      09-17-2018, 01:00 AM   #1
godzilla-1
Drives: 1M Coupe
Harness bars and mounts
I have just installed a custom set of recaro sportster seats and the next job is to install my harnesses. Any ideas ? I can't see anything listed for our car anymore.
AFE induction, N55 midpipe, ER chargepipe, forge recircs, Berger OCC, Berger CDV, "West Tuning" Remap 450bhp, 519lb torque, Bilstein clubsports, BMW Performance front grilles, boot lip and steering wheel, IND repeaters, lightweight front splitter and carbon diffuser, PSD titanium stud+nut conversion, 10mm spacers, AR01 semi-slicks, RS29 pads.
      09-29-2018, 04:43 AM   #2
godzilla-1
Drives: 1M Coupe
Still not found anything regarding harness bars for 1M
      09-30-2018, 10:42 AM   #3
Tinsta
Tinsta's Avatar
189
Drives: 1CSL
Depends if your after a halfcage which GRID (in the uk) can do a boltin version.
You can actually make up an harness bar to go just behind the rear seats, behind the side carpet panels there are 2 brackets already inplace, and just need a bar welded to the endplates.
Pic of one had made up a few years back
      10-04-2018, 05:45 AM   #4
godzilla-1
Drives: 1M Coupe
I don't really want a rear cage. A harness bar as shown in the pic would do what I require. Anyone got one laying around ? It doesn't look like there is anything available off the shelf anymore. The brr bar would be better as it mounts closer to the rear of the front seats and the harnesses that I already have aren't quite long enough to reach as far back as would be required to use the bar in the pic above.
      10-04-2018, 07:26 AM   #5
Soterios
BXR
575
Drives: 2012 135i
Any halfway decent fabrication shop should be able to make one if you can't find a prefabbed model.
Call around to some local speed shops.
