      02-13-2019, 01:30 AM   #1
duder13
duder13's Avatar
767
Drives: Cashmere
Choetech quick-charge wireless charger
Hi. While I know that Inbay makes that pretty slick looking wireless charging insert for our center consoles, the speed/tech is already outdated, it’s $120, and my iPhone XS is slightly larger than the recommended dimensions, so I went looking for something else.
This $20 Choetech fits the bill. I thought I’d have to secure it to the console, but its rubber back seems to keep it in place so far. Plus, it’s quick-charging and has three coils, so the phone can slide back and forth a bit and still find the charge. If I keep it long term, I may make a hole to run the cable.
Also, you need a QuickCharge 3.0 USB adapter for the cigarette lighter.
https://www.amazon.com/dp/B07D2CWBS1/ref=emc_b_5_mob_t
      02-13-2019, 08:37 PM   #2
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
Run the cable out the passenger side.
In the case it does come flying out, it'won't interfere with your feet, accelerator peddle, etc.
duder13767.00
      02-14-2019, 06:00 AM   #3
duder13
duder13's Avatar
767
Drives: Cashmere
Yeah, I’m actually going to drill out the little hole a bit that’s already under the rubber mat and run the wire. Yesterday I went on a spirited, windy road drive and the charger/phone didn’t budge.
      02-28-2019, 05:24 PM   #4
duder13
duder13's Avatar
767
Drives: Cashmere
I lifted the rubber pad in the bottom of the tray, routed out the hole on the left a bit to allow a USB through, ran the wire, and replaced the rubber pad. I may cut a notch in the pad.
      01-14-2020, 10:15 PM   #5
AshwinLB
Drives: 2008 BMW 135i 6MT
Would it work if you put the rubber pad on top of the charger?
      01-15-2020, 09:27 AM   #6
duder13
duder13's Avatar
767
Drives: Cashmere
Probably, but it hasn’t been necessary. The top of the charger is a bit of a rubbery material itself, and I haven’t had issue with the phone flying out of the cubby.
