08-28-2017, 12:40 AM | #837 | |
Rep 8,165
09-25-2017, 08:16 AM | #839 | |
Rep 22
Hi,
Looking to run a 17x9 255/40 setup on a race car. When you say you have a ton of strut clearance, do you mean up front? Could you get by with less of a spacer? Rob Quote:
09-25-2017, 02:36 PM | #840 |
Rep 988
In front, yes. I think the TCK's I run are on the thinner side of strut tubes (unlike KWs or Ohlins). I might try a 5mm spacer instead to alleviate fender rub. I will have to double check, but you can definitely go higher than ET32.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
10-06-2017, 12:29 PM | #841 |
Rep 138
Hey Everyone,
What is your take on a square setup 18x8 ET 35 for a daily? From the research I have done it will fit on stock suspension and will allow for rotating tires due to the square setup. Do you think the loss of width in the front and rear is worth having the ability to rotate? Will this setup need spacers to sit flush with the fender? |
10-06-2017, 02:03 PM | #842 | |
Rep 545
If you don't floor it very often or take turns quickly then you probably won't notice the thinner tires. If you do drive spiritedly, I'd advise against going any smaller than the stock 245 in the rear
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
10-06-2017, 02:38 PM | #843 | |
Rep 361
Here is Vorshlag's test fit of a 17x9 +36 (+41 with a 5mm spacer) with a narrow 255 and it appears to fit just fine: On the other hand, my 17x9 +35 with a 255 RE71R which is a MUCH wider tire is an extremely tight fit and rubs over bumps. I have Ohlins coilovers and with that wide tire, there is no way that a +42 would not rub the strut. Maybe with a smaller tire it wouldn't, but with my RE71R, it definitely would. -Mark
2011 BMW 128i - Check out my STX build thread!
10-06-2017, 03:10 PM | #844 | |
Rep 138
10-06-2017, 04:29 PM | #845 | |
Rep 545
10-11-2017, 09:25 AM | #846 | |
Rep 45
Drives: a superior vehicle
still,it's going to be hella flush or borderline mexi-poke,if anything. |
Mr. Pharaoh60.50 |
10-11-2017, 03:57 PM | #847 |
Rep 138
So I guess the ultimate question is then is it worth going down to 225's all around? Is the loss in tire width super noticeable? Nice use of the word hella btw.
10-13-2017, 10:21 AM | #848 |
Rep 545
Wheels: BMW Style 68
Front: 17x7.5 ET41 Rear: 17x8.5 ET50 Tires: Continental ExtremeContact Front 245/40R-17 Rear 255/40R-17 Suspension/Fender Mods/Camber: none No rubbing that I've noticed during street driving. Will update after autocross this weekend on how they do when pushed EDIT: Didn't notice any rubbing during autoX this weekend. The car felt much more neutral with the 245's up front, but I will say that I was disappointed in the overall level of grip from these tires. They're old Conti ExtremeContact DW tires and they felt like they had lower total grip than the stock size RE050A RFT's that I have used in previous events. In the market for a set of good tires (RE71, Rivals, Direzza, etc) and trying to decide whether I should stick with 245's up front or try 235's since high-performance tires tend to run a little wider...
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser Last edited by BimmerAg; 10-16-2017 at 02:18 PM.. |
Fakemike369.50 |
10-14-2017, 11:44 AM | #849 | |
Rep 45
GL in your wheel endeavours though |
11-01-2017, 01:53 AM | #850 |
Rep 11
Drives: 2011 E82 135i M-Sport
Wheels: BBS RS-GT
Front: 18x8.5 ET35 Rear: 18x8.5 ET35 Tires: Bridgestone Blizzak Front 225/45R-18 Rear 225/45R-18 Suspension/Fender Mods/Camber: none NOTE: Wheels came off an M3, were the guys winter setup hence the tires. Rubbing a little little tiny bit in the front with 2 people on big dips but that will be taken care of with new suspension and better tires after the winter. Back clearance is fine |
11-14-2017, 08:26 AM | #851 | |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito Last edited by desertman123; 11-14-2017 at 11:31 AM.. |
11-14-2017, 11:36 AM | #852 |
Rep 11
I like the setup a lot. The front has just the right amount of poke. Not to far out to be slamming fender but looks more aggressive, wish the rear was out a little more but I’ll get spacers eventually. The car feels better to drive as well!
11-14-2017, 02:10 PM | #853 |
Rep 16
looked through the whole thread and couldn't find anyone running this. Would it work with the rears rolled and pulled?
19x9.5 et40 255/30 19x8.5 et35 225/35 lowered on h&r coils |
11-14-2017, 06:46 PM | #854 |
Rep 361
Those are doable, but will depend on your tire choice and alignment.
Front will be no problem as long as you have camber plates - I would estimate you will need 2 degrees camber. I ran an 8.5" +35 front with a 225 Conti DWS with my 3.5 degrees camber and had TONS of room. Rear will require a roll for sure, and probably a pull. I ran a 9.5" +45 with my 255 Conti DWS with rolled (but not pulled at all) fenders and it absolutely did not rub under any circumstances. If you ran the same tire as me (which is quite narrow for a 255), you would be close to getting away with it with just a roll - might need a bit more roll. If you wanted to run a wider 255, you'll need a pull. -Mark
11-27-2017, 09:45 AM | #856 |
Rep 17
I just picked up some winter tires For my non-sport 128i. A set of kinda ugly mille miglias, 17" diameter, ET 40's with 225/45R-17 blizzacks.
However, I'm not sure if they are 8 or 8.5 width. Will either 8 or 8.5" width clear? seems like it should based on what I've read here, but willtheyfit.com makes it seem like they will be too far out with the 8.5. opinions? |
bmwlaguna29.00 |
12-10-2017, 05:00 AM | #858 |
Rep 6
Just had my 08 135i lowered on AP coilovers (not overly stiff)
Running a 245/40/18 on the OEM 8.5+52 wheels Had 18mm spacers which rubbed quite a bit, before I change to some thinner spacers would going to a shorter tyre (245/35) provide any extra clearance? |
