      07-04-2016, 06:57 AM   #1
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
ESS Flash tune with Pure Stage 2 N55
Purchased the Turbo through Peter Oleksy ( absolute the man to buy it from, with optimum customer service) just hope the ESS tune works well ... I'm only using 98 octane here in Australia and no other fueling as its a daily driver . Tune is 14-15 PSI although not sure if it's to Redline. Once received and installed I will advise on the outcome. If anyone with this setup would love to hear from you.
      07-04-2016, 10:07 PM   #2
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Looking forward to hearing how things turn out.
      07-06-2016, 01:23 AM   #3
Hit Redline
Hit Redline's Avatar
Drives: 2010 E60 M5
Pure stg2 here. I would think running 98 octane you could run higher boost, closer to 18 psi or more.
Currently running almost 19psi at redline but I am running E70 with Fuel TBI. Still dialing in the tune. Once dialed in I am looking for 25-26 psi.
Did you get the pure inlet? The stock inlet gets pretty restricted right at the turbo connection.
This turbo feels amazing.
N55 135i DCT, Pure Stg 2, JB4 map 7 E50, N54tuning Catless DP, VRSF 7" IC, VRSF CP, AFE sealed intake, Ohlins R&T, Voshlag camber plates, corner balanced, M3 front control arms, M3 FSB, M3 RSB, M3 rear subframe bushings, M3 rear wishbone, RPI quad exhaust, APEX Arc 8 wheels, Fuel-it stg2 LPFP- Fuel lines- E sensor, BMS OCC, Quaife LSD
      07-06-2016, 08:17 PM   #4
No Style 135is
No Style 135is's Avatar
Drives: '90 gtr r32
I wish I could afford PS2......
      07-08-2016, 04:32 PM   #5
Rob_BMW_PNW
Drives: 135i 2011
Bout to drop the cash on it
      07-08-2016, 05:05 PM   #6
GR1P
GR1P's Avatar
33
Drives: 135is
21psi on the PS2 is where the car got stupid fast on the street, like spinning 3rd gear fast.
If you have a true 98 octane and not just 98RON, a small meth nozzle is all you'll need to reach 19psi.
The ps2 doesnt start to really shine until you crank up the boost.
      07-08-2016, 06:13 PM   #7
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Which tune are you using?
      07-09-2016, 12:03 AM   #8
GR1P
GR1P's Avatar
33
Drives: 135is
jb4 custom map6 over the ppk that comes stock on the car. I run an e35 mix and a cm10 nozzle with 90/10 meth/water.
That would be about 96 octane plus the meth, good for 21 psi safely
      07-09-2016, 12:32 AM   #9
Newguy123
Drives: 2008 Nissan Titan
[QUOTE=GR1P;20229960]jb4 custom map6 over the ppk that comes stock on the car. I run an e35 mix and a cm10 nozzle with 90/10 meth/water.
That would be about 96 octane plus the meth, good for 21 psi safely[/QUOTE
any slipping with just Ppk flash? I'm gonna guess you are 6 m/t if not post your map 6 targets
2012 DCT 135i
PURE S2
JB4/mhd
Fuel-It! direct port meth injection
check out my youtube channel here
      07-14-2016, 02:35 AM   #10
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
At this stage I'm only going for that 14-16 psi with pure stage 2....
May need ESS to make me another map.
Will try the existing and see how it goes!!
No inlet pipe for me just DV+ at this stage..
I want to feel the power alllllll the way to redline .
      07-15-2016, 07:09 PM   #11
Newguy123
even 16 psi at redline on a PS2 is hauling the mail
2012 DCT 135i
PURE S2
JB4/mhd
      07-16-2016, 07:36 AM   #12
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
That's why I got it... Based on your videos, especially the last one with just ps2 & jb4 map6.
If I put jb4 back on I will need your map6 settings
      07-16-2016, 12:14 PM   #13
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
+1.
      07-18-2016, 06:13 AM   #14
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
Eagle has landed !!!!!
      07-19-2016, 12:12 AM   #15
Newguy123
Oooooph bout to be a #supercarkiller
2012 DCT 135i
PURE S2
JB4/mhd
      07-27-2016, 04:26 AM   #16
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
Size difference!!
      07-30-2016, 12:09 AM   #17
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
Received back and she is Nice
100-200 run in 8.5 sec and with ESS stage 1 tune it seems to go 15psi to redline no more gear changes at 5300rpm... Power all the way to 7000rpm!!!
      08-13-2016, 06:12 AM   #18
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
About 250rwkw 750NM torque is pretty good.
Boost does taper down to 11ish at redline!!
Can't wait for stage 2 tune which ESS are currently developing!!
Car feels great with great pull and deeper sound ....
      01-16-2017, 04:52 PM   #19
aroonkl
Any chance to run ESS stage 2 yet?
      01-17-2017, 04:16 AM   #20
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
Still awaiting ESS.... don't fancy they will come to the party now !!! Hoping MHD can give clear instructions to unlock my dme and successfully tune post 04/2012
      01-20-2017, 02:12 PM   #21
Newguy123
What about ptf? Bm3
      01-20-2017, 11:18 PM   #22
Tricki
Tricki's Avatar
Drives: BMW M2 Comp
What about ptf? Bm3
We can't !!! Bm3 is only for the F-series
