10-08-2009, 04:00 PM | #45 |
Rep 1,477
You obviously have not looked at how the 1-series rear sway bar is mounted. Much different than the E36/E46.
10-08-2009, 05:17 PM | #46 | |
Rep 10,176
I'm a pretty daring wrench wielding car hack, and that's more than I would want to attempt (and I've done many swaybar installs before - along with many other things to my past bimmers). |
10-10-2009, 11:25 PM | #47 | ||
Rep 1,804
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
10-11-2009, 09:05 AM | #48 |
Rep 10,176
Chill? Thanks for the advice.
You were the one who said you did the front/rear on your past bimmer and SPECIFALLY mentioned replacing SWAYBARS. Nobody "called you" on mentioning the "rear" word... |
10-11-2009, 01:34 PM | #49 |
Rep 1,804
Sorry for the confusion. I guess it was a little unclear on how I worded it.
P.S. I'm using your review to install my front sway bar. Did you leave the black rubber inserts inside the bushing when you installed it, and grease it as well? My previous sways were H&R (i.e. no grease).
-Nick
10-14-2009, 04:03 PM | #50 |
Rep 1,804
No worries. Figured it out.
-Nick
02-20-2010, 06:57 PM | #52 |
Rep 10,176
I removed it, after never getting it to not bang (no matter how it is adjusted), even with purchasing another set of aftermarket end links, after the UUC adjustable end links rusted solid after 3 months.
I'd recommend the E93 M3 bar or the Hotchkis bar over this one. The UUC one is not up to quality standard of past UUC parts I've purchased... not even remotely close. |
10-28-2010, 01:48 PM | #55 |
Rep 2,233
10-28-2010, 07:29 PM | #59 |
Rep 10,176
UUC's front bar doesn't fit on any 1er without bumps and scrapes. I've tried to save others from having the major problems I experienced. Sorry you didn't read any of my many warnings about that product. Be grateful it didn't rip your brakes lines out, and slice the ABS pulsers in two, like mine did.
10-28-2010, 07:31 PM | #60 | |
Rep 541
11-07-2010, 04:30 PM | #61 |
Rep 2,233
Just finished the M3 front bar install on my 128. Straight forward install, the DIY allowed me to make sure I had all the tools necessary before getting car up on ramps. Thanks.
11-20-2010, 12:44 AM | #62 |
Rep 676
Where can you get lithium grease? Local hardware store? Home Depot (US retail chain)?
135i // M-Sports Package // RR Oil Catch Can // Black Kidneys // iCarbon Hood // Alum Pedals // KW v2 Coilovers // Vorshlag Camber Plates // Hotchkis Sway Bar // Wheel Studs. Best mod ever? Tires. 255's in front, 275's in back.
11-23-2010, 10:50 PM | #63 | |
Rep 6,107
This is the brand I used on my M3 and it works great ! Regarding installing the Rear Bar, I wouldn't recommend doing it unless you have a access to a lift. |
11-23-2010, 11:29 PM | #64 |
Rep 676
Very cool! Thanks for the tip.
11-15-2013, 12:47 PM | #65 | |
Emperor
1611
Rep 2,753
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
11-15-2013, 01:28 PM | #66 | |
Rep 12,559
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
