03-19-2013, 09:13 AM | #1 |
Joint Chiefs of Staff
4922
Rep 115,999
New - Low Temp Thermostat - LOWER OIL TEMPS
ONLY $59.00 Order Link http://www.n54tuning.com/index.php?_...&productId=125 Easily lower your engines operating temperature for maximum driving performance!! 135 335 535 N54 and N55 Motors Maintaining higher oil temperatures reduces emissions at the factory power levels but puts your engine cooling at a serious disadvantage at higher power levels. This simple device lowers your oil temperatures by bypassing the factory oil cooling thermostat and allowing oil to circulate through your oil cooler full time. The result is dramatically lower oil temperatures and more consistent engine performance. Engine oil warm-up time is only marginally increased. Installs in minutes and is fully reversible. Applications: 1 Series • 2008-2013 E82 Coupe 135i / 1M • 2008-2013 E88 Convertible 135i 3 Series • 2008-2011 E90 Sedan 335i / 335xi • 2008-2011 E91 Touring 335i / 335xi • 2008-2013 E92 Coupe 335i / 335xi • 2008-2013 E93 Convertible 335i / 335xi 5 Series • 2008-2009 E60 Sedan 535i / 535xi • 2008-2009 E61 Touring 535i / 535xi Please check to be sure you have a factory oil cooler on your vehicle before ordering. Low temperature thermostat upgrade location highlighted in yellow in the above photo. Vehicles without a factory oil cooler can not use this upgrade. Order Link http://www.n54tuning.com/index.php?_...&productId=125 |
06-17-2013, 02:21 PM | #6 |
4922
Rep 115,999
09-09-2013, 12:21 PM | #7 |
4922
Rep 115,999
11-21-2013, 08:38 PM | #8 |
4922
Rep 115,999
11-21-2013, 09:57 PM | #9 |
Rep 481
Just so you guys know... This is the cheapest way to get quality number from oil cooling. I use to pull 330-345 daily driving. With the oil thermostat swap I pull only 309 daily driving.
2008 BMW 135i ///MSport Alpine White / Taupe Leatherette Cobb 2+ Aggressive | BMS Intake | ER Charge Pipe + Tial Q | ER FMIC | RR Downpipe | RR Exhaust | RR OCC | KWV1 | Apex ARC-8 245/18/40, 275/18/35 |
02-16-2014, 04:27 PM | #10 |
4922
Rep 115,999
07-21-2015, 01:27 PM | #13 |
4922
Rep 115,999
09-06-2015, 07:39 AM | #14 |
4922
Rep 115,999
09-30-2015, 09:50 PM | #15 |
4922
Rep 115,999
10-04-2015, 07:16 AM | #16 |
4922
Rep 115,999
02-06-2016, 02:52 PM | #17 |
4922
Rep 115,999
02-12-2016, 01:48 PM | #18 |
4922
Rep 115,999
02-18-2016, 05:12 PM | #19 |
4922
Rep 115,999
02-28-2016, 07:34 AM | #20 |
4922
Rep 115,999
03-05-2016, 07:00 AM | #21 |
4922
Rep 115,999
03-10-2016, 11:39 AM | #22 |
4922
Rep 115,999
