      10-22-2013, 06:36 AM   #45
octainejunkee
octainejunkee's Avatar
Drives: M3 f80 Comp, MPE, stage 1
Great thread
Can somebody tell me how much these would be in the uk and where i can get them from please?
Cheers Jamie
BSM 1M owned from new.
      10-22-2013, 07:34 AM   #46
gibbo21
Drives: 1M Coupè
I have a question: Is it possible to install the e92 Bmw M3's Coilovers on my bmw 1M. These coilovers are the same?
Thanks
      10-22-2013, 08:54 AM   #47
dEvo6
Drives: 1M
Thanks
The answer is yes
      10-23-2013, 12:45 PM   #48
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Originally Posted by octainejunkee View Post
Great thread
Cheers Jamie
Sent you a PM!
Thanks
Yes, they will fit. However, you will not follow the recommended settings from the instructions as the 1M weighs much less, but rather use it as a guide.
      10-24-2013, 11:42 AM   #49
gibbo21
Drives: 1M Coupè
Thanks for the answer ;-)
Hi devo6!
      11-28-2013, 03:37 AM   #50
gibbo21
Drives: 1M Coupè
Hi, i have just mounted the ohlins R/T previously mounted on a bmw m3 E92 in my bmw 1M. But there is a problem: the rear height is too high! More than stock
The Mechanic also said to me that it is impossible to lower the car more.
Rear:
Front:
      12-08-2013, 01:15 AM   #51
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
Rear:
Front:
Very odd. I adjusted the spring perch to the lowest point and my tires were nicely tucked under the fender. You should remove one wheel to verify if your spring perch is maxed out.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      12-08-2013, 09:32 PM   #52
TXmtrhed
TXmtrhed's Avatar
37
Drives: VO 1M
Make sure the spring perch was installed correctly.
      12-11-2013, 10:38 AM   #53
schnite
Drives: E82 1M
KW clubsport and ohlins which is sport ?
      01-17-2014, 12:08 PM   #54
HP Autosport
Drives: F80 M3
You will get both a better ride quality and performance with the Ohlins R&T. The DFV is where it's at for a Dr. Jekyll and Mr. Hyde personality.
      02-20-2014, 10:51 PM   #55
SpencerMH
SpencerMH's Avatar
Drives: 1M, M6 GC, 718GT4, F355GTS6
I'm looking at a set of these from an e92, should I worry about gibbo21's pictures? Was his install definitely messed up and i should buy the e92 set with no worries?
BSM 1M, MCS Coilovers, Pure Stg 2 Turbos, Walbro LPFP, JB4, BMS E85 Flash, ECS CF sealed intake, N54 Tuning DP's, Evolve Race Exhaust, Wagner FMIC, Stett CP w/ Tial BOV, ST BBK, Big Tires.
M6 6MT Gran Coupe w JB4, 718 GTS, Lotus Esprit V8TT, Duc 998SBayliss
      02-21-2014, 11:51 AM   #56
Flatout
Sweden
Drives: 1M AW 2011
Rear:
Front:
Check if they removed part 10.
http://www.realoem.com/bmw/showparts...10&hg=33&fg=45
      02-21-2014, 11:54 AM   #57
Flatout
Sweden
Drives: 1M AW 2011
Rear:
Front:
      02-21-2014, 11:54 AM   #58
Flatout
Sweden
Drives: 1M AW 2011
Rear:
Front:
      02-21-2014, 12:55 PM   #59
HP Autosport
Drives: F80 M3
There should be enough adjustments to lower your 1M below stock height. Double check your installation to make sure everything was installed properly.
      03-04-2014, 08:05 AM   #60
Aqua
Taiwan
23
Drives: 1M
Is there an actual set that says it's for E82 1M on the box. Or are all the sets for E9X M3?
      03-04-2014, 08:20 AM   #61
MDORPHN
Drives: AW 1M
Suspect they all say E9x M3.
Neil
      03-22-2014, 08:29 PM   #62
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
Neil
+1 it's an E9X M3 kit.
2017 F80 M3/AW
      03-31-2014, 12:40 AM   #63
Aqua
Taiwan
23
Drives: 1M
I finally got my ohlins installed with Vorshlag camber plates. What is the ideal stiffness for a street setup? Im driving on fairly bumpy roads most of the time.
Also should the fronts and rears be same stiffness or the rears slightly stiffer?
      05-07-2014, 11:57 PM   #64
obiwun
obiwun's Avatar
Drives: AW(well very dirty) 1M
Ok,
I have just installed my Ohlins R&T and I have a few questions to anyone who can answer me.
- Usable clicks. There appear to be more than the suggested 20clicks of adjustment. Can I go softer than the twentieth click and will this damage anything or actually continue to adjust the damper?
- Rear Adjuster Extension. I have ordered the extender for the rear adjuster. Can someone please give me a measurement so i know where to cut a hole in my boot liner?
- Orientation of Sway bar bracket. I roughly oriented the front shock so the Ohlins sticker faces out and the dropper link is fairly well aligned with the sway bar. Is there anything more that I should take into consideration here?
Thanks
Toby
      05-08-2014, 11:20 AM   #65
///1M
Drives: On a good day, AW 1M coupe
Obiwun,
Do you prefer the Ohlins to stock?
      05-08-2014, 06:01 PM   #66
MechE
Drives: 2011 1M
Adjustment range:
Based upon memory, I found that the front struts had about 28 clicks or total adjustment and the rear shocks about 36 clicks. During my limited testing, I felt that adjustments beyond the 20 click range from full stiff didn’t cause damage, but they also didn’t work very well. At over 20 clicks it seemed like the Dual Flow Valve might have been too free to move because the dampening was inconsistent. The car was almost under damped for small movements and then abruptly transitioned to normal dampening over larger movements. The transition was not pleasant when entering a corner. I settled on 13 clicks from full stiff for daily driving. Due to the different total range of adjustment front to rear, I think it is very important to base all adjustments relative to full stiff.
Adjuster extensions:
Sorry, I can’t find my notes as to where I drilled the hole in the trunk liner, but I can describe the process. First, I temporarily installed the extensions on the shocks, and then measured the position of extension shaft relative to one of the liner mounting holes on the chassis. I then transferred this measurement to the liner itself starting from the corresponding mounting hole in the liner. Make sure to account for the slight offset in position due to the angle of the extension shaft and the gap between the top of the shock and the bottom of the liner. Fortunately, the extension shaft is flexible so it can compensate for small errors in alignment.
Orientation of sway bar bracket:
You should rotate the strut so that the rod ends on the link are in the center of their range of travel and therefore have maximum range of motion. If the strut is rotated too far in either direction, the rod ends might bind.
Overall, I think the Ohlins were a GREAT upgrade. At 13 clicks from full stiff, the car rides over small bumps (road reflectors) with much less harshness and motion while also feeling much better planted at high speeds. I also like the way it settles much faster from larger bumps and dips without being jarring. That said, it can feel pretty stiff over very large bumps. After the upgrade, the car feels like it is riding on a more expensive and sophisticated suspension. It just feels more refined. I’ve had the chance to compare my car back to back with an almost identical car on the stock suspension, and I’m definitely keeping the Ohlins.
