03-29-2011, 04:33 AM | #1 |
aiming for 450.....
303
Rep 2,910
Unable to reset brake service light
Last weekend I went ahead and installed my new Cool Carbon pads, and sensors that I bought from BavAuto. Everything went well until I tried to reset the values using the BT scan tool. They reset on the system but not on the dash. I followed a couple of DIY's on here, E90post and N54tech, but still the brake light on the dash is still on and it shows on my Idrive that I have to service the brakes
I have also heard that if you don't use OEM sensors, you will have issues trying to reset the brake service count. Does anyone know if that is a true statement or has it happened to anyone? Any help would really be appreciated. Nick
"you're only done when you sell the car " |
03-30-2011, 09:54 AM | #2 | |
Rep 1,711
03-30-2011, 12:34 PM | #3 |
Rep 22,992
Nick, I asked my guys at the BMW Zentrum in Bamberg (Auto Hering). They said you will need new brake sensors. IF you drive too long with your old sensor and new brakes - you might need to go to a BMW dealer to get rid of the brake warning light on the dash. My guy said normaly you can just reset the brake pad light via the turn signal stalk like in my DIY thread.
DIY resetting service "due" lights… http://www.1addicts.com/forums/showthread.php?t=415111 Normally BMW only has one sensor per axle. ei one on the LF brake and one on the RR brake pads. I am not sure about on our 1er's though. I see on RealOEM the sensors are cheap at $25 each. It only shows one per acel too. M3 09 AND135I 11 are you sure there are four sensors??? Dackel |
03-30-2011, 03:16 PM | #4 |
aiming for 450.....
303
Rep 2,910
Got it fixed finally
The details: I went today to Lell BMW in Weiden and got the OEM sensors and put them on this evening. Afterwards, started the car and did the DIY for resetting the lights (http://www.1addicts.com/forums/showthread.php?t=415111) First try was a no go. Second attempt and now my brakes are reset The car is still going to the dealer on monday so they can do the mid brake lines because I am not a contortionist.
03-31-2011, 10:46 AM | #5 | |
Rep 1,711
