06-18-2014, 08:48 AM | #23 |
Workin' hard
17
Rep 162
I don't think it weighs quite that much. The suspension pieces are the heaviest part. I worked at Rallysport Direct and took pictures of these kits when they first came in which meant pulling every single thing out of the box.
06-19-2014, 05:41 AM | #24 | |
Rep 45
The tank is extremely light, aluminum. I made the brackets from alum. so not much there, either. The pump is lighter than I thought it would be. I'll try and get numbers. The valve block is not that heavy either. The air hose I made is very light plastic tubing. A vid of my nephew letting the air out Last edited by mimtbr; 06-26-2014 at 06:00 PM.. |
06-23-2014, 02:09 PM | #25 |
Rep 278
Nice to see that airlift finally relased the rear kit i had the Airforce sleeve bags and it was awful had to have 100+ psi in the rears to have a drivable ride height and even with koni adjustables in the rear it was still way too soft. I dont have my 135i anymore but plan on getting an e90 in the near future to do equip with the new airlift rear setup. Any idea on official release date to the public?
INSTAGRAM:@add1ct 2010 E90 335I : FBO | M Sport Conversion | FK Streetline | 19" Apex Arc-8 (SOLD)2013 335i M Sport : FBO/Meth | BC Racing coilovers | 20" BBS RSII (SOLD) 2011 135i : FBO | Airlift suspension | CCW LM5 |
06-27-2014, 08:29 AM | #26 |
Rep 45
Finally hit the website!
http://www.airliftperformance.com/ve...-1-series-e8x/ 78510 - Performance Front Kit 78610 - Performance Rear Kit 27671 - AutoPilot V2 (1/4″ Air Line, 4 Gallon Tank, Viair 380 Compressor) Part #: 98010 full kit I checked Jegs, not up yet. Notes: I have the 2.5gal tank (Part #: 12958) in my car. The 4gal would not fit on the side where I have mine. Everything else is the same. Here is a list of basic control system part weights: Compressor = 8.88 lbs Manifold = 2.90 lbs Isolator brackets = 0.78 lbs Display = 0.22 lbs Wiring harness = 2.25 Alum tank = 3.77 Fittings = 2 lbs Air Line = 1 lb TOTAL = 21.8 lbs In most cases, it's in the trunk. Also, with most vehicles, this weight gain offsets the weight lost on the conventional steel spring/shock components. |
06-27-2014, 01:15 PM | #27 |
Rep 1,051
Donk/stance mods being marketed as "performance" parts for autocrossers? New one on me...
Same thing (same product for Imprezas) was attempted on a local Subaru forum and the poor guy got laughed out of the forum because the forum had dozens of experienced autocrossers on it. Not as many on this board (despite being an international forum).
10-08-2014, 08:38 AM | #30 | |
Resident Tamed Racing Driver
298
Rep 4,697
So it looks like the net weight change was a gain of 16lbs.
10-08-2014, 12:22 PM | #31 | |
Rep 777
Also, air springs are by definition extremely progressive (non-linear). Again the opposite of what is desirable in a "performance" application. As the OP points out he needs to crank the damping up and lower the car to get best lap times. This is more nonsense from a performance or ride quality point of view. An air suspension that supplements a conventional spring to adjust ride height makes some technical sense in some applications, because the non-linearity introduced by the air spring is small relative to the total spring rate. A pure air spring suspension has no place any car worth driving on a track. I am reminded of a cat that drags its ass on the carpet after having a crap when I see a car on deflated air springs. Correction, I am reminded of the crap it leaves on the carpet. |
10-08-2014, 12:39 PM | #32 | |
298
Rep 4,697
10-09-2014, 10:17 AM | #33 | |
Rep 4,040
Drives: 130i coupé ;)
10-09-2014, 12:48 PM | #34 |
Rep 1,026
10-09-2014, 12:57 PM | #35 | |
Rep 45
Road America BMWCCA Oktoberfast 2014 update
http://jalopnik.com/5974931/your-gui...-culture-donks Road America BMWCCA Oktoberfast 2014 update: I did 6 trackdays this year, Gingerman, Waterford Hills, and two days at Road America (a bucketlist item). Two sets of front 245 Hankook C71's, and one set of front Carbotec XP10s are now smoked. Switched from 275 Hoosier rears to 245 Hankook C71s (which allowed the rear to be lowered 1"). Road America...holy crap the place is fast and awesome! Mike Clemens was the organizer (1M). His car never ran right all weekend, but mine finally ran great! (Does the ECU need to "learn" after the COBB flash?) I got down to 2:47. Which is 11sec slower than Mike's 2:36. I heard James Clay ran a 2:34 in a 135. If you have never been to RA (and I had'nt), the track is 4miles and 14 turns. 4miles... Good times had, and I drove the car home, which is more than can be said by three M3 and one corvette drivers... Could I go faster? Maybe. The whole streetcar thing at that speed is a bit nutty. No rollcage, stock seat, stock seatbelt. I learned a ton about the track, so maybe next time. The "air experience" continues. Next to a Ferrari 333sp... Yes. Airlift company stuff. Not mine. |
10-09-2014, 02:48 PM | #36 |
Rep 2,384
this kit is $5,000 plus installation....a KW V3 kit plus camber plates, plus bushings, plus sway bars, plus toe arms doesnt even cost this much and will perform 100x better, just my opinion but this seems absurd from a handling performance perspective
10-10-2014, 07:57 AM | #37 | |
Rep 777
10-10-2014, 10:18 AM | #38 | |
Rep 45
$2,699.40 (Part #98010) one way adj. damper air setup with control system http://www.amazon.com/Air-Lift-98010.../dp/B00NWIX60S From Tirerack: KW Variant 3 Coil-Over Front and Rear fitment for 2009 BMW 135i Coupe $2,400.00 SPC BMW Ft Adj Upper Strut Mt Front fitment for 2009 BMW 135i Coupe $415.00 Total: $2,815.00 for a two way adj. damper coil over setup with camber plates |
10-10-2014, 11:20 AM | #39 |
Rep 914
Pretty cool. I finally got my air installed not too long ago, and do have to say that the ride is 10x better than on coilovers. As far as track performance goes, I'm not too sure, but I keep seeing numbers that state that air has pretty good times on the track comparatively.
Those wheels are Rotiforms IND wheel. |
10-11-2014, 09:48 PM | #40 | |
Rep 2,384
10-13-2014, 07:34 AM | #41 |
Rep 914
Directly from airlift will be more expensive for some reason. Bagriders has the full Autopilot V2 kit on their site for ~$3500 (without any discounts, they have a monthly discount that fairly often has the v2 management package).
http://bagriders.com/modlab/products...ANAGEMENT.html |
10-13-2014, 09:16 AM | #42 |
Inspiring the youth of tommorow...
37
Rep 333
I live in VA and the roads are terrible I have considered air, but in the end decided it was a terrible idea.. ill just stick with my properly designed and performing R+T setup...oh and slammed cars are hella Ghey....Hate u VW's ....end rant
E82 135i Jet Black over coral red
E39 Dinan 540i manual Topaz blue over beige F15 X5 35D Mineral white metallic over Mocha Nappa 991.1 911 GT3 Guards red over black alcantara P13 570GT MSO Volcano Red over saddle tan |
10-13-2014, 11:17 AM | #43 |
Rep 914
Are you claiming air isn't properly designed and that's why you decided against it or the price?
10-14-2014, 03:32 PM | #44 | ||
Rep 45
From the f30 forum: Quote:
