      07-30-2018, 03:34 AM   #1
Speed Logic
Speed Logic's Avatar
Drives: B58, N54, N55, S55, S58, S63
Arrow ◄ SPEED LOGIC ► Modifications, Service & Installs for BMW N54/N55 (OC, LA, IE, SD)
SPEED LOGIC AUTOMOTIVE
625 W. Valencia Drive, Unit A
Fullerton, CA 92832
Phone or Text: (888) 564-4215
Email: info@speedlogicauto.com
Message: Send a Private Message
*By Appointment Only*
We want to give a warm welcome to the Bimmerpost community! We are a fully licensed automotive shop that specializes on the various BMW Turbo Engines (N54, N55, S55, S63, etc). Whether you may be looking for simple plug and play Bolt-Ons, a Turbo Upgrade, or complete Tuning solutions and packages; we can be sure to be able to help you with your needs. We have the resources and BMW specialty tools to get the job done correctly for all the services we offer. Thankfully our employees are car enthusiasts as well and can easily share insight and passion for the lifestyle. We work closely with many brands and vendors within the BMW community, continually staying informed of new product updates and releases. We are looking forward to working with fellow enthusiasts and serving the community!
As an official introduction to the community, we figured we would work out a few deals that many of you may need or want on your BMWs. All specials will require dropoff of the vehicle and include both Parts & Labor. We only use Genuine OEM BMW Parts for all services we perform (please note that #3 and #8 may include aftermarket performance parts). Please be sure to mention 1Addicts/Bimmerpost when contacting us for an appointment so we can sure to price the service accordingly. We are happy to package other items that are not listed, just be sure to reach out to us so we can accommodate for your specific needs. These are limited time specials and the prices will be subject to change at anytime!
*All special prices apply to 1 and 3 Series RWD vehicles - if you have another vehicle model please be sure to reach out to us directly for an estimate as the cost may be slightly additional*
#1 - Walnut Shell Blasting Service for N54 & N55 Vehicles (All models) including Replacement of OEM BMW Intake Manifold Gaskets during Service @ $250 (CLICK HERE)
#2 - Turbo Replacement with OEM Turbos for N54 Vehicles including Installation Kit, Fluids, Labor @ $3100
#3 - Pure Stage 2 Turbo Upgrades for N54, N55 Vehicles including Installation Kit, Fluids, Labor @ Contact for Lowest price in SoCal (CLICK HERE)
#4 - Clutch/Flywheel Replacement for N54, N55 Vehicles @ $500 for Labor if Parts purchased directly through us
#5 - Oil Pan Gasket Replacement for N52, N54, N55 Vehicles @ $750
#6 - Valve Cover Gasket Replacement for N54, N55 Vehicles @ $380
#7 - Oil Filter Housing or Oil Cooler Gasket Replacement for N52, N54, N55 Vehicles $400, or $550 for Both
#8 - Spark Plugs and Coil Pack Replacement with OEM Bosch for N54 Vehicles @ $430
#9 - BMW ECU or DME Unlock for N55 Vehicles with Late model 2012+ @ $300
#10 - Waterpump and Thermostat Replacement for N52, N54, N55 Vehicles @ $800
We are proud to offer a wide variety of services to accomodate for your BMW needs. All services we offer are always performed by qualified technicians using specialized BMW tools. Each service includes a full 1-year warranty on Parts & Labor to give each client full peace of mind. If there are any services or items unlisted that you may be interested in please feel free to reach out directly and we would be happy to accomodate.
