04-06-2023, 09:47 AM | #1 |
Rep 1
N52 replacing Disa
Hello is there someone who replaced original Disa valve (both) with OEM valves than OE? Thanks a Lot and wich brand. but also CCV and solenoid.
04-06-2023, 06:42 PM | #2 |
J
367
Rep 697
Drives: BMW 128i
Everyone is going to tell you to only use OEM parts.
I agree. That being said, I'd say just look at the reviews. I know there are a ton on the eBay and Amazon. When stuff doesn't work, ppl complain about it. That's literally what the internet is for. Find the one with the least complaints. It'll probably be the OEM one. |
04-07-2023, 08:47 AM | #3 |
Rep 27
Vanos Solenoid:
I once bought Vaico which is normally a good brand. But they failed right out of the box and made it even worse. Also cleaning didnīt work. Go with original ones and you should be fine. Disa: I installed Bavarian Autosport without any issues. https://www.ecstuning.com/b-bavarian...617560538~bav/ https://www.ecstuning.com/b-bavarian...617579114~bav/ Last edited by Pistolpete2911; 04-07-2023 at 08:52 AM.. |
04-07-2023, 12:26 PM | #4 |
Rep 2,276
I believe 11 61 7 560 538 is the larger unit and is accessible on the outside of the manifold. Can it be replaced without removing the manifold?
A number of you tube videos show how to bench test them. |
04-30-2023, 05:04 PM | #5 | |
Rep 29
You can also replace the small inner DISA by removing the alternator. Much quicker than removing intake manifold. |
mkeiser435.50 NorthernDancer849.50 |
05-02-2023, 03:15 PM | #7 |
Rep 29
