      07-21-2010, 05:56 PM   #1
schmeah
Drives: 2011 135i
Any N55 HPFP failures yet?
Or any other major problems? There were reports of several HPFP failures with the N54 as early as 1-2K miles. I have a 2011 135i DCT with 2200 miles on it (early May pick up) and am keeping my fingers crossed. I came from a 335i 6MT and so far am very impressed. Not crazy about the paddle shifters moving with the wheel or that it will downshift for you even in M mode if it thinks that your not doing it right. Otherwise no complaints.
      07-21-2010, 06:39 PM   #2
bryce
Drives: zhp 3-pedal
i haven't heard of any myself......just a report or two i've read online from a dealership w/ an n55 having long cranks, that's all.
      07-21-2010, 07:41 PM   #3
MarkR171
MarkR171's Avatar
102
2019 BMW M2C  [0.00]
I had a couple 2-3 second cranks when the car was still in break in stage. That made me a bit nervous, but now at 2600 miles, it starts right up as soon as I touch the button, every time.
It will only downshift in M mode if you go under 1k RPM so you don't stall, nothing wrong with that. You won't be getting that low in rpm unless you're in traffic anyway.
2019 M2C - Alpine White - 6MT
2023 Supra 6MT - Deposit and Wait
      07-21-2010, 09:07 PM   #4
schmeah
Drives: 2011 135i
I've driven a manual tranny the last ten years and have never stalled, so I know how to shift. It consistently seems to downshift before I get a chance to when pulling up to a stop sign or red light. Sure it's not a problem. but it takes some of the "manual" feel out of the DCT. Also I hear it upshifts when you red line though I've not yet pushed it that hard to find out.
      07-21-2010, 09:28 PM   #5
MarkR171
MarkR171's Avatar
102
2019 BMW M2C  [0.00]
I'll agree with you there, when I have it in Manual mode in traffic now, I tend to just let it downshift on it's own.
Also, it does upshift at redline, but I don't see that as a problem either, bouncing off the rev limiter isn't exactly good for the engine nor is there really any benefit to it. Takes away from the 6MT feeling, but this isn't a 6MT.
      07-22-2010, 07:20 AM   #6
OhDasCrazy
SuperNoob
OhDasCrazy's Avatar
Italy
Drives: 2011 Sonic & Knuckles 135i
Automatics are known to do that from time to time.
-OhDasCrazy-
2011 135i /// 6MT /// SONIC & KNUCKLES /// M-SPORT /// HK /// COMFORT ACCESS /// HEATED SEATS
      07-22-2010, 02:59 PM   #7
IS+1
Drives: 2017 M2 (AW 6MT)
To respond to the OP's question, I picked up my 2011 6MT on April 21, and 3 months later it now has over 12,000 km (7500 miles!!)
Aside from two isolated sound system/speaker anomalies that each occurred only once, the car has not missed a beat. The N55 has started immediately every single time I pushed the button since the day I took delivery. I love this car! We are indeed a fortunate bunch.
      07-22-2010, 04:41 PM   #8
N55_NOLE
Drives: 2008 550i
7,000 miles! I thought the 4,700 on mine was a lot! No issues so far for me either!
      07-22-2010, 07:21 PM   #9
schmeah
Drives: 2011 135i
So exactly how do you define an automatic? (better do your reading before responding)
      07-22-2010, 07:23 PM   #10
schmeah
Drives: 2011 135i
Man, I hope your not leasing that puppy...
      07-22-2010, 07:28 PM   #11
IS+1
Nope, cash purchase... this car is worth every penny.
      07-22-2010, 09:05 PM   #12
RPM90
Drives: 340i M-sport AT
I define an auto "automatic" trans as a trans which uses a torque converter to couple engine power to the trans, and then the shifts are done without further need for driver input, once the forward "drive" is selected.
An "auto-manual" is, again, a torque converter transmission that can take driver input as to which gear the trans will automatically switch to.
An dual-clutch, SMG, DCT, DSG, ect...is a clutch coupled trans in which the clutch engage/disengage is operated automatically, with the ability to change gears automatically as well. Also, it has the ability for the driver to select which gear the trans will automatically engage when driver input is given.
So, basically, it comes down to how the engine power is coupled to the trans. A "true" automatic trans has a torque converter.
The feel of the shift is different between a TC automatic and a true clutched trans that can operate automatically.
A TC can pull off softer and smoother shifts as it has a soft coupling (fluid), whereas a clutched "auto" trans retains the more direct, and harder, shift of a true manual.
They each have their own appealing qualities.
      07-22-2010, 10:49 PM   #13
RPM90
BTW, given the title of this thread, where are all those failed N55 HPFP's?
I would think a thread title like this would at least get 1, no?
      07-23-2010, 12:58 AM   #14
Remonster
Drives: E90 M3
Anything without a clutch pedal.
      07-23-2010, 09:48 AM   #15
wcadrin
Drives: 2008 M3 Sedan
Picked mine up on June 24 and have 4200 miles on it. No problems to report.
      07-23-2010, 10:33 AM   #16
KingOfJericho
KingOfJericho's Avatar
Drives: Yes
2010 135i Coupe  [5.26]
This.
If your left leg is not moving, you're driving some form of an automatic.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold
      07-23-2010, 10:44 AM   #17
jeremyc74
Drives: '08 135i Montego/Terra
By very definition "automatic" means it shifts by itself. Throwing the torque converter in there is pointless. Do you not consider a CVT an automatic? All torque converter based transmission can take driver input for gear selection. Calling them manuals because of that is just marketing BS.
DCT is an automatic transmission. It shifts automatically. That doesn't means it's the same as a traditional torque converter based transmission, but it's damn sure not manual in any sense of the word.
      07-23-2010, 01:18 PM   #18
schmeah
Drives: 2011 135i
That's why I shake my left leg around quite a bit when I'm paddle shifting and leaving that "real manual" 135i guy in the dust.
      07-23-2010, 05:43 PM   #19
bryce
Drives: zhp 3-pedal
      07-23-2010, 05:44 PM   #20
bryce
Drives: zhp 3-pedal
      07-23-2010, 05:47 PM   #21
jeremyc74
This.
That's not exactly true either. Sequential manual race boxes with straight cut gears are manuals, but you don't use the clutch.
For example:
Of course, you're not likely to see that in a typical street car.
      07-23-2010, 06:08 PM   #22
Robert
Drives: 135i -> is350 -> Tesla M3 perf
I am going to start off saying I agree 100% but here's my question.
If the manual mode lets user select gear no matter what. (won't upshift or downshift) Does that constitute as a manual? Does manual must include a clutch or simply implies user selection of gears.
I guess you just answered that question above
