      07-25-2021, 06:54 PM   #45
JimD
JimD's Avatar
368
Drives: 128i convertible
Since my earlier comments I finally had to replace the battery in my 2009 e88. I went to Walmart and bought a battery. Then I used INPA to register it. Walmart doesn't tell you the amp hour of their batteries so I just set it to the same size as the original. It should be close. Later I bought a "Autophix 7810" BMW specific code reader. I says it will code batteries. I checked on my INPA work and found that the date had indeed been updated.
INPA is, of course, available free but you need a cable to connect your computer to the OBDII port of your car. My Autophix 7810 was about $100. I got it to find out which wheel had a bad abs sensor. (both fronts failed, one at a time) For any one repair is is probably cheaper to just pay somebody but it clearly saves money if you use it more than once. INPA is easier than NCSExpert to use but still it is not easy. The Autophix tool is quite simple to use.
bmw1racer998.00
      11-01-2021, 05:32 PM   #46
Dazo
Drives: Bmw m140i
Easy to register battery now with bimmerlink & bimmercode.
      11-01-2021, 06:06 PM   #47
markslc1
Drives: 2011 1M, 14 X5 x35i
I was reading the earlier parts of this thread and read the claim you could not switch from AGM to standard battery types. Bimmercode made it easy!
      11-05-2021, 08:39 AM   #48
m_thompson
m_thompson's Avatar
Drives: M-Sport 128i, 328xi, 3.0CS
2009 128i  [0.00]
1972 3.0CS  [10.00]
I tried to register the same size and type of battery with Carly. It could read the current battery configuration, but could not register the new battery. The Carly people don't know what is wrong and can't fix it. I used BMWLogger to register the new battery in just a few seconds. I then used Carly to read the configuration, and the new battery was registered correctly.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
