      09-03-2016, 03:03 PM   #771
Eau_Rouge111
Eau_Rouge111's Avatar
Drives: 2009 128i and 2007 Z4M Coupe
I'll try to take some more. But you can't go wrong with either...19s or 18s suit the look of the car. 18s will ride smoother given you get more sidewall on the tire.
      09-05-2016, 08:33 PM   #772
sandlion
Drives: 2011 135i
Wheels: BMW Style 197
Tires:
Front 215/40ZR-18 HANKOOK VENTUS V12 EVO2 XL
Rear 245/35ZR-18 HANKOOK VENTUS V12 EVO2 XL
Suspension/Fender Mods/Camber:
Koni FSD
Front -2camber, rear -2camber
Work great no rubbing
2011 135i DCT
Space Gray Metallic | TR Motorsports 17x8 ET40 Wheels | Koni Yellows | FMIC | Charge Pipe | MHD Stage 1 | Riken Raptor 245/40ZR Tires
      11-20-2016, 02:48 PM   #773
bp05
bp05's Avatar
Drives: 09 135i Vert
Tires:
Koni FSD
Are you lowered at all?
      11-20-2016, 02:49 PM   #774
bp05
bp05's Avatar
Originally Posted by Pyrat 2 View Post
Front 255/35-18 on 18x8.5 ET 42 (ET 45 + 3 mm spacer).
Rear 255/35-18 on 18x8.5 ET 45.
Direzza Z2SS.
No rub, no fender pull, no fender roll
Dinan camber plates at -1.5 camber
BMWP springs
This would actually be +39 offset, if anyone is wondering.
      11-22-2016, 06:38 AM   #775
135
Direzza Z2SS.
BMWP springs
Actually, it's a square ET45 setup with a 3mm spacer on the front, so the rear is ET45 and the front is an ET42 (45-3), not ET39 (42-3, which seems to be how you interpreted it).
Pyrat 21417.50
      11-22-2016, 09:59 PM   #776
HomeIsToronto
Drives: 2008 BMW 128i
About to get some RSSW Diamond
Front 17x8 with 35 offset, real excited. Will post pictures when installed
      12-02-2016, 07:24 AM   #777
HomeIsToronto
Finally got them on, was only able to take a quick iPhone picture, the winters make it look a little boaty with how high profile they are but oh well... Also going to have to replace that ugly center cap with a nice BMW one
EDIT: Finally switched the caps and she's looking gorgeous
      01-19-2017, 10:38 PM   #778
Gangplank
Gangplank's Avatar
2011 135i  [0.00]
Tires:
Koni FSD
Looks good but how'd you get this to fit? Style 197 are
3er E90+ 8x18 ET 34
3er E90+ 8.5x18 ET 37
I'd expect it to rub stock. Doubt a 225/255 set up would work.
      01-24-2017, 05:10 AM   #779
sandlion
Drives: 2011 135i
Tires:
Koni FSD
3er E90+ 8x18 ET 34
Thanks. Didn't do anything special just camber and stock tire sizes. I think larger would probably rub.
2011 135i DCT
      01-24-2017, 12:08 PM   #780
berne
Sweden
46
Drives: BMW 135i
PCD: 5x120
WIDTH: 8.5" Front / 9.5" Rear
OFFSET: et38 front / et45 rear
CB: 72.6
i gussing this will fit a e82?
what tiers sholde i run?
      02-11-2017, 02:17 PM   #781
Accrual_World
Member
Drives: Black 135i M Sport
Wheels: Moda Eb1 18*8+45 all four corners
Tires: General Gmax As-03
Front: 225/40/18
Rear: 255/35/18
Suspension: Stock MSport suspension
Other: No fender rolling, no spacers, no rubbing clears front suspension by about .5", and the rears have plenty of room.
Only have a pic of the rear as I myself was curious about the fitment of a 255 on an 8" wheel, worked out well..
      02-14-2017, 12:24 AM   #782
chopstik
chopstik's Avatar
Drives: 128i
would it be possible to run square oem m68 rear wheels?
17x8.5 et50
thanks!
      02-19-2017, 09:29 PM   #783
bimmerboyE92
Drives: BMW
ASA GT9 in Titanium Gunmetal
17x8 et40 with Continental DWS 225/45-17 - square setup same all around
Lowered on Bilstein B12 kit with Pro Kit springs
Alignment was done by dealer within factory tolerances - pins still in
No rubbing!
John_01232.00
Mach1er88.00
niceast45.00
      02-21-2017, 01:59 PM   #784
zapatista
zapatista's Avatar
Drives: 2011 128i Vert 6MT
Well this is what I'm going to do, just to see if it will work.
