      06-14-2017, 06:54 PM   #815
Blown95ImpalaSS
Drives: s54 e36 m3/4/5
^^it will look super stretched but it will fit
      06-16-2017, 09:31 AM   #816
homewrecker07
Drives: 2012 E88
Wheels and tires being mounted right now, excited but worried.
Specs for reference
BBS CI-R Platinum Silver
19x8 et 45 - 225/35/19
19x9 et 48 - 255/30/19
Stock height, no rolling, no rubbing
Fakemike368.50
swagon13522.50
      06-21-2017, 01:27 PM   #817
durpflip
durpflip's Avatar
Drives: a superior vehicle
2008 BMW 128i  [0.00]
i kind of wanted the stretch lol. i'm probably going to lower this near the ground (no tracks nearby = no use for fat slicks right?)
      06-24-2017, 02:58 PM   #818
Blown95ImpalaSS
hopefully this helps some of the autox/drag race crowd, sorry for the crap pics and dirty car
c5 wagon wheels 5x120.56
rear - 18x9.5 +65, 265/35/18 hankook rs3, no spacer
front - 17x8.5 +56, 245/40/17 hankook rs3, 12mm hubcentric spacer and ext. lugs, 3mm enlarged center bore to 72.56mm
bilstein b6, swift springs, m3 arms, alignment pins pulled, -1.6 camber in front, zero rub. about 2 credit cards' worth of front strut clearance. finally...traction in 2nd gear
Fakemike368.50
      07-06-2017, 12:11 AM   #819
Newguy123
Drives: 2008 Nissan Titan
I'm running kosei k1 17x8.5 I think et40. 225/45/17 Federal RSR front and 255/40/17 RSR rear. I have slight rubbing over bumps in the rear, I've done what I can with a fender roller and heat gun but still get the pesky rub. I know the R compounds run wide was just seeing if anyone on here has experience with the kosei and r comp tires
2012 DCT 135i
PURE S2
JB4/mhd
Fuel-It! direct port meth injection
check out my youtube channel here
Jpelps19.50
      07-07-2017, 02:14 PM   #820
Larsarous
Drives: 2012 135i
Square set up on my 2012
APEX ARC-8 18x8.5" ET45
225/40 18"
No modifications to make this work.
      07-12-2017, 12:48 AM   #821
spxxx
Boost
spxxx's Avatar
1354
Drives: 135i M-Sport
Anyone squeeze 265s up front yet?
      07-21-2017, 03:38 PM   #822
berne
Sweden
46
Drives: BMW 135i
will
8.5 ET 35 19"
9.5 ET 35 19"
fit on a bmw E82?
i have eibach sping, and m-sport
      07-21-2017, 04:58 PM   #823
BimmerAg
BimmerAg's Avatar
Drives: 2011 135i
Originally Posted by berne View Post
will
8.5 ET 35 19"
9.5 ET 35 19"
fit on a bmw E82?
Those will probably rub the fender lip, especially in the rear, but it also depends on what tire size you're trying to run...
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser
berne45.50
      07-28-2017, 02:33 PM   #824
durpflip
durpflip's Avatar
hi
setup complete!
Wheels: Fast FC-04
Front: 18x8 ET40 (square)
Spacer: N/A
Rear: 18x8 ET40 (square)
Spacer: N/A, will probably get a small spacer because hella flush yo
Tires:
Front - some cheap chinese tire i can't remember 235/40R18
Rear - same crap tire 235/40R18
Suspension/Fender Mods/Camber: none for now
Notes: no rubbing. i'll probably ditch these meaty tires for 215s when they wear out and get some H&R springs,but i'm a student so i can't afford those toys for now.
image - https://vgy.me/wvJ5uh.jpg
edit 08/18/2017 - front rubs on the fender liner in big dips on the highways (found this out the hard way while in gaspésie) at 50-65mph. the only part that rubs is soft plastic and it's just a small scrape,so no worries there. rear also rubs,but this is due to a slow leak in the rear shocks. i scrapped the plans for h&r springs and got coilovers, which are on their way, but it's a three month waiting list.
i'll get to taking on some more detailed pictures later,probably next week; it's the weekend alright you gotta spend it wisely
Last edited by durpflip; 08-18-2017 at 02:08 PM.. Reason: very big image so i just linked it
      07-28-2017, 02:48 PM   #825
Matt@EuroJerks
Drives: 2021 Jeep Cherokee
I never understood why people "cheap out" on the ONLY thing that holds them to the road and has a significant job in breaking.
      07-28-2017, 04:49 PM   #826
durpflip
durpflip's Avatar
cool
no one cares
      08-06-2017, 04:33 PM   #827
Kontra
Drives: N51 128i
Sorry for the phone pictures, I'll try to take some better ones in a week or so.
H&R Sport Springs + Koni Yellows
OZ Alleggerita HLT's 17x8et40 w/ MPSS 235/45/17 - 0 rubbing all around so far w/o camber plates or any fender rolling
niceast45.00
      08-08-2017, 12:44 AM   #828
glorydays
Drives: 2011 135i
https://ibb.co/nNcR4v
https://image.ibb.co/gcofxF/Screensh...804_130245.png
Wheels: ESR SR02
Front: 18x 8.5 +35
Spacer: none
Rear: 18x 9.5 +30
Spacer: none
Tires:
Front Nexen SU1 215/40/18
Rear Nexen SU1 245/35/18
None
Notes:
Rarely rubs on rear passenger side, shock could be going out.
      08-08-2017, 09:02 AM   #829
Matt@EuroJerks
Originally Posted by glorydays View Post
Wheels: ESR SR02
Front: 18x 8.5 +35
Spacer: none
Rear: 18x 9.5 +30
Spacer: none
Tires:
None
Notes:
Do you have any pictures of this setup?
      08-08-2017, 02:12 PM   #830
glorydays
Drives: 2011 135i
Just added links
      08-08-2017, 02:53 PM   #831
Matt@EuroJerks
Just added links
Dope.
      08-15-2017, 01:55 PM   #832
CAYY
CAYY's Avatar
Drives: 2011 128i
I've got an opportunity to pick up 4 Style 42s for my 128 (to use for winter). 16x7, ET46 they're from an E36. According to searches from this forum these should fit no problem but i wanted to confirm for sure? Tires will be 205/55/16. Currently I have the OEM steelies 16x7 but with ET31 they rub on speed bumps, driveways, etc plus these look great!
http://www.bmwstylewheels.com/bmw/42
      08-25-2017, 11:07 PM   #833
Matt@EuroJerks
We need more fitment pics!!! Make sure you post the offsets too!
      08-26-2017, 10:45 PM   #834
NDion80
NDion80's Avatar
Drives: AW 2012 135i M sport
0-Z Ultraleggera
O-Z Ultraleggera Matte Bronze
F: 18x8 ET40 215/40/18 Continental ExtremeContact Sport
R: 18x9 ET40 245/35/18 Continental ExtremeContact Sport
ST XTA coilvers
Front camber -2.5
Rear camber -2.0
Rear fenders rolled and absolutely 0 rub in any scenario
      08-27-2017, 03:47 PM   #835
swagon
swagon's Avatar
Drives: F80 6MT
Why 215's only?
      08-27-2017, 05:31 PM   #836
NDion80
NDion80's Avatar
Why 215's only?
I stayed with 215 at the front because I was afraid that 255s in the rear would rub too much. And the difference in diameter between 245/35/18 and 225/40/18 was too much for my liking.
Next set of rubber i will bump up the width front and back. Although i'm thinking of adding a 3mm spacer at the front right now.
