02-24-2009, 04:40 PM | #1 |
Bimmerpost Resident Marijuana Consultant
448
Rep 3,197
Drives: 320i, 325xi, 335Xi, 335i, M3
Garage List 2010 BMW 335i [0.00]
2011 BMW X335i [0.00] 2006 BMW E90 325xi [0.00] 2011 BMW E90 335xi [4.00] 2011 BMW M3 E90 [7.00] 2006 E90 320i [0.00] |
Computer Help Needed- Vista related
long story short: my norton crashed my laptop. Destroyed the Disk.sys file. I removed the hard drive, put it in an encasing, and im trying to access my user files. it wont allow me to access my folder. how to bypass this?
i really need someones help with this..... i cant afford to loose my data.
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!" '06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi |
02-24-2009, 04:50 PM | #2 |
448
Rep 3,197
do you have a link to send me to give me a better idea of what that proceedure involves/how to do it?
02-24-2009, 04:57 PM | #4 |
448
Rep 3,197
02-24-2009, 05:00 PM | #5 | |
you know he kills little girls like you
388
Rep 892
http://www.ubuntu.com/getubuntu/download Boot from the livecd. Then, as root on the console or in a terminal, do Code:
#fdisk -l Next mount the ntfs partition. Code:
# mount -t ntfs -o ro /dev/hda1 /mnt Code:
# mkdir test # touch test/{a,b,c} # zip test.zip test/* adding: test/a (stored 0%) adding: test/b (stored 0%) adding: test/c (stored 0%) I'd only use this as a last resort though. There is more than likely a much friendlier vista-centric solution. I've used this procedure for friends when all else fails though. If nothing else works, PM me. |
02-24-2009, 05:13 PM | #6 |
448
Rep 3,197
well i just destroyed my western digital passport 320gb hdd case to remove the hard drive. i mounted vista x64 on it and i just loaded it up into my asus.... say a prayer for me!
02-24-2009, 05:18 PM | #7 |
Rep 386
Easy, should have just booted to safemode, turn off simple sharing.
Then change security permissions for that directory (for all administrators or your specific username, etc) and apply changes to all child directories. |
02-25-2009, 12:08 AM | #8 | |
448
Rep 3,197
but anyways, my diabolical plan worked out just fine.... didnt have to loose anything. thanks for your concern and assistance anmcguire!
02-25-2009, 08:10 AM | #9 | |
Careful, I Bite.....
153
Rep 504
Your account may have administrator privileges, but you are not the "Administrator". This is how you activate the Administrator account: 1. Logon to Vista using your usual account. 2. Launch the cmd prompt - Make sure you select, 'Run as administrator' 3. Net user administrator password 4. Net user administrator /active:yes 5. Switch User, or logoff 6. Logon as Administrator Password password (Your password may be different!) Once you have logged on as the Administrator, try accessing your files. |
02-25-2009, 06:46 PM | #10 |
Rep 459
Drives: E90 335i w/ZSP
What does turning off simple sharing achieve in this scenario?
