      09-06-2018, 07:14 PM   #67
juld0zer
I can't confirm but i do believe the Alpha type is not installed in any 1 series.
Battery positive cable to the junction box - stock is drying up. If it hasn't already run out.
Blower controller cables - stock is also in short supply for E9x owners, if it hasn't already run out. If you are worried, pop the two T20 screws out of the passenger footwell and unplug the blower. Slide the black tape wrap up about 7cm and check for stiff or discoloured insulation, or visible strands of wire.
If yes, then you are best to avoid using the blower or only use it at low output.
