      04-06-2011, 03:18 PM   #23
YoKev
Drives: 335i Coupe
Originally Posted by techthentic View Post
First off, I applaud you for yet another attempt at "135i > overpriced/under-engineered/under-powered/not-a-real-M-car 1M".
Unfortunately, I am not here to coddle your ego over the fact that your 135i is no longer top dog in the 1 family.
To begin, between performance suspension and the stock 135i and sport packaged equipped 135i; ride height is lowered by 25mm and 10mm respectively, and spring rates are +48% and +34% respectively.
These simple improvements in making the car stiffer and lower is why you notice a decrease in nose dive, squatting, body roll, and under-steer.
While those numbers might give you a boner and inflate your ego, in the grand scheme of things, just modifications to spring rates and ride height mean jack shit.
M3 vs 335i, and thus 1M vs 135i also feature differences in ride height and spring rate; but your performance suspension ONLY alters these two components, whereas between the 1M and 135i differences also include the facts that:
1) The suspension geometry is completely different and vastly superior; the M-division doesn't just sit around slapping more powerful engines and a lowering kit on their cars, they dump a lot of r&d on chassis.
2) The suspension arms are forged aluminum vs cast aluminum/steel; stronger and lighter.
3) The significantly widened track; wider track improves handling and allow wider tires which also improve handling.
4) Individual suspension components are also improved upon not to mention countless other components such as larger mount points, different springs, chassis and suspension reinforcements throughout, arm control sizes, bushings, etc
^ All of that PLUS the differences in spring rate and ride height between the 1M and 135i make it a FAR superior handling machine, and as an extension superior than your performance suspension equipped 135i with just spring rate and ride height adjustments. And this is far superior handling even BEFORE a LSD.
With the M-Diff, its not even comparable.
Anyways,
Thanks for playing
Wow..
More proof that an internet connection and keyboard = 'Internet Expert Commando'. And a bitchy one at that
Please explain how in your world a 'wider track' 'allows the use of wider tires'.
In the real world, wider wheels, and depending on their width, wider fenders is all that's needed.
Taking it a step further, you can run the widest wheels with the 'widest track' in the world, and it won't do a damn thing for you if you aren't running the right amount of negative camber. You'll simply roll up on the sidewalls of your $$$ tires, and be slower than you were with stock tires.
To address the OP's question about 135 being able to out handle a 1M with suspension work....OF COURSE IT WILL. Every single mass-produced, street legal car is built with compromises. Even BMW's M's.. If BMW made the 1M with track speed the only goal, it would ride like wood, and chew up tires in less than a 1000 miles. Since most people who buy these things not only drive primarily on the street, but NEVER even see the track, very very few would sell. The car rags ripping them up one side and down the other for having ZERO street manners wouldn't help either....neither would the multiple law suits from people who lost control of 'em while driving over a pot hole, and running into a light pole.
Contrary to this, what YOU do to your car is only limited by how much you want to move towards track orientation and away from street comfort. Moton/Ohlins etc.. produce light-years better shocks than the stock 1M's units, and the aftermarket is full of suspension pieces for the 1 series that when properly mounted, will leave ANY stock 'M' in the weeds, when properly set up. The down side to this is if you plan on driving your car on the street you'd need a kidney belt, and a set of the hardest compound tires you can find, as the only part of the tires that will be touching the ground in 'normal' use would be the extreme inside edge.
Upside is, when you get the thing on the track, you'll need a flak jacket to protect your ribs, as the thing will corner like a go kart.
I've personally gone this route before, as luckily for me at the time the car was not my primary, and I had a trailer to haul it back and forth to the track.
The REAL question is, how much modification/improvement can you do to a 1-series' suspension, yet still retain decent street ride quality and tire life.
If you only drive your car on weekends, equating to only a couple hundred miles a month, then you'll probably be willing to deal with a stiffer ride and shorter tire life on the street in order to gain quicker lap times and longer tire life on the track.
Point being, the answer to the aforementioned question is going to be different for each individual car owner.
      04-06-2011, 03:41 PM   #24
1SerieStud
1SerieStud's Avatar
183
Drives: '11 VO 1M (498 of 740)
Thank you for your detailed response. I truly appreciate you taking your time to put something together in so much detail. While I agree with every single point you made, your response slightly deviated from the main point in mind: I was comparing the BMW Performance suspension (which is a BMW-provided upgrade for the 1-series), to the stock upcoming 1M suspension, simply because I do keep warranty in mind. Also, my 135i already has the Performance suspension installed, which is leaps beyond the stock suspension that comes on the car, and I was just curious to see if my car will continue to fall short of a 1M's handling, of course not taking into account the lack of LSD and narrower track with obviously smaller wheels/tires.
Thanks!
Originally Posted by YoKev View Post
Wow..
      04-06-2011, 05:15 PM   #25
EmmDrei
Drives: 2011 Saphire Black 1M Coupé
@OP: That's all theory and in itself fine and dandy. There is one simple answer: drive a 1M and you'll feel the difference. Imho its suspension suits the 1M even better than it does the M3. Yes I have the latter and I have driven the former. If your 135i outhandles an M3 (which I seriously doubt), then you stand a chance against a 1M. A slim chance. The 1M is lighter and shorter than the M3. Rear wheel drive without a lsd is pointless, performance wise, provided the car has grunt and both the 135i as well as the 1M do. That alone makes a world of a difference. And as far as improving the 1Ms suspensions... I honestly wouldn't know how! Granted you can lower the car and make it look better, but as long as the goal is "daily driver" with an occasional "track option", then imho you cannot set that suspension up any better. The car works on lousy roads, even on cobblestone and yet and still it gives you a cart-like feeling and precision. It really speaks for itself and that is about the best you can say about any cars setup.
The best piece of road - worldwide.
      02-10-2012, 12:10 PM   #26
Rana135i
Drives: 2011 135i Matte Metallic Blue
What kind of exhaust system you have in that 135i image?
