      08-21-2018, 12:00 AM   #1
AndyW
AndyW's Avatar
Engine and Transmission mounts...what did you upgrade to and why?
Looking at getting new engine mounts and transmission mounts. Not ready to go solid...this car still gets driven on the street quite a bit, but figure I should upgrade beyond factory if I am doing it. TIA!
Best,
Andy
      08-22-2018, 11:45 AM   #2
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
I ended up buying Revshift engine mounts. Have yet to install.
Installed Rogue transmission mounts and found them to be perfect for a street car. No real NVH increase, but definite improvement in shift quality.
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
AndyW672.00
      08-22-2018, 04:35 PM   #3
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
I'm thinking about doing the RE ones. I have E46 M3 mounts now but I want to tighten up the transmission even more after driving a friend's Z4 M, not sure I'll get it quite that good though lol.
      08-22-2018, 07:24 PM   #4
berns
Drives: '07 E90 335i
AKG 90A motor mounts and trans mounts. Necessary for a chassis mounted shifter. Definitely feel them. Beautiful pieces and they work.
AndyW672.00
      08-23-2018, 07:15 AM   #5
bbnks2
Drives: 135i N55
The shiftier carrier itself also has a lot of play in it. Consider getting delrin bushings for the two front bushings and figuring out a way to stiffen the rear mount. I filled mine with liquid poly which usually doesn't last long.
      08-23-2018, 10:47 AM   #6
chris82
chris82's Avatar
Drives: 128i
can you explain a little more? What's the shifter carrier? How difficult to install bushings?
      08-23-2018, 10:56 AM   #7
bbnks2
Drives: 135i N55
Part number 2 can be replaced with something like this: https://www.turnermotorsport.com/p-3...it-ultra-oval/
Or this: https://www.ecstuning.com/b-ecs-part...it/2511-002~3/
Part number 5 doesn't have any "upgrade" part as far as I know but it is very soft and has a lot of play in it. There is a groove through the middle that almost makes the bushings hollow similar to the rear sub-frame bushings. I filled that groove with Poly to stiffen the bushing and it made a pretty noticeable difference.
      08-23-2018, 11:00 AM   #8
chris82
chris82's Avatar
Drives: 128i
Would the driveshaft need to be removed for this install?
      08-23-2018, 11:01 AM   #9
chris82
chris82's Avatar
Drives: 128i
What about this?
https://store.garagistic.com/Rear-Po...39-25111222015
      08-23-2018, 11:04 AM   #10
bbnks2
Drives: 135i N55
Never seen it before but now I've got to order one lol... I personally believe the rear bushing contributes much more to the play than the front bushings. The front pin bushings are made from pretty solid rubber and can't be deflecting much. The rear bushings is very easy to deflect due to the void in it.
      08-23-2018, 11:11 AM   #11
chris82
chris82's Avatar
Drives: 128i
How is the install? I love these low cost bushing upgrades
F13.KENN603.50
      08-23-2018, 11:20 AM   #12
bbnks2
Drives: 135i N55
It's doable with small hands. You can bend the heat shield back and reach up behind the transmission. Look at the install instructions for a DSSR if you want to get an idea of what you would be looking at.
If you undo the transmission mounts you can pull the trans down to gain more room. The two bolts that hold that rear bushing in are actually a big pain. I had to use a wrench with very small turns since a socket wouldn't fit over the top of the bolt. It is doable though. It will probably be blind. Once you undo the rear bushing the shifter carrier will be free to droop and you can slide the bushing off.
      08-24-2018, 04:09 PM   #13
TZANIDO777
Drives: 2011 E82 135i, 2015 F15 X5 35D
2020 BMW X5 40i  [0.00]
2011 BMW 135i  [0.00]
Turner solid engine and trans mounts. Raised idle to 1000 rpm and all good.
      08-24-2018, 09:03 PM   #14
AndyW
AndyW's Avatar
All these shifter posts just make me glad to have a DCT!
Best,
Andy
      07-04-2019, 05:52 PM   #15
AndyW
AndyW's Avatar
Reviving this thread as I deferred doing this last year but ECS is having a sale so...I'll ask the question a different way...is there any real performance reason to get stiffer mounts if you have a DCT? Car is almost at 100K so it's about time to replace motor and trans mounts anyway. Just need to decide stock or aftermarket.
