03-11-2021, 04:44 PM | #1 |
Rep 51
Akrapovic Axleback for 1M
As it says in the title, looking for just the Akrapovic axleback for 1M. Based in Southern California but open to shipping too. Thanks. |
07-16-2021, 09:09 PM | #2 |
MSgt (ret)
561
Rep 2,116
Drives: VO 1M #739/740
I have one I took off my 1m but no longer have fob/switch to change exhaust from inside cab…. I just wired it open… shipping from Alabama?
07-18-2021, 09:13 PM | #3 |
Rep 429
If you get the wiring diagram for 135i, you can wire it to open the same as on that car (uses same solenoid) and will also open when you press M button (opens based on vanos position). This is way down my todo list, but will eventually write it up.
07-21-2021, 12:24 AM | #4 |
Rep 99
07-22-2021, 10:40 PM | #5 |
MSgt (ret)
561
Rep 2,116
Esker, thx, but let's see if OP is interested as this is their thread… I'll ping you when/if they decline
07-22-2021, 10:40 PM | #6 |
Rep 51
07-22-2021, 10:44 PM | #7 | |
MSgt (ret)
561
Rep 2,116
Cogitoergosum34.00 |
07-22-2021, 10:57 PM | #8 |
MSgt (ret)
561
Rep 2,116
See attached photo for complete kit. Overall in great condition, the CF tips need reconditioning but everything else is clean and straight.
02-03-2022, 06:58 PM | #11 | |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
10-14-2022, 07:54 PM | #12 |
Rep 429
I haven't tried this yet, but looks like you might just need to tap power from somewhere (OE is fuse F17, which could be tapped at fuel leak module) and run the ground signal from pin 5 on one of the DME plugs. I'm also fairly certain that the vacuum source is the capped off tee fitting between pump and brake booster