  • BRAKES
  • Brake Pads & Wear Sensor Replacement
  • Brake Rotors Replacement
  • Stainless Steel Brake Line Installation
  • Big Brake Kit (BBK) Installation
  • MAINTANANCE
  • Walnut Shell Blasting Cleaning Service
  • Vacuum Line Replacement
  • Belt, Belt Tensioner & Idler Pulley Replacement
  • Waterpump and/or Thermostat Replacement
  • Starter Replacement
  • Clutch & Flywheel Replacement
  • Turbo Replacement (Stock Turbos, Upgraded Twin Turbos, Single Turbos, etc)
  • IGNITION COMPONENTS
  • Spark Plug Replacement
  • Coil Pack Replacement
  • Fuel Injector Replacement
  • GASKETS & SEALS
  • Oil Filter Housing Gasket Replacement
  • Oil Cooler Gasket & O-Rings Replacement
  • Valve Cover Gasket Replacement
  • Oil Pan Gasket Replacement
  • Front & Rear Main Seal Replacement
  • FLUIDS
  • Oil & Oil Filter Change
  • Brake Fluid Flush
  • Coolant Flush
  • Power Steering Fluid Flush
  • Automatic Transmission Fluid, Pan, Mechatronic Sleeve Replacement
  • Manual Transmission Fluid Replacement
  • Differential Fluid Flush
  • SUSPENSION & DRIVETRAIN
  • Spring Installation
  • Coilover Installation
  • Differential Installation
  • Control Arm Installation
  • Rear Subframe Bushing Installation
  • Differential Bushing Installation
  • PERFORMANCE BOLT-ON INSTALLS
  • Intake Installation
  • Chargepipe Installation
  • Front Mount Intercooler (FMIC) Installation
  • Turbo Inlet Installation
  • Exhaust Installation
  • Turbo Upgrades (Stock Turbo, Upgraded Turbos, or Single Turbo Kit)
  • Fuel System Upgrades (Available for all power goals)
  • Oil Cooling Upgrades
  • Aluminum Radiator Upgrades
  • OTHER
  • Engine Replacement
  • Transmission Replacement
  • Automatic to Manual Transmission Swap
  • Tapping Intake Manifold for 1/4" Nipple
  • Oil Catch Can Installation
  • MHD Tune or Backend Flash Installation
  • Coding/Programming of any type
  • Alpina Transmission Flash
  • xHP Transmission Flash
  • Contact us directly for any other needs!
We offer many brands and products in addition to the brands below. We specialize in BMW aftermarket products and are happy to source anything you may need for your vehicle or build. We can also provide OEM BMW Parts for Service & Repairs, Retrofits, and Cosmetic Upgrades. Please feel free to ask us for any specific requests and we are happy to accomodate
Hours of Operation: Mon-Sun 10am-5pm (PST)
Availability: *By Appointment Only*
Website: http://www.speedlogicauto.com
Instagram: @speedlogicauto
      07-30-2018, 05:58 AM   #2
Speed Logic
We are proud to announce that we are running a special for the Pure Turbos Stage 2 product line of Turbo upgrades. They offer a wide variety of Turbo upgrades that are easily able to hit the power goals for most N54 & N55 builds. We work closely with Pure Turbos since they are local to Southern California and provide high quality wear-matched and balanced components. They have a reputation for building the most proven turbo upgrades in the industry. In addition, by joining forces with Pure Turbos we are able to offer these Upgrades installed at a price that no other shop in Southern California can compete with due to our strong relationship. Come find out why these turbos have been making all the buzz within our community!
INCLUDED STANDARD ON ALL TURBO INSTALLS:
-Pure Turbo Upgraded Turbo(s)
-Motul 8100 X-Cess 5w40 Oil (Standard for Upgraded Turbos)
-OEM Turbo Installation Kit (All required Gaskets, Seals, O-rings, etc)
-OEM BMW Oil Filter
-OEM BMW Coolant & Distilled Water
-Full 1-year Warranty on all Parts & Labor
PRICING: Our prices for these Upgrades simply cannot be beat and we stand by it. We offer a Price Match guarantee and will be happy to beat other local and reputable shops. We are willing to do what it takes to earn your business. If you have found a cheaper deal or "special" elsewhere for these Turbos, please reach out and we will be sure to beat any competitor pricing as a means to earn your business. For accurate pricing and estimates - please reach out to us directly through Direct Message, Phone, or Email. Our pricing is so low that we are unable to share it publicly. Please be sure to mention E90post/Bimmerpost when contacting us so we can be sure to price the Turbos accordingly. Special pricing applies to all 1 and 3 Series RWD Vehicles - please inquire about other Models directly. These are limited time specials and the prices will be subject to change at anytime!
