12-23-2014, 08:36 PM | #1 |
Rep 48
1m european light switch
Hey!
I'm looking into ordering the euro switch, this may be a dumb question but do our 1m's have fog lights? thanks |
12-24-2014, 10:33 AM | #4 | |
Rep 324
‘If it even looks like rain and you pretend to be Michael Schumacher in a 599 GTO, you’ll end up in a tree’ -Clarkson
12-24-2014, 05:35 PM | #5 |
Kind of a big deal
300
Rep 1,674
All is wired and even the bulb is present on NA 1Ms. Just remove 4 tiny latches underneath the blank space (that is in fact a factory disabled switch) and you're all set. If you need the fog light icon to be on the switch button, go for the euro switch.
09-17-2015, 05:58 PM | #8 | |
Rep 6,196
Is the dial to raise/lower the headlights? Does it work? |
09-18-2015, 02:30 AM | #12 | |
Kind of a big deal
300
Rep 1,674
In our HID equipped E82s, the height servos in the headlights are controlled by a level-sensor located near the front axle, so the dail is simply not operational. In halogen-light equipped (EU/ROW) 1Ms, these servos could be connected to the dial for manual control. |
09-18-2015, 02:41 AM | #13 | |
Rep 22,992
wooper
The above headlight switch pictured - is for a 125i(128i) or 118d/120d/120i with halogen headlights AND front fogs and rear fogs. On halogen equipped cars the height is adjusted manually. Dackel
09-18-2015, 02:53 AM | #14 |
Kind of a big deal
300
Rep 1,674
09-18-2015, 05:27 AM | #15 |
Kind of a big deal
300
Rep 1,674
Here's how you can connect common electrical gadgets to the currently non-functional front-fog-light switch:
Once you confirm that the headlight switch has a yellow/white-stripe wire connected at pin7 (this is a low current drive signal, see diagram), You can now connect and switch ~50W gadgets to either or both pin 3 and 37 of the FRM module (located at your utmost left toe while pushing the clutch). WDS12 E8x Front & Rear fog lights.pdf PS (WDS actually shows vertical aim - level sensors both at the front and rear axles) Last edited by eeghie; 09-18-2015 at 05:32 AM.. |
