      08-16-2015, 11:26 PM   #1
nachob
Canadian 1Ms TPMS Question
Dear Canadian 1M owners. I just bought a Canadian 1M and it doesn't have Tire Pressure Monitors, just plain rubber valves. I got a Tire Warning and thought maybe the owner removed them but I noticed a RESET decal in the door with the tire symbol that the US version did not have. Also the manual has instructions for both systems. The rotational old style flat sensors and the Tire Pressure Monitors that the US version had. What do you guys have?
      08-16-2015, 11:40 PM   #2
champignon
Disrupter
champignon's Avatar
Drives: 1M;Z3M Cp;135is Vert, 996TT
My (formerly from Toronto) 1M does not have the sensors in the tires. I believe that this system, which is the norm in the USA, is not required in Canada. Most of the world does not require the TPMS sensors in the tires, the US is an outlier in that regard.
Don't know what your particular problem is in this case but I would consider myself fortunate to not be burdened with the tire sensors, which in my experience malfunction more often than they provide useful information, and are a nuisance every time you change tires, for any reason.
      08-16-2015, 11:45 PM   #3
nachob
Ok that explains it then. Thanks Yes, there is a ticker that reminds you to reset the system after you change tires or pressures. It uses tire diameter to assume there is drop in pressure. The US system actually gave you which tire had a problem, etc. I must admit I like it better, but now I know it's normal. Thank you!!!! I can sleep now. One tire had about 6 more PSI than the other 3 and just have set it off.
      08-17-2015, 12:19 AM   #4
champignon
Disrupter
champignon's Avatar
Admittedly this is not with BMWs, but my former cars that have had an issue with the tires have simply lit up an idiot light and gave no indication which tire the system thought had a problem. On further examination no tire had a problem but the idiot light went off anyway.
My business partner's Audi has had TWO flat tires while I was a passenger in it, at different times. Neither time did the indication come on indicating that there was a tire problem, in spite of the installed TPMS sensors, rather the car started to just feel like it had a flat and in fact it did.
      08-17-2015, 06:04 PM   #5
Luca335
Luca335's Avatar
Drives: AW 1M
Could be your car is a stripper. I have tire sensors in all my tires and I had received warnings when the pressure was too low. Once it is fixed, I could reset and this is all done on the monitor. Mine is fully loaded with nav.
      08-17-2015, 07:19 PM   #6
1mm2
Drives: M2
http://www.1addicts.com/forums/showp...9&postcount=19
      08-18-2015, 08:18 AM   #7
MrRoboto
Drives: VO 1M
It's a different system on Canadian vehicles. It uses the ABS system.
      08-18-2015, 08:22 AM   #8
nachob
Yes. Figured it out. Thanks!
It has one advantage if you change wheels. No TPMS sensors needed.
      08-18-2015, 08:22 AM   #9
MightyMouseTech
MightyMouseTech's Avatar
4338
Exactly. Canadian 1ers don't have sensors, uses wheel speed from the ABS sensors.
BUT! You must reset the system every time you change tires, or adjust the tire pressure. If you have iDrive, it is in the Vehicle Information menu, or you can program a radio button to do it.
      08-18-2015, 04:38 PM   #10
IEDEI
Drives: L'Orange
2011 BMW 1M  [8.40]
off topic: I heard Canadian 1Ms are significantly slower than US cars...is this true?!
      08-18-2015, 05:00 PM   #11
champignon
Disrupter
champignon's Avatar
No, they are faster. When you are going 62, they are going 100.
      08-18-2015, 06:11 PM   #12
1mm2
Drives: M2
I only drive mine in the snow so I couldn't tell ya...
      08-20-2015, 08:46 AM   #13
MrRoboto
Drives: VO 1M
Opposite. The dense cold air up here makes our turbo cars faster. Natures intercooler.
      08-20-2015, 08:59 AM   #14
IEDEI
Drives: L'Orange
2011 BMW 1M  [8.40]
but I heard Canadian 1Ms are only 235hp instead of 335hp. is this true? :P
      08-20-2015, 09:38 AM   #15
MightyMouseTech
4338
The power level goes up and down with the price of oil.
#thanksharper
      08-20-2015, 10:50 AM   #16
nachob
Canadian horses play hockey and pull harder! : )
