      03-21-2016, 06:53 PM   #67
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
It doesn't rub going straight, I believe the tire is touching during hard cornering with the wheel slightly turned. Even then, you never hear anything. With the spec rs and dinan camber plates the top of my tire sits flush with the fender. I think just because of the default position of the tire, with a slight turn, the tire grazes the front section of the fender. This is with sumitomo htrIII's. I'll have to take a picture when I install the new suspension.
      03-21-2016, 11:36 PM   #68
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
And you're on what width in front?
2010 135i 6MT Jet Black
      03-21-2016, 11:52 PM   #69
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
8.5 inch, 45 offset
      03-21-2016, 11:59 PM   #70
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
8.5 inch, 45 offset
Tire?
      03-22-2016, 12:26 AM   #71
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
235/40 sumitomo htr III
      03-22-2016, 08:48 AM   #72
drunkenup
Drives: 2009 135i, 2021 F150
Tire has got to be too tall though others have pulled it off. Your offset is pretty high and close to the strut. Maybe time for a fender roll? You have decent camber too
      03-22-2016, 09:27 AM   #73
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Lower offset and he'll hit his fender more.
      03-22-2016, 10:04 AM   #74
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
The clearance is good on both sides and my fender is completely rolled flush. With my wheel pointing straight, it looks like I have a lot of clearance to the fender and I never hear the tire rub. You know, when the tire rubs, even if it is the most minor rub, you hear it loud and clear. Right now, I never hear it rub. It's like the little nubs that stick off of a brand new tire are barely touching the fender. Even though I don't hear it, I still want to see if I can avoid it from happening so I don't have to keep cover up the exposed metal with primer.
I am hoping with the tc plates that I can increase the amount of caster I have currently at 2.5 degrees camber, which will increase my camber when the wheel is turned to give me additional clearance and most importantly, improve handling.
      03-22-2016, 11:31 AM   #75
drunkenup
Depending on what height he sets with the TCK SA he is also going to be dangerously close to the height adjustment collars with that offset and tire height. My 245/35-18 on 8.5 ET45 was like 2 credit card widths from touching the collars with the shoulders. ET40 now with a 5mm spacer and it is still a little close for comfort.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
      03-22-2016, 12:08 PM   #76
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Question
Yeah. It will be interesting to see how mine fit with a 19x8 et 45 wheel and 235-35-19 tire. Thinking it will be close but OK.
      03-22-2016, 01:00 PM   #77
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
What ride height did you go with? Also, are you running their camber plates?
      03-22-2016, 06:50 PM   #78
drunkenup
So I have dinan plates on stock top hats, so overall strut height is probably at least 5mm higher without them. I am at 11 threads from the bottom and that gives me about 1.5 finger gap. Without the dinan plates I'd probably be around a 1 finger gap since the entire strut is shorter. Dinan plates and nothing else netted me -2.1 deg camber.
This is ET40 with a 245/35-18... if the tire were any taller it would risk hitting the collars. I am actually going to go to ET35 since I have the fender room to spare.
      03-22-2016, 06:54 PM   #79
hokejka
Drives: Past: 135i 6mt
this is the exact setup i want to run. are you on the 7 inch front springs? Any more picures you could share? outside drop. fender clearance? ... m3 control arms or not? ( sorry if i missed that.)
      03-22-2016, 06:56 PM   #80
hokejka
also... i have read that the TCK give you a minimum drop of 1" . Thats probably as low as i want to go so ill probably be at max ride height. can anyone confirm?
      03-22-2016, 07:11 PM   #81
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
I was under the impression that the usable range was ~.5-1.5". ~1" is where I'm at now, Though I want to raise it up a little in front.
      03-22-2016, 07:34 PM   #82
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks for the picture. Tire brand?
      03-22-2016, 07:35 PM   #83
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
I don't think that's true. When I spoke to tc, he said the sa could easily go back to stock height.
      03-22-2016, 07:59 PM   #84
hokejka
maybe he was referring to the 8 inch springs? assume you all will be running 7 inch to clear the anything besides a skinny tire
      03-22-2016, 08:00 PM   #85
drunkenup
No M3 arms. Just the coils and plates. I'm on the TCK supplied springs which are probably 7". Have you considered the shorter swift springs? I'll have to get a photo next time I'm around the car. But I have probably an inch of room between tire and fender, which are pulled. I bet I could go to ET30 with some more camber.
Pilot Super Sport
      03-22-2016, 08:00 PM   #86
hokejka
harold packs the tcks with 7 inch springs for the e82 since our offsets are so high we hit the springs/perches.
      03-22-2016, 08:02 PM   #87
hokejka
i would also like a drop from .5-1.0" from stock sport suspension. i need more clearance as its a dd and am not a fan of the slammed look
      03-22-2016, 08:03 PM   #88
hokejka
Pilot Super Sport
are the dinan plates adjustable within their max range? or is it fixed?
any previous pics you might have posted before?
