      04-20-2010, 01:48 PM   #23
miro2296
miro2296's Avatar
I am running 19X10's(265/30/19) in the back and no rubbing. i am still on stock suspension though, but i believe tire choice usually makes or breaks the rubbing issues on custom wheels.
      04-20-2010, 06:29 PM   #24
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
Originally Posted by Eyeman View Post
Wishbone, that's a similar setup to what a lot of us run. On the stock suspension you'll have few options. Where you'll have to be very careful is if you lower. I'd for sure try to get a 255/30 rear in a tire that tends to run small. That pretty much means Toyo T1r's to me. I'd use 225/35 fr to play it safe but a Toyo 235/35 will work also.
Adrean, I'm confused. I thought you asking about what to buy. As for your wheels, no doubt they are great looking but also no doubt they did not provide you good offsets. There have been others with custom wheels that had the same problem. I bet much of the problem comes from the fact that it's just hard to get a wheel to look good when you make the offset in the +52 kind of range.
Yeah I had to set my suspension back to stock heights and I was rubbing on dips with the Goodyears and really rubbing with the Yoko's...the offset is obviously off and I hope that they will fix it without a huge fight....right now it is more a pain in the a$$ and time lost right now.
I was more asking about issues others have had getting 19's to fit properly WITHOUT a lot of fender modification or playing tire roulette.
SGM was God's color and has been recalled to heaven.
      04-20-2010, 10:37 PM   #25
WishBone33
Japan
14
Drives: SGM 135i
So what offsets did they send you, adrean?
      04-20-2010, 10:56 PM   #26
91Kevin
Drives: White 2011 Subaru STI
I was on Advan RZs
19x8 front
19x9 rear with a 50mm offset
I had AD08 tires all around in a 235mm width, and Im lowered on coils about an inch and a half. I rubbed in the rear even with that, and it actually cut part of the sidewall of my passenger side rear tire.
itll be difficult. The car is in the shop now getting my rear fenders rolled and basically pulled out lol
      04-20-2010, 10:56 PM   #27
mshahidz
Drives: M4, 991 GT3
Adrean, the fact that you are running round side-walled tires seems to be the problem. Specially ad08's along with any other ultra high perf. rubber is rounded. However, that SHOULDNT be your problem as you're running a custom set up.
Hope it gets figured out for you.
I have 19" LM's on the way, 245/30/19 in the rear, 225/35/19 in the front.
JRZ RS2 | Capristo | Eisenmann | Volk Racing TE37SL | Endless Brakes |
      04-20-2010, 11:06 PM   #28
91Kevin
what are the offsets on the LMs you've ordered?
Those are the wheels I always wanted, but i thought they didnt fit
      04-20-2010, 11:17 PM   #29
WishBone33
Japan
14
Drives: SGM 135i
Do you guys think i'll be straight with
19x8.5 et45 with 225/30/19 toyos
19.9.5 et48 with 255/35/19 toyos
on stock suspension?
      04-21-2010, 12:40 AM   #30
mshahidz
Drives: M4, 991 GT3
they dont fit, but i plan to make them
19x8.5/9.5 +30
      04-21-2010, 03:27 AM   #31
mshahidz
Drives: M4, 991 GT3
Am i the only who see's everyone using the WRONG tire size?
I ordered 245/30/19 and 225/35/19
everyone is going to be racking on at least 4% more mileage on their cars!
We have to run at least a 30 series tire in the rear for 19s, and 35 series up front!
      04-21-2010, 04:08 AM   #32
WishBone33
Japan
14
Drives: SGM 135i
Sorry mohammadz! I'm clueless when it comes to wheels and tires that's why i was asking. Could you explain why we need 35's in the front and 30's in the rear? Also, why 245's instead of 255's?
      04-21-2010, 07:02 AM   #33
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
Good training!
http://www.tirerack.com/tires/tirete...jsp?techid=46&
      04-21-2010, 09:46 AM   #34
Eyeman
Eyeman's Avatar
121
Wishbone, you just wrote it down wrong, otherwise it should work. You need 225/35fr and 255/30r. That will work with those wheels and your suspension. I doubt it will ever rub but if it does it will be when you have a few passengers and the passenger side rear fender will rub a little.
      04-21-2010, 02:26 PM   #35
WishBone33
Japan
14
Drives: SGM 135i
anyone have any recommendations on tires? I was thinking toyos but they are too expensive. anyone with experience with hankooks?
eyeman, are you saying that i might rub with passengers in the rear seats or do you think i would rub with just 1 passenger in the passenger side?
      04-21-2010, 02:41 PM   #36
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
I would recommend the Goodyear Eagle F1's or Nitto Invo's
      04-21-2010, 02:50 PM   #37
WishBone33
Japan
14
Drives: SGM 135i
Im assuming that these don't rub very much and are fairly affordable? I like the hankooks price but i'm not sure if they'll rub.
      04-21-2010, 03:18 PM   #38
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
The rub is dependent upon your offsets more than anything. From what I have heard from several vendors (with project cars) the Nitto's have the best "sidewall" for running 19's.
      04-21-2010, 04:49 PM   #39
WishBone33
Japan
14
Drives: SGM 135i
My vendor recommended toyos, kumho, general exclaim, and hankooks.
      04-21-2010, 06:52 PM   #40
Eyeman
Eyeman's Avatar
121
Wishbone, I'm sure that just Toyos and Falkens run so abnormally small and that seems to be your main concern. I just looked it up for you, with Falken FK452 you'd order 245/35 rears, with Toyo T1r 255/30. Basically those are your two choices given your concerns. So if you want to save go Falkens. With either of these choices you might rub a little if you have 200+ lbs of passengers in your car. If you chose any other tire you are likely to rub more. The cheapest tire I know of that runs small are Nexxens but they don't come in our sizes.
      04-21-2010, 07:08 PM   #41
ptack
ptack's Avatar
2008 135i  [6.50]
Hankooks seem to have a pretty square shoulder so I think they are more likely to rub that Toyos.
      04-21-2010, 08:01 PM   #42
WishBone33
Japan
14
Drives: SGM 135i
Alright now I'm really confused. My vendor told me that the falkens would def rub because falkens are known to be "oversized"? I'm not sure what that means but I'm totally confused.
      04-21-2010, 09:06 PM   #43
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
Ok so lets put it this way Wishbone....On 19" wheels w/stock suspension you will not rub in every day driving (given that the offsets are correct for whatever wheels you purchase) this is with pretty much what ever tire you choose.....BUT....if you hit a doozy of a dip or have heavy passengers you will have a slight to moderate rub.....that is part of the reason I opened this thread, because I do not think I have heard of ANYONE with 19's with ZERO rub without some type of fender mod.
**Addendum** This is with 255/30's for the rear tires...
      04-21-2010, 09:20 PM   #44
WishBone33
Japan
14
Drives: SGM 135i
Sorry adrean, i kinda feel like i hijacked your thread lol. Anways, what would be considered "correct" offsets? I got et45 front and et48 rears. I know in the rear, the higher the offset the better it is. This has the be the most confusing car the try to buy proper wheels and tires for.
