02-04-2010, 02:14 PM | #45 |
Rep 369
Drives: 2009 BMW 135i
looks awesome!!! IMO the tire fitment looks perfect in the front but somewhat small in the rear, like 265 would have been great (gl fitting that),,, sweet wheels man!
02-04-2010, 02:33 PM | #46 | |
aka 1013MM
1246
Rep 9,545
Thanks man. Fitment in the front "looks" perfect but does not "drive" perfect. Fender mod is a must, which I will be doing soon. As for the rear the 19x9.5 is really tough I might be rubbing against the inner liner or somewhere inside but not the outside of the fender. I suspect that 265 would work but they would rub because of the 19x9.5. Right now the 255 rears are a little stretched due to the 9.5 rear. But the front and rears look pretty even to me. The perfect setup would probably be 19x8 with 225 and 19x9 255 and no fender mods should be needed. My extra .5 up front and back really throws everything out of proportion and I MIGHT be able to fit 265 in the back and it would look nice and full, I just don't want to risk it now. I will try 235 and 265 in the future when my tread life is down, which should be pretty quick on a RWD car
02-04-2010, 04:23 PM | #47 |
Rep 25,989
Car looks amazing John. HS is perfect on your blue car!
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
02-04-2010, 05:37 PM | #51 | |
aka 1013MM
1246
Rep 9,545
Thanks!! You hit it right ont he spot the first time HOW DID YOU KNOW ?!?! Thanks! Matte black too.
02-04-2010, 05:41 PM | #52 |
Rep 2,036
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Wow, looks great John!
If you still haven't gotten an alignment, then I think I'd "pull the pin". The extra camber will probably fix the front rubbing easier than fender work.
02-04-2010, 06:41 PM | #54 | |
aka 1013MM
1246
Rep 9,545
xray eyes haha
02-04-2010, 10:40 PM | #55 |
Rep 2,036
Did you have your alignment rechecked after installing your springs? Most let the springs/coilovers settle for a week or so then have it done.
Actually it probably would not mess up your alignment if you just removed the pin at the top of the struts and moved them in as far as the screw holes will allow. This will probably give you enough camber to stop your rub. Too much camber though and you'll wear out the insides of your tires too fast. What center caps are you planning? Did you get some wheel locks? I even struggled with lug color and finally went with a set of polished gorilla lugs and locks.
02-04-2010, 10:44 PM | #56 | |
aka 1013MM
1246
Rep 9,545
I already want coils lol.
02-04-2010, 10:46 PM | #57 |
E30 Addict
38
Rep 590
So you are rubbing up front with 452's in 235? That is so odd, Eyeman and myself both had that same set up with no rubbing. Do you rub alot, or just on hard dips?
What mad to go with 40 series in the back as opposed to 30? BTW the car looks awesome.
02-04-2010, 10:49 PM | #58 | |
aka 1013MM
1246
Rep 9,545
As for why 40 and not 30 in the rear.... believe it or not we could not find a 255 30 or 35 for the rear from Falken Does it make that much of a difference? BUT I'll double check in the morning to see if it really is 30 or 35, maybe I just misread.... Cause I don't see it.
02-04-2010, 10:58 PM | #59 | |
E30 Addict
38
Rep 590
Yeah a basic roll up front should do that. Only under really hard dips would mine make that sound. I could never find anything on the tire so I left it. Removing the pin should also help. My springs were really squeeky at first so give that some time. Look around the rear for any missing paint to see if it is rubbing. The 35 series should rub less as it is less tire. I think it looks fine as it is though, and it is safer. Just do a mild roll in the back and you should be fine.
02-04-2010, 11:23 PM | #60 | |
Rep 769
Your front looks ok, but your rears look like they'll be the problem. You're way jacked up in the back so if you're not rubbing already, when you lower your rears an inch or so it probably will. With your offset and tire size you're pretty close to what I have, which was a bitch to fix. I used to rub all the time, and it was pretty annoying. I had my rears rolled twice, and had some negative camber put in (-1.5 degrees or so should do), and I had to set my suspension to a little firmer than what I had. Although I'm not sure what suspension setup you have. If it's coilovers, set them to a firmer setting. Safe to say now I'm rub free, even with 4 people + crap in the car. Although YMMV since you have 265 vs my 255, but your offset is 45 and mine is only 40. As for the fronts, I hope you're not rubbing because there's not much you can do about it except trimming the inner plastic a little, but that's kind of pointless since you can just let the tire rub it down anyway. Again, it's just plastic so there won't be any rust issues. Maybe negative camber, I put -0.9 up there I believe. edit: just read you have 40's in the rear... I know it sucks since you already have the tires but I'd try and get 35's in the back if at all possible. 40 will just make the diameter too big, and hence more rubbing.
02-05-2010, 01:02 AM | #61 | ||
aka 1013MM
1246
Rep 9,545
As for the rear, I don't think I'm rubbing actually, I have yet to seat 4 people, but I guess I'll try it out after it all settles and see if the rears rub. It might just be hitting the plastic tab which I plant to cut down in the front and the back. I also think the rear is 255/35/19, I probably misread the first time. Quote:
Right now I have 235/35/19 front and 255/35/19 rear just to clarify. My bad... Thanks guys for the input! I'm not that scared about rolling now.
02-05-2010, 01:03 AM | #62 |
Rep 3,479
Drives: 19 M2C 6MT
Look sooo amazing dude...awesome..just awesome
02-05-2010, 01:43 AM | #64 | |
aka 1013MM
1246
Rep 9,545
hahahahah we so do have GREAT trunk space
thanks man! where are your wheels man?! Thanks!
02-05-2010, 01:47 AM | #65 | |
Rep 769
02-05-2010, 01:50 AM | #66 | |
aka 1013MM
1246
Rep 9,545
