09-10-2011, 01:24 PM | #1 |
Rep 638
LUX H8 V3's - adaptive headlight warning?
So I washed my car today and the adaptive headlight warning came on... I shut the car off and now its gone... Has anyone else had this issue? I'm thinking of just returning them if I keep having issues...
Current: 2022 M240i xDrive
Previous: 2018 440i xDrive, 2012 135i |
09-10-2011, 02:14 PM | #2 |
Rep 239
Check to see if the covers are on correctly and making a tight seal. Moisture is probably getting in. Are your headlights fogging up? Also could be due to the power adapter getting in the way.
09-10-2011, 03:04 PM | #3 |
Rep 638
They are as the dealer insured both sides were on correctly and making a tight seal when they replaced the headlight control module and stepper motor on the passenger side headlight due to the cover not been on correctly and making a tight seal and moisture damaged those 2 components... Do you think its still not on correctly and making a tight seal?