N54 VEHICLES:
Package 1 - Pure Turbos N54 Stage 2 DD Model (Daily Driver) - which are capable of ~600hp @ $3095
Package 2 - Pure Turbos N54 Stage 2 HF Model (High Flow) - which are capable of ~700hp @ $3595
Package 3 - Pure Turbos N54 Stage 2 Newest Model (Pure600) - which are capable of ~600hp @ $2200
Package Add-Ons:
(+INLETS) - We highly recommend Upgraded Turbo Inlets during Turbo Installation
(+OUTLETS) - We also recommend Upgraded Turbo Outlets during Turbo Installation
N55 VEHICLES:
Package 1 - Pure Turbos N55 Stage 2 - which is capable of ~550hp @ $2500
Package Add-ons:
(+INLET) We recommend to consider a Turbo Inlet Upgrade during Turbo Installation
(+DV) - We recommend to consider a DV Upgrade during Turbo Installation
Contact us through Direct Message, Phone, or Email for accurate pricing. Please be sure to mention Bimmerpost and include the following information with any inquiry:
-Year and Model Vehicle (ex: 2009 BMW 335i)
-Turbo Package of Interest (ex: N54 Package 1 + Inlets)
      08-13-2018, 11:26 AM   #3
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Would the clutch and flywheel install apply to DCT cars as well?
      08-13-2018, 12:58 PM   #4
Speed Logic
Unfortunately, the current special only applies to Manual or 6MT Vehicles.
With that said, we will reach out via message so please check your PM box. We would be happy to assist you with an M4 Flywheel Replacement if you are looking for the help. We have done many in the past for DCT cars running big power.
      08-14-2018, 02:59 AM   #5
Speed Logic
Arrow ◄ SPEED LOGIC ► Pure Turbos Upgrade for ALL N54/N55 Vehicles *Lowest price in SoCal*
Fullerton, CA 92832
-OEM BMW Oil Filter
N54 VEHICLES:
Package Add-Ons:
N55 VEHICLES:
Package Add-ons:
      08-30-2018, 04:23 AM   #6
Speed Logic
Arrow ◄ SPEED LOGIC ► Walnut Shell Blasting for BMW N54 and N55 Engines @ $200 *SPECIAL*
Fullerton, CA 92832
What is Walnut Shell Blasting?
Walnut Shell Blasting involves "shooting" a mixture of compressed air and Walnut Shells into the Intake Ports to clean carbon deposits and buildup that occurs slowly over time on the Intake Valves. It is considered a scheduled maintenance service that is required only on Engines that have Fuel systems known as Direct Injection (or DI). Many vehicle makes and manufacturers have modern vehicles that are Direct Injection which would also require this cleaning at a specified interval, not just BMWs.
Modern day BMW's all use Direct Injection Fuel Systems - which as the name implies allows fuel to be “directly injected” into the cylinder combustion chamber. This enables the vehicle to be much more gas efficient, make more power with lower octane fuels, and allows manufacturers to meet efficiency requirements. While it provides many benefits, one specific drawback of the Direct Injection style Fuel system is that the Intake Valves are not cleaned with fuel or detergents. It creates the need for a Walnut Shell Blasting cleaning as a scheduled maintenance which should be performed regularly. If you have a Stock or Tuned vehicle and this service has yet to be completed - it would certainly be a good idea to get it taken care of!
How Often Do I Need Walnut Shell Blasting?
The service should be completed based on a balance of how the car was driven as well as modifications during this time. If the vehicle is completely stock, then the Walnut Shell Blasting Service should be completed as a scheduled maintenance service every 50K miles. With elevated heat cycling and levels with a modified or tuned vehicle - the need for the scheduled maintenance service becomes more important to be completed every 30-40K miles depending on use within this time. Many owners have more mileage than these recommendations, previous owners responsible for a large amount of mileage, or even drive the vehicles lightly. Any of these circumstances may call for slightly different intervals and if you have any specific questions in this regard please feel free to reach out to us directly and ask. We are happy to answer any questions specific to your application.
Which Vehicles Need Walnut Shell Blasting?
-BMW 135i w/ N54 Engine (2008-2010)
-BMW 135i/135is w/ N55 Engine (2011-2013)
-BMW 335i/335xi w/ N54 Engine (2007-2010)
-BMW 335is w/ N54 Engine (2011-2013)
-BMW 335i/335xi w/ N55 Engine (2011-2013)
-BMW 535i/535xi w/ N54 Engine (2008-2010)
-BMW Z4 35is w/ N54 Engine (2009-2016)
-BMW X1 xDrive 35is w/ N55 Engine (2011-2016)
-BMW X6 xDrive 35is w/ N54 Engine (2009-2016)
What are Symptoms of a Vehicle that Requires a Walnut Shell Blasting?