A little background, I ran a square 235/40r18 setup of Goodyear F1 Asymmetric 2's with the same basic suspension setup and 18x8 et 40 wheels. The only difference was that I used H&R Sport Springs that came as a kit with the Konis and never had any rubbing or poke issues over 15k miles and 10-12 autocross days.
Square set up:
Tires: 265/40-18 Hankook Ventus R-S3 Version 2 (V222)
Wheels: Alzor Style 020-10 18x9 ET42
Suspension:
Koni Yellows
BMW OE Non-Sport Springs (BMW 128i Vert)
M3 (TRW) Front Control Arms (Tension & Wishbone)
Dinan Fixed Camber Plates
5mm Spacers if needed (I think there will be rubbing in the inner front).
There will be poke in front but not sure about fender rub.
I get the wonder(fully) cheap ECS Tuning housebrand wheels this week and will mount them with the R-S3's ASAP.
A couple or fifteen mods.
Last edited by zapatista; 02-24-2017 at 11:48 AM.. Reason: Added some irrelevant info.
      02-25-2017, 08:20 PM   #785
derekh
Drives: ---
Ok, so I've been looking for wheels for a while now. I'm interested in running a 225 and an 8.5 to 9 inch up front and a 255 and 9.5-10 inch out back. I'm struggling with figuring out the best offsets to run as a balance between "the look" and not having any issues. I have a 2011 128 sport pack. I got the car used, it looks like it has had the fenders rolled and might be on lowering springs. haven't been able to get under it to have a look.
At any rate what kind of offset should i be looking for with what size wheel, the best I'm coming up with is 18x8.5 et35-45 and 18x9.5 et45-60. Does a 18x9 et40 fit with a 225 up front? what about a 18x10 et55 out back with a 255? any info would be incredibly helpful.
Many Thanks.
Derek
      02-26-2017, 12:39 PM   #786
drunkenup
Drives: 2009 135i, 2021 F150
Square set up:
Suspension:
Koni Yellows
I'm pretty skeptical on whether this setup is going to be usable for a couple reasons
1. Several people have already documented fitting 255/35-18 and 255/40-17 on 9" square wheels and that is supposedly the maximum that can be fitted
2. The aforementioned setups required adjustable camber plates (~-3 deg) and fender modifications for optimized stack height and fender/spring perch/strut tube clearance, even then, it is very close
3. In contrast, you have an even wider and taller tire, and less possible camber (I was maxed out at -2.2 with dinan plates, not sure if M3 arms are a viable camber adder in the way they change geometry). Also, I don't know where the spring is on the setup you have, though you want the shortest spring possible for maximum width tire, especially for one as square as an RS3.
I'd love for you to put my concerns to ease but everything known about the given working setups really don't work in your favor
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
      02-26-2017, 08:14 PM   #787
zapatista
zapatista's Avatar
I appreciate the feedback and I'll let you know tomorrow as I will have them mounted and balanced--I very much have my doubts too. I actually swapped the H&R Sport springs for the original springs which adds about 2 inchs of wheel well height back. I assumed this would be better for clearing the fenders with the R-S3's?!?
Pre-install pics of wheels attached to front passenger side-no spacer. Obviosuly I'll need a spacer to clear the strut tube---the caliper is real close too (w/335i conversion in front). Wheels weigh 22.6 lbs a piece.
Name:  Reduced Size (2 of 6).jpg
      02-27-2017, 03:41 PM   #788
drunkenup
Fingers crossed for ya, looks like your shock tubes are smaller even the thinnest coilovers (thinner than my koni based TCKs), and the spring seat is pretty high up.
      02-27-2017, 08:56 PM   #789
zapatista
zapatista's Avatar
Well fender liner rubbing and severe front spring perch rubbing with 5mm spacers. Time for bigger spacers (after it stops snowing).
The rears appear to be just fine but time to put the snow tires on it.
      03-03-2017, 07:43 PM   #790
Maxim_X
Drives: 2011 135i
What do you all think of the OZ Ultraleggera Bronze on a white 135.
      03-11-2017, 08:37 AM   #791
derekh
Drives: ---
I have my eye on a set of wheels 18x9+38 18x10+40. any thoughts on fitting these on a 128 sport pack? the plan is to run a 225 and a 255 but i wouldn't be to upset about switching to a 215 and a 245 if there is cause for it. From what i have read though this post they should fit under the car without touching the fenders or the struts but I'm not sure if the rubber will hit the fenders or not.
Note, these are 3 piece wheels and i could tweak the backspacing and size if i had to.
Thanks
Derek
      03-11-2017, 08:55 PM   #792
Maxim_X
Drives: 2011 135i
I read through this whole thread looking for exactly that info, and it was on the last page. Thanks for trying, I can't wait to be square. 235 seems the widest for the front on a 40et without modifications, but, 245 would be better all around. I'm really surprised this car doesn't have the room.
