07-20-2018, 07:10 AM | #6 |
Rep 142
07-20-2018, 09:21 AM | #7 | |
2212
Rep 2,219
Drives: '08 128i
Gonna be dead honest I'm pretty sure those are my offsets, can't remember, but I could be switching them around. Either way aim for about +40 with those widths.
07-21-2018, 07:48 AM | #8 | |
Rep 142
07-21-2018, 09:43 AM | #9 |
2212
Rep 2,219
Drives: '08 128i
Are you on mobile? I thought I made sure to enable my signature
Either way here it is https://www.instagram.com/128i.6mt/
07-22-2018, 04:15 PM | #11 |
Rep 142
09-03-2018, 03:47 PM | #12 |
BXR
575
Rep 636
Bringing this back to life. I attempted to do some math on these compared to my stock 261 style wheels.
It looks like the 8.5" ET45 fronts will push the rim out another 16.7mm (0.65") from stock The rear 9.5" ET58 rears will push the rim out another 6.7mm (0.26") from stock. I think that lines the front up a lot better, but the rear doesn't change much (save the nicer contact patch) Apex doesn't make that rear wheel in a 50 offset, but I think that would land me closer to wear I'd like it to be? Unless I'm crazy?
09-03-2018, 06:57 PM | #13 | |
Rep 3,057
Drives: 2019 M2 Competition
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
I am running the EC7. Fronts sit perfectly on the car with 18x8.5 and the offset Apex recommended. But the rear 18x9.5 sit sunken in. I put a 3mm spacer on and nothing, I think I can probably run a 10-12mm spacer and it would make them sit like the fronts.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
09-03-2018, 07:56 PM | #14 | |
BXR
575
Rep 636
If you ran a 10mm spacer, you'd actually have the same 'change' as the fronts, so a .65" increase in width to the outside.
09-03-2018, 07:57 PM | #15 | ||
Rep 3,057
Follow me on IG
09-03-2018, 08:03 PM | #16 | |
BXR
575
Rep 636
I guess I'll have to do some digging on the ring/spacer set up for those things.
BAN_M2C4154.50 |
09-03-2018, 08:43 PM | #17 | ||
Rep 3,057
Follow me on IG
Soterios575.00 |
