      04-23-2019, 04:58 PM   #1
vincefreeflyer
France
18
Drives: 135I e82
Hi everybody,
I don't like that ruberry feeling with the rear train since i got the car (almost 2 years), i run with JB4 since 8 months and it's worst !! It's like i drive a drag race car but i "only" got above 360/380HP with JB4 .
So i've disassembled the rear subframe of my 135i to make the usual modifications :
Hydraulic ramps to lift the car :
Ultimate grip
Come on baby !
My program :
- Subframe bushings : Strongflex https://www.strongflex.eu/en/e81-e82...553526639.html
- Solid bearing rear toe arm : https://www.ebay.fr/itm/1-Series-E82...UAAOSwGq5cLlwD or https://www.ebay.fr/itm/06-12-E90-E9...cAAOSw3bBceZOl
- M3 rear guide rod
- Shock absorber + coils
- Andddddd LSD !!! either i look for a m3 auto diff with shafts or i'll install a quaife or Mfactory one ...
Now i have some questions :
I don't know what suspension kit is the best for price (less than 1400)
KW V2? KW St? Billstein? Koni? H&R?
Replacement of the Sway Bar or not ?
See you soon for more pictures
      04-25-2019, 07:18 PM   #2
lowbudgethero
lowbudgethero's Avatar
114
2009 BMW 135i  [4.25]
If you're not set on coil overs, I've been a huge fan of my setup with dinan springs from a 335i with bmw performance shocks. Great for getting rear weight transfer, but still has good dynamic handling on rough twisty roads. I changed a lot all at once though.
      05-01-2019, 10:22 AM   #3
vincefreeflyer
France
18
Drives: 135I e82
BMW performance shock? have you a link? Cause i have the M suspension and in my opinion this sucks
      05-01-2019, 10:32 AM   #4
HyeWarrior
Drives: 2012 135i DCT
I recently just installed Dinan springs (with Koni yellows) and I'm pretty happy with the improvement. Body roll is significantly reduced, though not completely gone. I may add a front/rear sway bar in the future.
Also running full M3 rear subframe bushings and front M3 control arms. It's definitely getting better
      05-01-2019, 11:16 AM   #5
gjm120
Drives: 2013 128i
I'm going to do a minor detour/hijack here since there is such good experience participating in this thread...
When dropping the subframe where do you disconnect brake lines?
Are the brake line pipes actually attached to the subframe?
Do you plug the ends and with what?
How to avoid loss of much brake fluid?
I assume bleeding is necessary after reconnecting.
Asking because I need to tap out the mounting holes for the rear arb bracket and need to drop the subframe a good bit to be able to do so.
E82 / Ver Red / Blk Boston L / BMWP Springs w/ Koni Yellows / M front control arms / M rear guide rods / AT / Sport seats & steering wheel + paddles
      05-03-2019, 02:39 PM   #6
Traf
Traf's Avatar
France
90
Drives: E82 135i
Dropping subframe will requier you to disconnect the middles lines. Hold the brake pedal to the floor with a wood block or some shit and brake fluid won't drip out.
      05-03-2019, 04:48 PM   #7
gjm120
Drives: 2013 128i
thanks.
So the metal pipes are not attached to the subframe? I was just afraid of lowering the subframe and snapping a metal pipe.
      05-04-2019, 03:49 AM   #8
Traf
Traf's Avatar
France
90
Drives: E82 135i
Originally Posted by gjm120 View Post
thanks.
The middle lines connect the body hardlines to the subframe hardlines
gjm1201029.50
      05-04-2019, 09:08 AM   #9
vincefreeflyer
France
18
Drives: 135I e82
When dropping the subframe where do you disconnect brake lines? on the left in front of the subframe
Are the brake line pipes actually attached to the subframe? yes you got metal line for the right caliper
Do you plug the ends and with what? with wood sreweded in the thread
How to avoid loss of much brake fluid? you can't
gjm1201029.50
      06-06-2019, 08:31 AM   #10
vincefreeflyer
France
18
Drives: 135I e82
hi guys, here arre the news.
