11-04-2019, 10:53 AM | #1 |
Rep 22
Difference of exhaust fitment e88 vs e82
Does anyone know the fitment differences for an exhaust for e82 on the e88. I am looking to get BMR exhaust but they don't know if it will fit the e88. Is there extra bracing in the back since it's a convertible
Thanks! |
11-04-2019, 12:14 PM | #2 |
Rep 1,078
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
I dont think so as Turner doesnt show diff systems for E82 or E88 search. But I know in the past on some BMW models, the coupe exhaust did not fit the convertible.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
11-04-2019, 12:31 PM | #3 |
1Addict
3237
Rep 7,897
Easiest would be to check the part number for the axleback on realoem.
11-04-2019, 12:48 PM | #4 |
Rep 22
it seems the exhaust part#s are identical. Just can't tell if there is extra bracing that would get in the way of a larger 3.5inch exhaust. Real oem doesn't seem to just show the underside x-braces (or i am horrible at finding it)
11-04-2019, 02:58 PM | #5 |
Rep 654
There is bracing in back on E88. Don't have a clue how/if it would interfere with aftermarket exhaust though I do have Dinan Axle and braces are forward of that.
11-04-2019, 07:04 PM | #6 |
Rep 33
E88 is different at cross brace by having the pipe slightly flattened so it goes over top of brace without hitting it. I switched my original exhaust for a 1m and had to have this done. If you go under car you should be able to see how pipe has a flat spot.
11-04-2019, 07:16 PM | #7 |
Rep 22
There are convertible 1m??
11-04-2019, 07:17 PM | #8 | |
Rep 22
11-04-2019, 07:28 PM | #9 |
1Addict
3237
Rep 7,897
3.5" exhaust basically doesn't fit either. It will take fiddling no matter what unless you have an oval cross section made
11-04-2019, 09:58 PM | #10 |
Rep 187
It won't fit.
I was under the car over the weekend looking at the e88 exhaust. The rear bracing is extremely close to the exhaust piping. I wanted to sleeve the middle resonator but because of the bracing it blocked me from just dropping the rear muffler back section to access the middle resonator. |
11-04-2019, 10:00 PM | #11 | |
Rep 22
