      03-09-2014, 01:25 PM   #1
///JAAM
Drives: 2010 135i
Torque Specs
I am making this as I don't see one anywhere. I was gathering all the torque specs for replacing front and rear suspension components and it has taken me all morning. I know I should just put up the money and get a manual, but what good is a forum if you can't spread knowledge (as long as it is correct)? So I am going to start this in hopes that others will use it and help me build on it.
Disclaimer
All of these numbers have come from this forum somewhere and may or may not be perfectly accurate. I do know that some of the ft lb measurements have been rounded up as everything started with nm. If you have something to add or correct please let me know and I will update/add it. Also some fasteners should be replaced and I can make note of that also.
Rear Sub Frame Rear Position 74 ftlb
Rear Sub Frame Front Position 74 ftlb
Front Tension Strut to Knuckle 122 ftlb
Front Tension Strut to Sub Frame m12 8.8 50 ftlb + 90
m12 10.9 74 ftlb + 90
Front Control Arm to Knuckle m14 8.8 59 ftlb
m14 10.9 122 ftlb
Front Control Arm to Sub Frame m12 8.8 50 ftlb + 90
Front Sway Endlink to Strut m10 43 ftlb
Front Strut Pinch Bolt 34 ftlb
Front Strut Top Hat Bolts 25 ftlb
Front Strut Top Bolt 47 ftlb
Rear Shock Top Bolt 20 ft lb
Rear Lower Shock Bolt 28 ftlb
Rear Lower Control Arm to knuckle 121 ftlb
Rear Lower Control Arm to Sub Frame 121 ftlb
Rear Upper Control Arm to Sub Frame 74 ftlb
Rear Upper Control Arm to Bearing Carrier 74 ftlb + 90
Rear Guide Arm to Sub Frame 74 ftlb
Rear Guide Arm to Bearing Carrier 74 ftlb + 90
Brake Caliper Mounting Bracket 81 ftlb
Brake Caliper Pins 22 ftlb
      03-10-2014, 04:58 AM   #2
sparkyblue
sparkyblue's Avatar
Drives: E82 135i & E92 M3 & E90 335xi
2008 BMW 135i  [0.00]
Thank you, going to do my rear subframe bushings soon and I'll need some of these.
      03-18-2014, 10:12 PM   #3
johngrossi
johngrossi's Avatar
Drives: 2011 135i e82
Any torque to yield bolts should be replaced ( ft lbs + "x" degrees)
PE exhaust, tints...more to come
      11-11-2014, 08:07 PM   #4
Pig Farmer
Drives: E92M
Has anyone come across the torque specs & tightening sequence for the differential cover?
      01-02-2016, 03:56 PM   #5
nikijack
Drives: 2016 M235i, Grey, manual
Hi: Does anyone know the size of the sway bar nuts, please? I seem to have lost it under the snow, while replacing yet another seized Bilstein strut.
thanks,
Jack
      01-02-2016, 04:22 PM   #6
Pig Farmer
Drives: E92M
thanks,
Jack
The nuts on the end links are M10 and the nuts near the center bushings are M8.
Also, I believe they both have a 1.0 pitch and are self locking.
      01-03-2016, 09:24 AM   #7
nikijack
Thank you PF.
      04-28-2017, 06:39 PM   #8
TridenTBoy
Drives: 2013 BMW 135is
2013 BMW 135is  [0.00]
I'll add it later if I can find it in my INPA/whatever software but does anyone know the torque specs for the lower bracing for an E88? It's for the bars that attach to the front of the frame/subframe and then to the front area of the doors.
      08-14-2017, 06:09 AM   #9
Traf
Traf's Avatar
France
90
Drives: E82 135i
Anybody knows the torque spec for the front subframe to body ? I can't find them in the bentley manual.
      09-27-2017, 07:06 PM   #10
ajoosten
Drives: 2009 135i | https://bmw135iblo
Looking for repair instructions and torque specs.
Go to www.Newtis.info
It is the bmw repair manual online. It has every torque spec you will ever need.
2009 135i
https://bmw135iblog.wordpress.com
Traf89.50
      09-28-2017, 12:28 PM   #11
Traf
Traf's Avatar
France
90
Drives: E82 135i
Oh man ! you the boss, thanks !
      09-28-2017, 12:41 PM   #12
TridenTBoy
Wow. Finally found what I was looking for:
https://www.newtis.info/tisv2/a/en/e...t-body/GVNYBbN
v-brace torque specs. Amazing... I couldn't even find this info in the VM instance I have of all these docs. (To be fair, BMW software is horrendously bad)
Although what does angle of rotation mean in this case? Apply 60NM and then do another 105 degrees? Confusing.
      09-28-2017, 02:17 PM   #13
Traf
Traf's Avatar
France
90
Drives: E82 135i
Well it is really simple, torque to 60NM then turn another 105 degrees, which is a little bit less than 1/3 of a turn. I use a black marker to mark the bolt for that kind of stuff.
      10-12-2017, 06:08 PM   #14
robygomez
Mexico
Drives: 325i, 2010, E90
Smile
Disclaimer
m14 10.9 122 ftlb
Thank you a lot for your information, do you know if this would be the same for a BMW 325i 2010 E90? AGAIN THANKS A LOT
      05-19-2019, 12:45 PM   #15
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [5.00]
Just used this guide today doing my rear upper shock mounts. Thanks!
      07-19-2019, 08:38 PM   #16
AndyW
AndyW's Avatar
Drives: 2008 335i E93 & 2012 135i E82
First, OP, Thx for this. Now a question for anyone who might know...
For the above, I am curious where this came from. RealOEM specifies that the bolts are 8.8. Bentley Manual says 100NM, which is the 74 lb-ft number.
This doc says 87NM for 8.8.
http://www.e38.org/bmw_torq.pdf
This site says 100NM is generically recommended for M12 bolts.
https://www.boltdepot.com/fastener-i...ed-Torque.aspx
But this thread mentions the same issue vis a vis 8.8 vs 10.9 bolts.
https://www.1addicts.com/forums/show....php?t=1363945
I am interested as I just upgraded my front control arms to the M3 ones and followed the Bentley Manual instructions and torqued to 100NM +90 degress. Not sure I overtorqued or not. Certainly didn't feel like overtorquing when I did it.
Any advice appreciated. Don't want to have to replace them if I don't need to. TIA.
Best,
Andy
'12 135i E82 - Stoptech Brakes, KW Coilovers, Wagner FMIC, ERCP, BMS Intake, Mason Strut Bar, Wedge MHD Tune //2008 335i E93 - HPF FMIC, ERCP, c-PE DPs, Wedge MHD Tune
      07-20-2019, 12:47 PM   #17
AndyW
AndyW's Avatar
So, I will have to replace these fasteners. Long story short...Old Bentley Manual (2008-2011) had both specs listed (8.8 and 10.9), new one (2012-2015) only had one spec with no hardness specified (but it was the 10.9). Pretty irritated with Bentley right now...
TLDR: Don't believe the new Bentley manuals, I suppose.
Best,
Andy
Copyright ©2000 - 2019, vBulletin Solutions Inc.
