      05-08-2018, 11:45 AM   #1
romnation
Is there any other option for headlight replacement aside from spending $1200 a set?
I need two new headlight assemblies, as I have some damage that appears to be located inside the light. i've tried buffing the outside which didn't change anything.
View post on imgur.com
I have the Bi-Xeon Adaptive lights, and the cheapest i can find for an OEM equivalent are the Valeo brand headlight assemblies which are nearly $600 each!
Links:
https://www.ecstuning.com/b-valeo-pa...127164931~val/
https://www.ecstuning.com/b-valeo-pa...127164932~val/
Do I have any other options besides this? I'd really like to keep the OEM look.
      05-08-2018, 12:10 PM   #2
low135
Drives: E88 135i
I had the same question really. Moreso because I wanted to do a cool retrofit but didn't want to be without headlights on my daily lol
      05-08-2018, 03:31 PM   #3
Jorgensen54
Jorgensen54's Avatar
Drives: 2008 AW/AG 135i 6MT
These were popular for a short time: http://www.m o d b a r g a i n s.com...lights-e82.htm
Also, buffing a headlight lens is very ineffective without sanding it prior. Most of the shimmer that you're seeing is pitting in the UV protective coating that is factory sprayed on the lens. It's a tedious job, but you could sand/polish that out to look a lot better.
On the other hand, some of that is heat damage and that can't be corrected.
I've done it on numerous cars and while it improves the light quality and overall appearance, it would take a lot of boredom or a car for show to do it again.
      05-08-2018, 09:26 PM   #4
low135
Drives: E88 135i
Those are for halogen only cars
      05-09-2018, 11:29 AM   #5
Jorgensen54
Ah, I didn't pay attention to that aspect. I could've sworn there were some for Xenon cars..
      05-14-2018, 12:17 PM   #6
Cavpilot2k
Chief Warrant Officer
1023
Drives: like a damn lunatic
I've considered the clear corner European headlights, but I think they run about $700 USD per light.
ouch!
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK
Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff
      05-14-2018, 04:59 PM   #7
low135
Drives: E88 135i
It doesn't seem like there are any good aftermarket options for cars with xenon adh from factory. I've been looking and looking but have always come up with "halogen cars only" "not for cars equipped with xenon" etc.
      05-25-2018, 02:24 PM   #8
jamespaoli
Drives: 128i
are those clear corner euro lights completely plug and play for a car with bi xenon / xenon adaptive? everything ive found has been projector halogen
      05-26-2018, 07:09 PM   #9
low135
Drives: E88 135i
Yeah unfortunately there doesn't seem to be any other options for bixenon with adh. Not sure if ecodes would need any coding but I'd imagine they're just plug and play. for what you'd pay for those, I'd just buy clear corners and crack open my OEM lights
      05-29-2018, 06:54 PM   #10
jamespaoli
Drives: 128i
Gotcha.. thanks for reply. I am in a pickle because my headlights get condensation everytime it rains and also there is a constant small blur on them.. i think when the PO did the angel eyes it wasnt done 100% correctly so i am trying to see what options ive found.. I may order euro lights at one point just wanted to make sure theyre plug ang play
      05-30-2018, 09:58 AM   #11
Throne54
Throne54's Avatar
Drives: 2009 E82 135i M-Sport N54
From what I hear these headlamps have a poor design which allows water to drip right on the control module. I have that issue currently and been looking for any option. I was informed by a good friend who is a BMW tech that we should not use aftermarket headlamps since for some reason the electronics act up and he has seen multiple fires in cars due to this.
2009 135i N54 M-Sport | VRSF 7" FMIC | VRSF Chargepipe | HKS BOV | BMS DCI | JB4 w/ two-step/anti-lag | MHD | BMS Oil Cooler Upgrades | VRSF Downpipes |
IG: Throne54
      05-31-2018, 12:07 PM   #12
arhoads335i
Drives: 2015 435i grand coupe xdrive
2008 BMW 128I  [0.00]
You're in NYC there should be plenty of places that could fully restore the lights. One I know is Lightworks
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current)
2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD)
08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD)
      06-18-2018, 10:12 AM   #13
uberschnell
uberschnell's Avatar
Drives: Wide Body 1
OP - I have the same thing. Like there is a residue on the inside of the lens. Typical restoration wont do a thing as this is on the inside. I also noticed it's worse on one side where water leaked in a year ago.
I'm looking into trying to pull the lens off and clean the inside myself.
      06-18-2018, 11:49 AM   #14
low135
Drives: E88 135i
I'm probably going to send my lights to get retrofitted with new angel eyes and black out. I'll just rent a car while they're being done. Much cheaper than buying a spare set lol
      09-10-2018, 02:32 AM   #15
Thomas94
Drives: BMW 120d e82
I have an e82 120d of 2012 with halogen headlights from factory and I want to replace them with angel eyes with the lit eyebrow (attached photo). Any sources?