Best,
Andy
      10-08-2019, 06:59 PM   #16
chris_flies
Sideways and Smiling
chris_flies's Avatar
3027
Drives: In Exuberance
Manual 128i, but I did E46 M3 trans mounts and AKG engine mounts. Thinking back, I’d do 034Motorsports engine mounts or new OEM ones, these AKG ones are brutal in the best way possible.
AndyW672.00
      10-14-2019, 05:46 AM   #17
135
Here's my update in the M3 forum:
Originally Posted by 135 View Post
Just an update to my previous posts, I ended up getting the Turner Motorsport solid engine, transmission and diff mounts.
I haven't installed the solid diff mounts yet because that was going to be an involved process but will install them in a few months. I don't expect much additional NVH compared to the current rear end setup.
I installed the solid engine and trans mounts and immediately noticed increased NVH. Since there were a lot of other changes made at the same time, I decided to remove just the trans mounts and revert back to OE trans mounts - NVH gone. This was just to ensure it was the trans mounts and not something else that contributed to the increased NVH. I didn't mind the increased NVH so the plan will be to re-install the solid trans mounts at the end of the year.
The solid engine mounts have been in for over six months and I have no complaints at all with them. Maybe a very slight (to me) increase in NVH but nothing at all that concerns me.
houtan707.00
AndyW672.00
      10-17-2019, 10:05 PM   #18
ajsmithvmi
Professional Hack
Drives: 2009 135i
DO NOT DO 034 MOUNTS. Mine came apart after maybe 5000 miles.
For my swap I'm doing the turner solid mounts.
MCS 1WNR Dampers | Ground Control Camber Plates | E90 M3 front control arms| E90 M3 front tension arm w/ Turner monoball bearings | E90 M3 Steering rack conversion | SPL Adjustable Outer Tie Rod Ends | M3 Rear Camber Arms | SPL Adjustable Rear Toe Arms | M3 Front Caliper Conversion | 275/35/18 Toyo RA1s | 18x9.5ET22 Apex EC-7’s | mFactory LSD | AIM EVO4S with GS Dash | New for 2020: LS1 Swap!
spidertri399.00
lab_rat394.50
AndyW672.00
      10-18-2019, 09:30 AM   #19
spidertri
spidertri's Avatar
Drives: 11 128i 6MT Sport
2011 BMW 128i  [0.00]
034 mounts seem like a great option but reading your experience and a few others is a big red flag. How did they come apart? Did 034 make it right? How long ago did you buy the mounts and install them?
I wonder if they have revised the design at all to address these issues.
11 128i slicktop
13 WK2
19 Alltrack S
      10-18-2019, 11:30 AM   #20
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
I did the softer of the two options for the Turner Engine Mounts. Did increase NVH a bit, livable for sure, but it's not the ultra smooth GT car that some people may be after. Specifically at idle the car vibrates a bit more.
AndyW672.00
      10-18-2019, 12:24 PM   #21
ajsmithvmi
Professional Hack
Drives: 2009 135i
They were installed probably a year ago by a local shop - at the time I didn't have a garage or equipment to do it myself.
I discovered the issue when I pulled the engine and one of the mounts came out in two pieces (the lower plastic disc had separated from the rest of the mount housing.)
I didn't bother going back to get it fixed/replaced because the shop is now an hour away...and my car currently has no engine.
      05-07-2020, 06:15 AM   #22
135
Further update:
I finally had the solid diff mounts installed. No noticeable increase in NVH but I already had a solid diff brace installed, which at the time did make diff whine noticeable, which is something I've learned to live with and ignore.
Summary of installed solid mounts:
  • Sold rear subframe bushes (RSB) - no increase in NVH.
  • Solid diff mounts - no noticeable increase in NVH with an already installed sold diff brace. There would likely be some increased diff whine without a sold diff brace but would be bearable.
  • Solid engine mounts - very minor (easily bearable) increase to NVH. Becomes unnoticeable.
  • Solid trans mounts - introduces considerable NVH but just bearable.
YMMV depending on your tolerance level for NVH.
AndyW672.00
