      12-21-2017, 09:13 PM   #1
HP Autosport
Drives: F80 M3
Clutchmasters BMW N54 N55 Clutches (OEM Fitment)
X250: Street
The FX250 System uses the Power Plus I Pressure Plate and a hybrid combination of Clutch Masters New Formula Button on one side and a heavy-duty Steel Back Organic friction lining on the other. This clutch is designed for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and have a spirited driving style. The FX250 clutch system has a higher holding capacity than a traditional full faced Kevlar without compromising the street friendly characteristics Clutch Masters is known for. *
FX350: Street/Race
The FX350 System uses the Power Plus I Pressure Plate with Clutch Masters New Formula Button disc. This clutch is designed for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and have a spirited driving style. The FX350 clutch system has a higher holding capacity than a segmented Kevlar lining without compromising the street friendly characteristic Clutch Masters is known for. For year’s enthusiast have had to compromise durability for drivability and vise versa, however with Clutch Masters New Formula button we have closed the gap between these two tradeoffs. *
FX400 - RACE/STREET
The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4 or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more streetable than solid or rigid designs. This disc is designed for long life, outstanding holding capacity, and rapid heat dissipation.
Warning: Due to the solid (no Marcel) friction rivet design, the FX400 disc engages very quickly and may chatter slightly in first and reverse. To help alleviate this problem, we only use premium ceramic friction material.
Starting at $805.50
http://www.hpashop.com/Clutchmasters...mw-e82-e9x.htm
      12-30-2017, 09:10 PM   #2
HP Autosport
Drives: F80 M3
Clutch Master clutches
      01-07-2018, 12:11 PM   #3
HP Autosport
Drives: F80 M3
We are your Santa Barbara / Ventura / Thousand Oaks / Santa Maria / San Luis Obispo local source for Clutch Master upgraded clutches and flywheels
www.hpashop.com
      01-31-2018, 09:31 PM   #4
HP Autosport
Drives: F80 M3
Clutchmaster clutches
www.hpashop.com
      02-09-2018, 03:26 PM   #5
HP Autosport
Drives: F80 M3
Looking for Clutchmaster clutches and live in Santa Barbara, Ventura or San Luis Obispo Counties? HP Autosport, Inc. is your local source.
We install everything we sell.
www.hpashop.com
      02-18-2018, 10:49 PM   #6
HP Autosport
Drives: F80 M3
bump
      02-28-2018, 10:10 PM   #7
HP Autosport
Drives: F80 M3
bump
      03-11-2018, 10:52 PM   #8
HP Autosport
Drives: F80 M3
bump
      03-20-2018, 07:18 PM   #9
HP Autosport
Drives: F80 M3
bump
      03-29-2018, 03:28 PM   #10
HP Autosport
Drives: F80 M3
$805.50!
www.hpashop.com
      09-15-2018, 10:37 PM   #11
HP Autosport
Drives: F80 M3
bump
      09-25-2018, 07:33 PM   #12
HP Autosport
Drives: F80 M3
bump
      10-06-2018, 12:15 AM   #13
HP Autosport
Drives: F80 M3
bump
      10-22-2018, 12:36 AM   #14
HP Autosport
Drives: F80 M3
bump
      10-31-2018, 07:27 PM   #15
HP Autosport
Drives: F80 M3
bump
      11-15-2018, 12:15 AM   #16
HP Autosport
Drives: F80 M3
bump
      11-25-2018, 07:42 PM   #17
HP Autosport
Drives: F80 M3
bump
      12-05-2018, 12:58 PM   #18
HP Autosport
Drives: F80 M3
upgraded clutch
      12-13-2018, 10:52 PM   #19
HP Autosport
Drives: F80 M3
bump
      12-23-2018, 09:10 PM   #20
HP Autosport
Drives: F80 M3
bump
      01-05-2019, 10:06 PM   #21
HP Autosport
Drives: F80 M3
bump
      01-14-2019, 09:49 PM   #22
HP Autosport
Drives: F80 M3
bump
Copyright ©2000 - 2021, vBulletin Solutions Inc.
