09-09-2011, 12:27 PM | #2 |
Rep 1,239
Bump.... I'm looking to order some since the car is coming in next week. Curious to see if anyone has tried some and has recommendations on front and rear spacer sizes...
TIA
● 2015 Cayman S (Current), 2011 1M BSM #297 (Sold), 2008 135i (Sold) ● |
09-09-2011, 01:37 PM | #3 |
Rep 3,164
Drives: Many
Garage List 2020 BMW M2 CS [0.00]
1994 Audi RS2 Avant [0.00] 2021 Audi RS6 Avant [0.00] 1988 BMW E30 M3 [0.00] 2011 BMW 1///M [0.00] 2017 BMW F80 M3 30 ... [0.00] 2018 Porsche 991.2 GT3 [0.00] 2015 Porsche Macan ... [0.00] 1998 Porsche 993 C4S [0.00] 1994 Lancia Delta I ... [0.00] 2008 Audi RS4 [0.00] |
I'm about to, just waiting for my car to arrive to PCD prolly in a week (been a restless 6+ weeks since I dropped her in EU). Most likely a 10mm all around, though I think I'm about to slap the rear tires up front and go with 285/30 in the back (265/285 combo fits perfect on a 9/10 rim, respectively). Have a company make me some, theyrun a high class operation, they'll make you anything you desire!
http://www.motorsport-tech.com
1988 BMW E30 M3: Hennarot, S14, stock 2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB 1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust 2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods |
09-09-2011, 01:50 PM | #4 |
Rep 1,239
Ill be picking up mine Wednesday (9/14) and was going to order maybe 15(f)/12(r) but I wanted to see what anyone else had done. I had 12(f)/10(r) on my 135 with stock wheels and tires and no rubbing. When I went to a little bigger tire I experienced rubbing. I guess 12/10 would probably work fine on the 1M stock setup, but would like to know for sure.
09-09-2011, 04:36 PM | #6 |
Rep 1,239
I assume you haven't had any issues with rubbing?
09-09-2011, 05:03 PM | #8 |
Rep 971
Drives: Ducati Hypermotard
I believe Dan Parker has wheel spacers, along with other suspension mods. Probably best to see what he has because if you intend on lowering, then you won't run into spacing issues if using his setup (i.e. pushed out to far).
Here you go w/pics: http://www.1addicts.com/forums/showthread.php?t=564848 Last edited by mikewills; 09-09-2011 at 05:38 PM.. |
09-09-2011, 06:41 PM | #9 |
Rep 155
09-09-2011, 08:46 PM | #10 |
Rep 1,421
How much did you lower yours? I tried 10mm front spacers when I had the Motons installed and the front tires hit the front of the fender liner really bad when the wheel was turned about 80% to lock. With the 5's I have no rubbing.
Dan Parker
09-09-2011, 10:39 PM | #11 | |
Rep 155
Did you get rid of the motons? |
09-10-2011, 09:20 AM | #14 |
Rep 1,239
I thought most people put the wider spacers up front???
09-10-2011, 04:55 PM | #16 |
Rep 1,239
Since every post I've seen about spacers on the M3 and 1er.
Looks good though.
09-10-2011, 05:38 PM | #17 |
Rep 113
09-10-2011, 05:56 PM | #18 |
Rep 254
Drives: 2020 Bmw 228xi Gran Coupe
09-10-2011, 08:02 PM | #20 |
Rep 1,239
With stock tires and wheels, the primary reason for spacers is looks. The front tires are narrower and can use a little more spacer to get the tire out to the same place relative to the fender as compared to the rear. Everything I have read on this forum has people using 2-3mm more spacer in the front vs the rear. Until this thread.... Maybe I'm just smoking crack and confused.
09-11-2011, 05:24 PM | #21 |
Rep 1,239
Here is one of the threads I was referring to. Seems most of the m3's are doing something like 15mm (front) and 12mm (rear)
http://www.m3post.com/forums/showthr...schnell+spacer
