      07-08-2021, 05:16 AM   #309
mwpa71
Drives: 2010 E88 135i
Saw the log. Thanks for posting. Getting misfires here and there after shifting has been a big problem. Glad to see it is gone.
G'day mate.
sorry to revive old thread.
having issues on ps2 dct with miss and limp mode after wot shifts...do you know what the cause and the fix??thanks
      07-08-2021, 12:44 PM   #310
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Easiest way to help you out is to see a log of it happening. Can you share one?
      07-21-2021, 01:41 AM   #311
mwpa71
Thanks mate..only just saw your response.
will post up soon.. the tuner has the car presently and cant get it right...
I was hoping to flick him some suggestions from you guys that seen to have done the hard yards and experienced similar problems. I have spent a fair bit of money and getting a little frustrated He is very experienced on the BMW platform. But not with n55 DCT ps2 with some boost.
      07-22-2021, 10:51 AM   #312
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
There's some known issue with the DCT and Pure Stage 2 playing nice together and causing misfires. The solution is to replace the flywheel with a flywheel from a F8X M car. Search around here a bit and you should find some threads about it.
AndyW672.00
      07-22-2021, 02:37 PM   #313
mwpa71
Thanks mate
has m3 f80 flywheel
will post some logs
      10-21-2021, 04:22 AM   #314
mwpa71
Hi Guys
I had Steve from wedge re-tune my car.. Amazing job and thank you.
No more misfires.
Just adding AEM meth.. Installed but with out a failsafe. Not interested in JB4 so will seek a tune in line with inline with current pump tune.
Kit is fully installed but not sure where to take 5volt signal from. (charge pipe Tmap or manifold tmap?) Can anyone shed some light? thanks
      10-21-2021, 11:15 AM   #315
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Should be the yellow wire. Yours might not be in the same location as mine because I repinned my connector to work with the n20 tmap.
      11-21-2021, 01:16 PM   #316
mwpa71
Thanks mate.
I picked up yellow wire from the intake manifold..Works a treat!!
Also i wired in the safety to cut the boost solenoid which works although without baffles in the tank, i have had one false safety cut due to fuel slosh (sensor in tank not so good!)
Had it retuned by Steve at Wedge (Good job !! thanks) 22.5psi and 12 deg of timing up top..
Car is running great..
      11-21-2021, 04:36 PM   #317
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks mate.
Awesome. Do you have any links to logs that you’ve uploaded?
      11-23-2021, 01:57 PM   #318
mwpa71
all my logs are public.
There are lots of them through various stages (Good and bad)
my datazip account name is mwpa71
I think you can look up account and view?
If not let me know and I can post specific for you.
cheers
houtan707.00
      02-24-2022, 03:15 PM   #319
mwpa71
https://datazap.me/u/mwpa71/3rd-gear...29-30-31-32-33
