      02-27-2020, 06:00 PM   #1
RestoreItSteve
Drives: BMW 1M Valencia Orange
Just got my 1M and found codes 0030FF + 0029F2
Hi everyone,
2012
WBSUR91090VS64193
Steve from Restore It on YouTube here. I know my E30's but I really don't know modern cars well at all.
I've just picked up my first 1M, and modern BMW for that matter.
I've used the Carly ODB 2 reader and app to check the car and this was the result.
Engine:
Size:  47.4 KB Name:  87902836_198390217941564_4209684552764882944_n.jpg
So I've been doing some research into the 0030FF code and I'm going to do all of the necessary checks tomorrow in regards to the vacuums lines etc..
0029F2 is said to possibly be the HPFP, but is there anything I should look for first?
Is there a way I can test the HPFP?
There is a myriad of other unimportant issues on the list as well. If anyone has any insight into any of those I would really appreciate it.
Other issues:
Size:  20.9 KBName:  87796693_551526775719606_6681631539500941312_n.jpg
Size:  18.7 KBName:  87796707_520437232010420_1999670978413592576_n.jpg
Any advice, links or suggestions welcome.
Thanks.
      02-27-2020, 10:56 PM   #2
10"
10"'s Avatar
Drives: orange BMW 1M.
post on 1M Owners Society on FB. somebody there will know!
congratulations on the 1M!
don't read this. too late...
      02-28-2020, 11:26 AM   #3
stormchaser7
stormchaser7's Avatar
223
Drives: BMW 1M
High pressure fuel pump had been known to fail and will be covered under an extended warranty bulletin. 30FF is related to Boost Pressure. Check your plastic charge pipe. Known area of failure. Best to replace with metal charge pipe. Lots of aftermarket ones available. Combox error is related to Bluetooth module in the trunk.
Follow your dream car!
      02-28-2020, 11:43 AM   #4
blackmist222777
blackmist222777's Avatar
Drives: 2011 BMW 1M
agreed. A lot of owners proactively replaced their cheapie plastic charge pipe with aftermarket aluminum ones. Thats what I did and have had zero issues.
2023 G80 M3
2020 F87 M2C
2011 E82 BMW 1M Series Coupe
Check me out at Point.Shift.Drive (YouTube)
0029f2, 0030ff, boost, boost pressure, fuel, fuel pressure, low, pressure