I installed Strongflex bushings on my rear subframe.
It seem to be goods bushings they got aluminium inserts.
First i extract the old bushings, for this i do custom tools :
here the rusty subframe :
I don't like it so i did a paint job :
Front bushong are in 2 parts so easy to install! But rear are a pain to engage
So i did another custom tool :
And finish the job like this :
Next time i'll replace TOE, Camber and trailing arms with adjustable ball link
- https://www.ebay.fr/itm/272049012994?ul_noapp=true
- https://www.ebay.co.uk/itm/FOR-BMW-3...53.m2749.l2649
In 2/3weeks, parts are on the road
After i'll do coilovers and M3 front arms.
dtla1341.00
asbrr238.50
Tuxedo383.00
      06-06-2019, 11:08 PM   #11
gmagnus7
Drives: BMW 135i FBO N54 MT
You clearly don't have bad salty wintery roads where you live My subframe has rust patches all over.
      06-21-2019, 05:24 AM   #12
vincefreeflyer
France
18
Drives: 135I e82
here we are :
i received the ball linked adjustables arms :
I was looking for an "non-expansive" LSD but not cheap too
I got it !!! M3E9X LSD baby !!
A guy who got a wrecked M3 sold his complete rear axle so i bought it last week.
I'm just disappointed to get this now because i ordered arms and bushings one month later... If i get this rear axle 1 month before i saved precious time and money ... But i have also a good setup
But i'm unsure, does i use my 135i modded rear axle or the M3 one? Or i can use some parts of the rear M3 one (like lower camber arms).
In both case i'll use m3 LSD, m3 halfshafts, m3 sway bar on the final project
Here are some pictures of the 2 rear axles :
and here sway bars comparison :
      06-21-2019, 08:16 AM   #13
ShocknAwe
ShocknAwe's Avatar
Drives: E82 N54
Should have done solid subframe...
2010 135i M-Sport 6MT Jet Black
N54 | BUILD THREAD
      06-21-2019, 09:56 AM   #14
vincefreeflyer
France
18
Drives: 135I e82
for the bushings?
      06-21-2019, 10:56 AM   #15
BMWWorld
Drives: E90
Good thread 🔥
      06-21-2019, 03:04 PM   #16
ShocknAwe
ShocknAwe's Avatar
Drives: E82 N54
Originally Posted by vincefreeflyer View Post
for the bushings?
Exactly
N54 | BUILD THREAD
      06-22-2019, 06:57 AM   #17
vincefreeflyer
France
18
Drives: 135I e82
Originally Posted by BMWWorld View Post
Good thread 🔥
thank's buddy
      06-22-2019, 07:01 AM   #18
vincefreeflyer
France
18
Drives: 135I e82
Exactly
not sur, i'll never go above 500 hp and those polyurethanne are a lot harder and not hollow than stock ones. This is a lot of difference !
      06-22-2019, 07:24 AM   #19
ShocknAwe
ShocknAwe's Avatar
Drives: E82 N54
It's not a power issue. The 2pc poly are easier to install but that's about it. When it comes to suspension, use rubber or metal.
N54 | BUILD THREAD
      06-24-2019, 03:07 AM   #20
Traf
Traf's Avatar
France
90
Drives: E82 135i
Well, subframe isnt exactly suspension related, more structural i'd say.
PU is good enough, i had PU before i switched to metal, both are fine.
      06-24-2019, 09:09 AM   #21
vincefreeflyer
France
18
Drives: 135I e82
Really? Look at the first pictures of this topic, a press is required to install those poly
And yes subframe is more structural than suspension
      06-24-2019, 01:51 PM   #22
dtla1
dtla1's Avatar
341
Drives: 2011 135i, Space Grey
The typical replacement for PU subframe bushings is from Whiteline, which are two piece both front and rear. No press needed for install! That's prob why previous commenter mentions this.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
