      03-14-2026, 12:08 PM   #1
Artdnj
Artdnj's Avatar
Drives: 2023 X3 X30i
oil pan gasket
2011 128i conv, 78k not a daily
Low level leak but looking to address it. Unfortunately I cannot do the work myself so looking at my options in the near future.
When getting it done would you do the motor mounts, water pump and anything else that frequently fails and if so does that increase the cost by a lot?
      03-15-2026, 08:38 AM   #2
mkeiser
Drives: e82 128i 6mt m sport
Yeah engine mounts, water pump, and thermostat. All of those are easier to get at while the subframe is lowered.
If a mechanic does you a solid it shouldn't add too much labor to bundle them all together. If mechanic charges book time for each job then it will be expensive.
Artdnj490.00
      03-15-2026, 10:42 AM   #3
Artdnj
Artdnj's Avatar
Good advice, thx. It's not leaking terribly, in fact it's my daughter's car and she uses it sparingly but I'm anal and like things fixed. Deale will quote me April 1 when I'm there for an oil change but I know that will be $$$. I also use a independent but they aren't cheap either.
SOmeone referred me to a local mechanic but after watching videos of the procedure I am not sure someone who doesn't work on BMW's regularly can do it right, maybe I'm wrong.
