03-06-2016, 10:01 AM | #23 | |
Rep 403
Pics in the Square 264s link in my signature... Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers |
03-06-2016, 03:40 PM | #24 |
Rep 8,164
Don't know either, but I think you should be happy about the additional 5 mm because the car looks great.
03-06-2016, 03:58 PM | #25 | |
Rep 7,224
03-06-2016, 04:20 PM | #26 | |
Rep 8,164
Honestly, the BMW PS should have been standard... Just to differentiate it from the rest of the line up.
03-06-2016, 04:22 PM | #27 | |
Rep 7,224
03-06-2016, 05:08 PM | #28 | |
Rep 8,164
F-gen M Sport suspension now have only 10mm drop from stock - while the stock suspension is even higher than before. And look what they are doing now to the M cars... Absolutely awful.
03-06-2016, 07:20 PM | #29 |
Rep 403
And I'm at the other end of the spectrum in that I think the PS drop is the maximum I'd ever want...
Horses for courses... Karl.
03-06-2016, 08:53 PM | #30 |
Rep 7,224
I might've felt that way too if I noticed a difference in the height... didn't really.
03-06-2016, 09:54 PM | #31 |
Rep 3,071
03-06-2016, 10:19 PM | #32 |
Rep 7,224
It's in my sig. The BMW Performance suspension.
03-07-2016, 10:59 AM | #33 | |
<(O0=[][]=0O)>
741
Rep 1,187
Needs a 2" drop and some 30mm spacers...
2012 E88 M-Sport 135i DSB Metallic
ER CP, ZHP Knob, E60 SSK Lever, E92 M3 FSB, RSFB inserts, Koni Sport, Eibach Pro, UCP, MPSS, AP axle-back, MHD Stage1+ 91 <(O0=[][]=0O)> |
03-07-2016, 01:14 PM | #36 | |
Rep 7,224
I believe BMW is discontinuing the Performance parts. Part #33-50-0-444-831 Springs are VIN specific.
hunginator153.50 |
03-07-2016, 01:46 PM | #37 |
<(O0=[][]=0O)>
741
Rep 1,187
I forget how this forum feels about "dealspotting" - I'm just doing a quick search but will remove info if needed.
~$877 at ECS, but it looks like springs are extra. Weird. I see it for $1275 at getbmwparts, but BR Racing lists the complete kit for 942. If going that way it might be worth calling to check availability and make sure everything in the kit is included from the supplier of your choice.
03-07-2016, 02:00 PM | #38 | |
Rep 265
This is confusing. It appears some vendors sell "half" the kit, without the springs. But if you add in 4 springs at roughly 100 bucks a pop, you're back to 1200-ish. |
03-07-2016, 02:04 PM | #39 | |
Rep 7,224
03-07-2016, 02:31 PM | #40 | |
Rep 265
BMW Performance Suspension 33500444831 BMW Performance Suspension Spring / Front 31336788891 BMW Performance Suspension Spring / Rear 33536788898 |
03-07-2016, 02:35 PM | #41 |
Rep 7,224
Never mind - found it. Took the dashes out of the part # and it popped right up. I'm an idiot!
https://www.ecstuning.com/BMW-E82-13...h/33500444831/
03-07-2016, 02:46 PM | #42 |
Rep 7,224
The part numbers you listed for the springs may not be the part numbers for your car since the springs are VIN specific.
03-07-2016, 04:08 PM | #43 | ||||
<(O0=[][]=0O)>
741
Rep 1,187
And I don't know what's up with the PS P/N. REALOEM says it's for Retrofit kit. ECS shows it that way. A couple other sites gave the full kit when I plugged that P/N in. Hopefully if you find a suitable supplier you can call 'em and make sure it includes everything you need for your car and configuration. Back to my configuration - I've noticed that a few race tuners (TCK, Dinan, others?) use custom-valved Koni's to great effect. But none of 'em have spring setting in the area I think I want. Dinan springs only lower 1/2", I can't find specs on the rates, and they are no longer available. BMW PS is less than 1/2" lower and 160lb/in front and 420lb/in rear. But not available for 'vert and rears would probably be a touch light. COBB gives 148lb front and 457 lb rear, but a full 1.2" drop which may be a bit much. TC Kline recommends 350/600. Not sure what the drop is but they look awesome. Swift R-Spec is at 201/502 with a 1" drop, but some have said it might be a hair firm for the street with off-the-shelf Koni's. So where does that put the TCK's? Lightest they go is 300/500, which, on paper, looks a touch unbalanced with too high a rate up front. I wonder if choosing Dinan or TCK-valved Koni's and running Swift R-Spec springs would yield a perfect compromise for the street, or if it would be a mis-match due to too much shock and not enough spring? I did note that TC himself recommends running as much shock as you can with minimal spring for the tire grip for optimal performance. I'm planning on 225/40 fr and 245/35 rr MPSS on factory staggered 261 wheels. Any experience? Opinions? Recommendations? If I'm spending all that dough on custom-valved shocks should I just get the coilovers? I'm not going to adjust them once I get 'em dialed in, and only want 3/4 to 1" drop so coils seem like overkill for my purposes. And set up the same (same springs, set for same amount of lowering) would they offer ride or handling advantages over springs and shocks?
03-07-2016, 10:57 PM | #44 | |
Rep 2,643
That first item for the BMW performance Suspension kit is correct one for the 1 series cars. It includes the dampers, struts, bump stops, all rubber parts, and a front sway bar, but WITHOUT springs. AFAIK, there are two sets of Performance springs that are sold for the 135i. LIGHT Set - for N55 cars with few options. BMW Performance Suspension Spring / Front "T2" Part: 31336788892 BMW Performance Suspension Spring / Rear "T1" Part: 33536788898 FIRM Set - For heavier N55 and N54 cars. BMW Performance Suspension Spring / Front "T3" Part: 31336788893 BMW Performance Suspension Spring / Rear "T2" Part: 33536788899 I have ordered both sets before. The difference is the thickness of the wire is slightly different, while the length and shape is the same. The spring rate will be about 10% higher between the T3 vs T2 front springs. Eg, if the T2 front spring is 147lb/in, the T3 front spring would be 162lb/in. |
lab_rat394.50 |
