      10-15-2015, 07:29 PM   #1
sparky_phantom
Drives: 2011 BMW 335i
2011 BMW 135i  [0.00]
Exclamation Error Codes And Almost Limp Mode
When I was coming from from work today, my car hesitated then gave me a warning on dash stating engine was over heating to drive moderately (Yellow Light). So I was then trying to get over to a safe place to stop. Before I could get there got another message stating that engine was over heating and to stop the car immediately (Red Light). I got pulled over and then pulled error codes from my Cobb AP V3. I got the following codes:
ECU
-P3792
-P377A
-P2CF4
I have tried to Google these and I can't find these anywhere. I did find a list of error codes in a .pdf for my N55, however these were not in there. If anyone is able to help, I would be grateful.
I have a 2011 135i DCT N55.
      10-15-2015, 09:11 PM   #2
what have i got into
Drives: 2012 135i, 2013 X5d
Look at the second column of that N55 error codes sheet and you will see the 0X3792 code versus looking at the 6th column with the P references.
The 3792 is the coolant pump. Hope that helps.
      10-16-2015, 12:49 AM   #3
sparky_phantom
Thank you for clarifying that. So maybe water pump has gone out?
      10-16-2015, 06:06 AM   #4
Just from what I have seen on these forums, I wouldn't automatically assume it's the pump. It may be a broken thermostat, wiring harness loose to the pump, and then maybe it's the pump. I try and go from check the cheaper solutions to more expensive solutions. But that's all I have as I haven't had this issue.
http://www.1addicts.com/forums/showthread.php?t=960648
      10-16-2015, 10:07 AM   #5
dbchun
dbchun's Avatar
63
Drives: 2009 135i
how many miles on the car? my water pump just failed and had the same exact symptoms (but i didn't get a chance to check codes)
N54 powered
MHD tuned
      10-16-2015, 11:54 AM   #6
Funch
Drives: 2007 z4m coupe
My water pump went at 44k, same issues. This car is prone to having water pump issues between 30-60k. A forum search will pull up a number of threads outlining the issue. If it IS the water pump you are looking at between 700-1000 dollars to fix if you are outside warranty as the pump is a $500 part and you may need a new thermostat as well... Best of luck.
      10-16-2015, 07:57 PM   #7
sparky_phantom
My car currently has 55k miles on it. I have an extended warranty I bought so that should fix that if that is the issue.
cobb, n55, overheat, overheat message
