04-28-2014, 12:15 PM | #67 | |
Rep 129
I checked mine and it has very little play, a lot less than your old valve. |
05-10-2014, 09:23 PM | #68 |
Rep 799
Ok, I solved my rattle issue. For real this time.
90% of my rattle was coming from excessive play in the valve, as I mentioned in an earlier post. The other 10% was due to a broken exhaust bracket. See pics below. |
05-13-2014, 02:39 PM | #69 | |
Rep 129
That is the support for the mid-section, isn't it? It's a shame that failed. If I remember correctly you have the full Akra system installed, didn't you? If i were you I would definitely contact Akra directly and let them know they let you down, both with the support as with the valve; I know I would appreciate a mail like that if it was my product that was sold. Although a small mistake like that can happen, I expect a high quality product buying from them. Nevertheless it's a simple repair judging by the pictures, just have it (re-) welded at a local millwright shop. |
05-13-2014, 08:39 PM | #70 |
Rep 799
Thanks 1mmaniac.
I guess I left out a big part of the process. I have the full Akrapovic exhaust system. When I found out that my valve was causing some rattling, I contacted Akrapovic with the intention of a work around. Not only did they respond in a very timely and helpful manner, but they offered to replace the valve free of charge. The only catch was I needed to ship the old one back. (I imagine they want to examine the defect). While swapping out the vacuum line, I reached over under the car and shifted the exhaust around. I could hear some faint metal on metal sounds until I zeroed in on the bracket. At that point it was obvious. I simply removed the bracket but left the part that joins the two pipes together behind. I reached out to Akrapovic and they shipped out a new bracket the following day.. I was so focused on the rattle that I didn't really talk about how awesome Akrapovic is to deal with and how well they stand behind their products. I wouldn't hesitate to buy one of their products again. |
05-14-2014, 11:10 AM | #71 |
Rep 839
Drives: BMW 1M VO
Guys, I'm interested in investing in the full system but I was wondering if any of you know if there's a way to prevent the yellowing of the titanium? Can the whole exhaust system have opti-coat or cquartz applied to it or have some sort of protected coating applied to it to avoid the yellowing?
And if it does yellow, is there a way to clean that off or is it permanent? |
05-14-2014, 03:10 PM | #72 | |
Moderator
29357
Rep 13,097
///M is art ↔ Artemis
05-14-2014, 03:35 PM | #73 | ||
Rep 129
You have some sweet rattle-free miles ahead buddy It'll feel like driving a new car now you're no longer irritated Quote:
http://www.1addicts.com/forums/showthread.php?t=757720 Simply put, this discoloration is caused by heat. I don't know the exact numbers but google shouted out that Ti oxidizes from 500 degF and up. The colors change in ratio with the temperature and/or exposure time of the material. The discoloration shown in the picture linked above is way, way worse then on my own (slip-on only!). I only have a straw/brownish colored glaze on the mid section of the muffler and a bit on the tips. These are first colors appearing in this process. I assume the system linked above has seen some long hard runs, maybe track or dyno judging by the colors seen, the amount of material that has changed color and the 2k miles. I should be removable by removing the top layer of material, so polishing or brushing should do the trick for the lighter colors. Pink, Grey or white will probably stay on permanently but i have no experience with any of this on titanium myself. I don't know if there are clear coats available for this application, I doubt it. |
05-14-2014, 04:31 PM | #75 |
Moderator
29357
Rep 13,097
The information several months ago was that production was discontinued (quite logically, given the limited production run of the 1M). But there are still in stock, I guess.
05-21-2014, 10:04 PM | #76 |
Work Hard! Play Harder!!
47
Rep 193
Drives: BMW 1M, BMW M3 CS
It would be nice to get a Group buy organized for the Akro 1M exhaust.
05-22-2014, 09:17 AM | #77 |
Rep 2,898
05-22-2014, 07:55 PM | #78 |
47
Rep 193
I still see them available at many vendors, however the prices are rediculous. Largest discount was 10% at Vivid Racing
05-22-2014, 08:18 PM | #79 |
Rep 4,744
Just ordered one today. The manufacturing of the exhausts are discontinued however akra has a stock of them.
05-22-2014, 09:17 PM | #80 | |
Rep 1,293
You're absolutely correct that the discoloration is oxidation caused by heat. I have an Akrapovic EVO full titanium exhaust on my Yamaha R1. Almost immediately the headers turned bronze. The bronze turned to light blue, then deep purple/blue/green. The color eventually moved its way all the way to the carbon fiber cans. However, given enough time and heat, the headers turned to a dull gray. I've tried everything to polish off the oxidation and have found nothing seems to work. If you rather have blue tips instead of bronze, I'm sure you could hit them with a propane torch and get the effect. Problem is...if you don't like it, it's not reversible. |
05-22-2014, 09:50 PM | #81 |
Rep 4,744
My friends have the akra exhaust on their m3's. I love the bronze color it turns. Looks awesome.
05-22-2014, 10:15 PM | #82 |
Rep 1,293
05-31-2014, 05:30 PM | #83 | |
Rep 129
I've only heard a 1m, 2011 m3 and 2013 sls amg irl with an Akra.... it rocks on an all of them this was my first aftermarket exhaust and I was shocked by the cost at first. But after doing some research on other brands and eventually having it installed it was totally worth it. If i every buy another performance car ever again I'll be looking for an Akra first. |
05-31-2014, 05:31 PM | #84 | ||
Rep 4,744
06-13-2014, 02:28 PM | #85 | |
Rep 129
BTW, mine i running and sounding like before again To be honest I don't know exactly what the root cause is because a couple of things changed and the 'return' was not as sudden: - the weather has been quite a bit warmer the last couple of weeks - I've done a few long runs where I changed the load significantly, long WOT pulls from 1000 to high rpms and longer runs driving higher rpm's - did the 'reset' throttle response, I honestly didn't feel any change - I'm driving a lot more with the valve closed (white/silent mode). This is relative since I ALWAYS drove with the valve open, I think it's 50/50 now. |
