      08-30-2016, 02:05 PM   #1
diigodr
Brazil
Drives: 335i
Question Noise from steering box - 130i 2010
Hi guys, im with a problem on my car, is a boring noise that began like 1 month ago.Im 99% sure that the noise comes from steering box (more sure from the sector) because i put on elevator and a ramp and i tested. This only happens in low speed, almost without move and only when i turn left by slowly. For the right side, nothing happens. Also, not vibrate.
I recorded the sound, and you can check if you know or saw something like that.
My car: BMW 130i 10/11 (e87)
P.S.: Sorry for my bad english.
Thank you all.
THE VIDEO:
In the video i'm tapping in the steering for the left.
      12-11-2018, 02:56 AM   #2
juld0zer
Also check balljoints (torn boots or moisture causing stiction).
Make sure rack bolts to the subframe are tight.
Have you tested with foot off the brake?
      12-27-2018, 09:38 AM   #3
drwillb
BMW Fan
drwillb's Avatar
Drives: e30 M3, e30 M3, e46 M3
Both ends of the rack boot on the side you focused on are wet. I think that says a lot. Looks like the rack is leaking.
2012 135i Mods: air scoops, CP, K&N filter, PS1, ADE FMIC, BMW PE, JB4, 1M front body, full M3 suspension front and rear, M3 brakes front and rear, M3 rear subframe and LSD
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i