-Car is due for scheduled maintanance cleaning (Every ~30-40K Tuned and Every 50K Stock)
-Vehicle has Misfires in One or more Cylinders
-Rough Idle (May occur during Idle or Cold Start)
-Car has sluggish response overall
What is the Cost of Walnut Shell Blasting?
The Walnut Shell Blasting Service costs $250 and includes Replacement of the OEM BMW Intake Manifold Gaskets during the service
CURRENT SPECIAL: $200 out the door for a Limited time!
What is the Difference between Speed Logic and the Other Shops offering Walnut Shell Blasting?
Experience and Quality. With regard to Experience, we have performed over 500+ Walnut Shell Blastings for Enthusiasts within the Southern California area and beyond. Not a single shop can complete with the number of cleaning we have completed for locals. On the other hand, don't let the number of cars we have Walnut Shell Blasted fool you. We take our time and treat every car as if it is our own - during cleaning and also careful reassembly. We simply won't reassemble the car unless it looks like one of the videos on this post. And we mean it! We have hundreds of videos we are happy to share to prove this is not an anomaly. Every single car that comes through our doors for this service gets cleaned with this expectation. Lastly, since we didn't answer the question directly - go ahead and answer it yourself by taking a look or asking for end results of those Other Shops? We promise our work is unmatched by any other Shop in this regard - not to mention we have the videos to PROVE it and are happy to do so
We want to give a warm welcome to the 1Addicts community! We are a fully licensed automotive shop that specializes on the various BMW Turbo Engines (N54, N55, S55, S63, etc). Whether you may be looking for simple plug and play Bolt-Ons, a Turbo Upgrade, or complete Tuning solutions and packages; we can be sure to be able to help you with your needs. We have the resources and BMW specialty tools to get the job done correctly for all the services we offer. Thankfully our employees are car enthusiasts as well and can easily share insight and passion for the lifestyle. We work closely with many brands and vendors within the BMW community, continually staying informed of new product updates and releases. We are looking forward to working with fellow enthusiasts and serving the community!
Contact us through Direct Message, Phone, or Email to setup an appointment. Please be sure to mention Bimmerpost to recieve special pricing. We will need the car dropped off for this special pricing. We generally need the car dropped off for a minimum of 4 hours or about half the day. Depending on workloads we may need the car for longer - but will always be able to provide a same day or 1-day turn around for this service. For any questions, please inquire directly!
      08-30-2018, 04:24 AM   #7
Speed Logic
Do you have any Videos to better explain the Before & After Results?
Yeah, we sure do! We are confident in our results on every car that gets this service performed in our Shop. Here are some Before & After Video Results of a Client with a 2008 BMW 335i with the N54 Engine. This vehicle had 60K on a Stock Vehicle prior to this service being performed. The After results clearly show the Intake Valves and the dramatic difference with the Walnut Shell Blasting Service. We see this here visually, but this is also felt with power, response and gas mileage.
Before Cleaning:
After Cleaning:
      11-03-2018, 05:48 PM   #8
pepper135I
pepper135I's Avatar
Drives: N54 6mt
You made a night and day difference on my car! Thank you so much!
      11-06-2018, 03:19 PM   #9
Speed Logic
Bump!
      12-06-2018, 03:57 PM   #10
Speed Logic
Bump!
      12-26-2018, 05:17 PM   #11
pepper135I
pepper135I's Avatar
Drives: N54 6mt
Bump for the best !
      05-16-2019, 01:54 PM   #12
Speed Logic
Bump!
      05-30-2019, 03:30 PM   #13
Speed Logic
Bump!
      06-06-2019, 03:38 PM   #14
Speed Logic
Bump!
      06-13-2019, 05:01 PM   #15
Speed Logic
Bump!
      06-14-2019, 07:19 PM   #16
Speed Logic
Bump!
      06-19-2019, 04:09 PM   #17
Speed Logic
Bump!
      07-29-2019, 06:30 PM   #18
Speed Logic
Bump!
      08-14-2019, 02:00 PM   #19
Speed Logic
Bump!
      09-05-2019, 05:28 PM   #20
Speed Logic
Bump!
      09-09-2019, 03:57 PM   #21
Speed Logic
Bump!
      09-18-2019, 04:56 PM   #22
Speed Logic
Bump!
135i, 135is, 335i, 335is, 335xi, blasting, california, carbon cleaning, n54, n55, pure turbo, pure turbos, socal, socal. intake valves, southern california, special, stage 2, upgraded turbos, walnut shell blasting, walnut shells
