05-11-2024, 05:23 PM | #1 |
Rep 2
2009 135i (1m clone) 6 speed
2009 BMW 135i M sport (1m clone), 6 speed manual transmission. 67k miles, clean title. Runs and drives very well and doesn't have any of the notorious n54 problems. Shifts smoothly and suspension feels very tight. OEM 1m fenders, oem 1m fender liners, oem 1m front bumper, oem 1m rear bumper, jay meadow rear flares. Quaife limited slip differential, f30 big brake upgrade. Have 2 inch stack of receipts for all maintenance performed. Comes with 2 keys, stock airbox, stock charge pipe, stock diverter valves. Notable Recent Maintenance: Fuel tank breather valve (65k Miles) Evap hose 65k Miles) Alignment (65k Miles) Water Pump (58k Miles) Index 12 Injectors (58k Miles) Spark Plugs (58k Miles) Coil Packs (58k Miles) O2 Sensors (58k Miles) Both turbochargers replaced by BMW under extended warranty Notable modifications Quaife Limited-slip Differential Koni Shocks Dinan camber plates F30 Big Brake Kit M3 Control Arms Rogue Engineering Toe Arms Dinan Rear Control Arms M3 Subframe Bushings OEM 1M Front Bumper OEM 1M Rear Bumper OEM 1M Front Fenders Jay Meadows Fiberglass Rear Flares MHD Stage 1(can flash back to stock with your smart phone) Dinan rear sway bar Topspeed 1m muffler BMS intake BMS chargepipe BMW short shift kit Known flaws: Rock chips on the front bumper Rear wheels sometimes rub on the plastic fender liner if you have 4 passengers in the car and a full tank of gas Asking $21,000. This is an excellent opportunity to have a well sorted 135i with many of the 1M benefits without the cost. Email: bik2798@gmail.com for fastest response. Car is located in Richmond, California. |
05-15-2024, 08:52 PM | #4 |
Rep 2
Update, sale is pending. Will update if the deal falls through. Thank you.
tracer bullet3441.00 |
