12-15-2016, 07:20 AM | #1 |
Rep 184
Agm Battery For 1m
So at dealer yesterday getting airbag replaced. Asked them to check battery and it's at 50% and needs replacing. It's original. Even though I've had it on the CTEK Charger for 6 months. It's time for a new battery.
From what I've gathered on this forum, (and since the original battery has been discontinued) looks like some recommend 61212353811 for a replacement which is 70, and with 680 CCA. Dealer said I should NOT use that battery because it is NOT an "AGM" like the original. So my question is has anyone discovered the best AGM replacement for the 1M original battery? Does it matter if it's not AGM? Thanks!!
'08 M5 BSM/Black 6MT- GONE; '03 M3 Jet Black/Black, 6MT- GONE; '03 M5 Carbon Black/Silverstone, GONE; '11 e90 M3, LMB/Ext Black, 6MT- GONE '11 e93 M3, LMB/Ext Black, DCT- GONE; '11 1M BSM/Black, '17 M2 Long Beach Blue/Black, 6MT; '11 1M Valencia Orange/Black
12-15-2016, 09:07 AM | #2 |
Thread killer
643
Rep 1,896
A lot of people will use aftermarket and code themselves E.g. http://www.1addicts.com/forums/showt...=388196&page=3
If you want OEM I came across this the other day: http://bmwusaservice.com/batteries?u...FY9lfgodcXAJ0g |
12-15-2016, 05:49 PM | #3 |
Rep 51
I just installed a new AGM battery from Batteries Plus, which was an exact fit and matched the OEM battery exactly. Order it online and pick it up and save 10%. There was also a $10 mail in rebate. As a result, the total price was about $170 and included a 48 month month free replacement warranty. I registered it myself using the BMW code reader from ECS. You can buy the code reader and the battery and still be cheaper than the dealer.
12-15-2016, 05:53 PM | #4 | |
Thread killer
643
Rep 1,896
12-15-2016, 06:26 PM | #5 | |
Rep 839
Drives: BMW 1M VO
12-15-2016, 10:06 PM | #7 | |
Rep 839
Drives: BMW 1M VO
12-15-2016, 10:24 PM | #8 |
Rep 51
I went with the Duracell because the X2 had a slightly higher CCA rating, and I wanted to match the OEM battery.
Make sure you remove the blanking plug opposite the vent tube hole from the OEM battery and transfer it to the new battery. |
12-15-2016, 10:39 PM | #9 |
Rep 839
Drives: BMW 1M VO
Nice, now just have to find that battery here in Canada.
12-16-2016, 10:30 AM | #10 | |
Rep 206
Schwaben: https://www.ecstuning.com/b-schwaben...020sch01a~scf/ Peake: https://www.ecstuning.com/b-peake-re...ash-fcx3-u~kt/ Thanks! |
12-16-2016, 03:05 PM | #12 |
Rep 839
Drives: BMW 1M VO
Anyone know where in Canada I can order the Duracell one? Not having much luck finding a retailer.
12-16-2016, 03:38 PM | #14 |
Rep 217
What has to be "registered" with a code reader? I don't get why changing a battery has to be so difficult. is this a bmw thing or are all manufacturers doing this?
12-16-2016, 04:05 PM | #15 |
Bergspyder
1469
Rep 1,212
You tell the car what the amp hour rating is and if it is wet or AGM.
Each has different charge acceptance rates. The car then adjust alternator output appropriately. I need one myself...168 at NAPA for an AGM and I have Carly already. R
12-16-2016, 04:19 PM | #16 |
Rep 51
I believe registering the battery tells the car to reset the charging profile for a new battery. Also, the car records the mileage of each battery replacement
My research showed the Batteries Plus warranty at 48 months free replacement was substantially better than the NAPA warranty. |
12-16-2016, 06:32 PM | #18 | |
Rep 22,992
You can also use the "Carly App" to register a new battery along with a OBDII wifi plug. This combo runs less than $70 for both. :thumbs:
12-16-2016, 11:35 PM | #19 | |
Bergspyder
1469
Rep 1,212
None. Just code it. Takes 5 mins with Carly.
12-20-2016, 10:22 AM | #20 |
Rep 957
You absolutely can replace an AGM battery with a wet-cell battery. You just need to code for the change so it charges correctly (AGM and Lead-acid batteries require different amperage during charging). There is definitely benefits to running AGM batteries though.
I wrote this comprehensive guide on how to register/code a battery: https://www.[spool]street.com/forums...-battery.1020/ Remove the brackets [] around spool. It walks you through some of your other options. |
12-20-2016, 01:10 PM | #21 | |
Thread killer
643
Rep 1,896
